查看: 4452|回复: 0
单片机计时器程序0~9999
ID:954156 发表于 2021-7-17 17:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
unsigned char code LedChar[] = {  //数码管显示字符转换表
    0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,
    0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E
unsigned char LedBuff[6] = {  //数码管显示缓冲区,初值0xFF确保启动时都不亮
    0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
unsigned char i = 0;   //动态扫描的索引
unsigned int cnt = 0;  //记录T0中断次数
unsigned char flag1s = 0;  //1秒定时标志
    char j;  //循环变量
    unsigned long sec = 0;  //记录经过的秒数
    unsigned char buf[6];   //中间转换缓冲区
    EA = 1;       //使能总中断
    ENLED = 0;    //使能U3
    ADDR3 = 1;    //因为需要动态改变ADDR0-2的值,所以不需要再初始化了
    TMOD = 0x01;  //设置T0为模式1
    TH0  = 0xFC;  //为T0赋初值0xFC67,定时1ms
    TL0  = 0x67;
    ET0  = 1;     //使能T0中断
    TR0  = 1;     //启动T0
    while (1)
        if (flag1s == 1)  //判断1秒定时标志
            flag1s = 0;   //1秒定时标志清零
            sec++;        //秒计数自加1
            //将sec按十进制位从低到高依次提取到buf数组中
            buf[0] = sec%10;
            buf[1] = sec/10%10;
            buf[2] = sec/100%10;
            buf[3] = sec/1000%10;
            buf[4] = sec/10000%10;
            buf[5] = sec/100000%10;
            //从最高为开始,遇到0不显示,遇到非0退出循环
            for (j=5; j>=1; j--)
                if (buf[j] == 0)
                    LedBuff[j] = 0xFF;
                    break;
            //将剩余的有效数字位如实转换
            for ( ; j>=0; j--)  //for()起始未对j操作,j即保持上个循环结束时的值
                LedBuff[j] = LedChar[buf[j]];
/* 定时器0中断服务函数 */
void InterruptTimer0() interrupt 1
    TH0 = 0xFC;  //重新加载初值
    TL0 = 0x67;
    cnt++;       //中断次数计数值加1
    if (cnt >= 1000)  //中断1000次即1秒
        cnt = 0;      //清零计数值以重新开始下1秒计时
        flag1s = 1;   //设置1秒定时标志为1
    //以下代码完成数码管动态扫描刷新
    P0 = 0xFF;   //显示消隐
    switch (i)
        case 0: ADDR2=0; ADDR1=0; ADDR0=0; i++; P0=LedBuff[0]; break;
        case 1: ADDR2=0; ADDR1=0; ADDR0=1; i++; P0=LedBuff[1]; break;
        case 2: ADDR2=0; ADDR1=1; ADDR0=0; i++; P0=LedBuff[2]; break;
        case 3: ADDR2=0; ADDR1=1; ADDR0=1; i++; P0=LedBuff[3]; break;
        case 4: ADDR2=1; ADDR1=0; ADDR0=0; i++; P0=LedBuff[4]; break;
        case 5: ADDR2=1; ADDR1=0; ADDR0=1; i=0; P0=LedBuff[5]; break;
        default: break;
原理图:http://www.51hei.com/bbs/dpj-210214-1.html
