查看: 4598|回复: 2
STM32液位检测系统程序(含原理图)
电路原理图如下:
STM32单片机源程序如下:
#include "main.h"
#include "dma.h"
#include "tim.h"
#include "usart.h"
#include "gpio.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
#include "OLED_NEW.H"
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
#define LED0(a) if(a){HAL_GPIO_WritePin(LED0_GPIO_Port,LED0_Pin,GPIO_PIN_SET);}\
        else{HAL_GPIO_WritePin(LED0_GPIO_Port,LED0_Pin,GPIO_PIN_RESET);}
#define LED1(a) if(a){HAL_GPIO_WritePin(LED1_GPIO_Port,LED1_Pin,GPIO_PIN_SET);}\
        else{HAL_GPIO_WritePin(LED1_GPIO_Port,LED1_Pin,GPIO_PIN_RESET);}
#define BEEP(a) if(a){HAL_GPIO_WritePin(BEEP_GPIO_Port,BEEP_Pin,GPIO_PIN_SET);}\
        else{HAL_GPIO_WritePin(BEEP_GPIO_Port,BEEP_Pin,GPIO_PIN_RESET);}
#define Trig(a) if(a){HAL_GPIO_WritePin(Trig_GPIO_Port,Trig_Pin,GPIO_PIN_SET);}\
        else{HAL_GPIO_WritePin(Trig_GPIO_Port,Trig_Pin,GPIO_PIN_RESET);}
#define IN1(a) if(a){HAL_GPIO_WritePin(IN1_GPIO_Port,IN1_Pin,GPIO_PIN_SET);}\
        else{HAL_GPIO_WritePin(IN1_GPIO_Port,IN1_Pin,GPIO_PIN_RESET);}
#define IN2(a) if(a){HAL_GPIO_WritePin(IN2_GPIO_Port,IN2_Pin,GPIO_PIN_SET);}\
        else{HAL_GPIO_WritePin(IN2_GPIO_Port,IN2_Pin,GPIO_PIN_RESET);}
#define k1 HAL_GPIO_ReadPin(K1_GPIO_Port,K1_Pin)
#define k2 HAL_GPIO_ReadPin(K2_GPIO_Port,K2_Pin)
#define k3 HAL_GPIO_ReadPin(K3_GPIO_Port,K3_Pin)
#define level_Reservoir 145   //水库高度
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN PV */
uint8_t key_bz,mode,ms_20,state,state_bz;
uint8_t value_set,value_H,value_L,uart_buf[2];
uint16_t value_level;
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
/* USER CODE BEGIN PFP */
void key()//按键程序
        if(k1==1 && k2==1 && k3==1){key_bz=1;}
        if(k1==0 && key_bz==1)//K1按下,切换设置参数
                key_bz=0;mode++;
                if(mode>=4){mode=0;}
                switch(mode)
                        case 0:
                                OLED_ShowChar(7*8,2,' ');
                                OLED_ShowChar(7*8,4,' ');
                                OLED_ShowChar(7*8,6,' ');
                                break;
                        case 1:
                                OLED_ShowChar(7*8,2,'*');
                                break;
                        case 2:
                                OLED_ShowChar(7*8,4,'*');
                                break;
                        case 3:
                                OLED_ShowChar(7*8,6,'*');
                                break;
        if(k2==0 && key_bz==1)//K2按下,参数加
                key_bz=0;
                if(mode == 0)
                        mode=4;state_bz=1;
                if(mode == 1)
                        value_set++;
                        if(value_set > 9){value_set=2;}
                else if(mode == 2)
                        value_H++;
                        if(value_H > 9){value_H=2;}
                else if(mode == 3)
                        value_L++;
                        if(value_L > 9){value_L=2;}
        if(k3==0 && key_bz==1)//K3按下,参数减
                key_bz=0;
                if(mode == 1)
                        value_set--;
                        if(value_set >= 17){value_set=9;}
                else if(mode == 2)
                        value_H--;
                        if(value_H >=17){value_H=9;}
                else if(mode == 3)
                        value_L--;
                        if(value_L >= 17){value_L=9;}
void Control_Motor(uint8_t way)//控制水泵的方式
        switch(way)
                case 0://电机停止
                        IN1(0);IN2(0);
                        LED0(1);LED1(1);
                        break;
                case 1://抽水
                        IN1(1);IN2(0);
                        LED0(0);LED1(1);
                        break;
                case 2://补水
                        IN1(0);IN2(1);
                        LED0(1);LED1(0);
                        break;
void Uart_Send(uint8_t dat)//串口发送
        HAL_UART_Transmit(&huart1,&dat,1,999);
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_DMA_Init();
  MX_TIM1_Init();
  MX_USART1_UART_Init();
  MX_TIM2_Init();
  /* USER CODE BEGIN 2 */
        HAL_TIM_Base_Start(&htim1);
        HAL_TIM_Base_Start_IT(&htim2);
        HAL_UART_Receive_DMA(&huart1,uart_buf,2);
        OLED_Init();
        OLED_Clear();
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
        BEEP(0);
        OLED_ShowCHinese(0,0,"水位");OLED_ShowChar(4*8,0,':');
        OLED_ShowCHinese(0,2,"设置");OLED_ShowChar(4*8,2,':');
        OLED_ShowCHinese(0,4,"上限");OLED_ShowChar(4*8,4,':');
        OLED_ShowCHinese(0,6,"下限");OLED_ShowChar(4*8,6,':');
        value_set=6;value_L=2;value_H=8;
  while (1)
                key();
                Control_Motor(state);//0停止    1抽水    2补水
                if(ms_20 == 1)
                        ms_20=0;
                        Trig(1);
                        HAL_Delay(1);
                        Trig(0);
                OLED_ShowChar(5*8,0,value_level/100%10 + 0x30);
                OLED_ShowChar(6*8,0,value_level/10%10 + 0x30);//显示液位
                OLED_ShowChar(7*8,0,'.');
                OLED_ShowChar(8*8,0,value_level%10 + 0x30);
                Uart_Send(value_level/100%10 + 0x30);//串口发送液位值
                Uart_Send(value_level/10%10 + 0x30);
                Uart_Send(value_level%10 + 0x30);
                Uart_Send('\r');
                Uart_Send('\n');
                if(value_level>=(value_H*10) || value_level<=(value_L*10)){BEEP(1);}
                else{BEEP(0);}
                OLED_ShowChar(5*8,2,value_set/10 + 0x30);//显示  设置  值
                OLED_ShowChar(6*8,2,value_set%10 + 0x30);
                OLED_ShowChar(5*8,4,value_H/10 + 0x30);//显示  设置  值
                OLED_ShowChar(6*8,4,value_H%10 + 0x30);
                OLED_ShowChar(5*8,6,value_L/10 + 0x30);//显示  设置  值
                OLED_ShowChar(6*8,6,value_L%10 + 0x30);
                if(mode == 4)
                        if(state_bz == 1)
                                if(value_level > (value_set*10)){state=2;state_bz=2;}//大于设置值,抽水
                                else if(value_level < (value_set*10)){state=1;state_bz=3;}//小于设置值补水
                        if(state_bz == 2)
                                if(value_level <= (value_set*10)){mode=0;state=0;}
                        if(state_bz == 3)
                                if(value_level >= (value_set*10)){mode=0;state=0;}
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /**Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI_DIV2;
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL16;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
    Error_Handler();
/* USER CODE BEGIN 4 */
void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin)//外部中断 中断回调函数
        if(GPIO_Pin == GPIO_PIN_11)
                TIM1->CNT = 0;
                while(HAL_GPIO_ReadPin(GPIOB,GPIO_PIN_11) == 1);
                value_level = TIM1->CNT*0.34/2;//计算液面与传感器距离
                if(value_level <= value_level){value_level = level_Reservoir - value_level;}//计算液位距离
                else{value_level = 0;}
uint16_t time;
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)//定时器中断回调函数
        if(htim == &htim2)
                time++;
                if(time >= 500){time=0;ms_20=1;}
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)//串口回调函数
        if(uart_buf[0] == 'S'){value_set = uart_buf[1]-0x30;}
        else if(uart_buf[0] == 'H'){value_H = uart_buf[1]-0x30;}
        else if(uart_buf[0] == 'L'){value_L = uart_buf[1]-0x30;}
        else if(uart_buf[0] == 'Z'){state_bz=1;mode=4;}
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
全部代码51hei附件下载:
KEIL5_LEVEL.7z (2.96 MB, 下载次数: 38)
参与人数 1黑币 +20 收起 理由
admin + 20 共享资料的黑币奖励!
收藏收藏5 分享淘帖 顶顶 踩踩
ID:971154 发表于 2021-12-2 09:38 | 只看该作者
楼主好,液位检测读的是某个pin脚的PWM的值吗?
ID:274187 发表于 2021-7-21 16:07 | 只看该作者
液位传感器走的是串口是吗?
