查看: 2157|回复: 3
51单片机+DHT111数码管显示出错
ID:626743 发表于 2021-7-24 20:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
首先感谢进来看的朋友,表示感谢。请问我这个DHT11数码管显示,为什么数码管只显示最后一位?
主函数:
#include<reg52.h>
#include"dht11.h"
#include"delay.h"
#include"uart.h"
sbit B1 = P2^2;
sbit B2 = P2^1;
sbit B3 = P2^0;
unsigned char tempH,tempL,humiH,humiL;
unsigned char Temp_Humi[4];
unsigned char code Temp_Table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
void Show_temp(void)
        uint i=0;
        Temp_Humi[0] = tempH/10;
        Temp_Humi[1] = tempH%10;
        Temp_Humi[2] = humiH/10;
        Temp_Humi[3] = humiH%10;
        for(i=0;i<4;i++)
                switch(i)
                        case (0) : B1 = 0 ;B2 = 0 ;B3 = 0 ; break;
                        case (1) : B1 = 0 ;B2 = 0 ;B3 = 1 ; break;
                        case (2) : B1 = 0 ;B2 = 1 ;B3 = 0 ; break;
                        case (3) : B1 = 0 ;B2 = 1 ;B3 = 1 ; break;
                P0 =  Temp_Table[Temp_Humi[i]];
                Delay40us();
int main(void)
        Timer0Init();
        UartInit();
        Dht11_Star();
        if(Dht11_Check()<0)
                printf("error! \r\n");
                printf("ok!  \r\n");
                Dht11_Read_Dat(&tempL,&tempH,&humiH,&humiL);
                Delay4ms();
                Show_temp();
                printf("temp: %bu%bu  humi: %bu%bu\r\n",Temp_Humi[0],Temp_Humi[1],Temp_Humi[2],Temp_Humi[3]);
DHT11时序读取
#include<intrins.h>
#include"dht11.h"
#include"delay.h"
void Dht11_Star(void)
        DATE = 0;
        Delay20ms();
        DATE = 1;
        Delay30us();
char Dht11_Check(void)
        uint t = 0;
        while(DATE)
                t++;
                _nop_();
                if(t>4000)
                        return -1;
        t=0;
        while(!DATE)
                t++;
                _nop_();
                if(t>100)
                        return -2;
                t=0;
        while(DATE)
                t++;
                _nop_();
                if(t>100)
                        return -3;
        return 0;
uchar Dht11_Read(void)
        uint i,t=0;
        uchar temp=0;
        for(i=0;i<8;i++)
                while(!DATE)
                        t++;
                        _nop_();
                        if(t>60)
                                return -1;
                Delay40us();
                temp <<= 1;
                if(DATE)
                        temp |= 1;
                        t=0;
                        while(DATE)
                                t++;
                                _nop_();
                                if(t>80)
                                        return -1;
        return temp;
short Dht11_Read_Dat(char *tempL,char *tempH,char *humiH,char *humiL)
        uchar i;
        uchar buff[5];
        Dht11_Star();
        if(Dht11_Check() == 0)
                for(i=0;i<5;i++)
                        buff[i]= Dht11_Read();
                Delay40us();
                if((buff[0]+buff[1]+buff[2]+buff[3]) == buff[4])
                        *humiH=buff[0];
                        *humiL=buff[1];
                        *tempH=buff[2];
                        *tempL=buff[3];
                        return 0;
                        return -1;
                return -2;
ID:747478 发表于 2021-7-25 01:54 来自触屏版 | 只看该作者
把show-temp函数里delay延时改成4ms试试
ID:626743 发表于 2021-7-25 14:38 | 只看该作者
谢谢 解决了
ID:965153 发表于 2021-9-9 20:45 | 只看该作者
怎么可以用dht11检查温度 当温度大于三十摄氏度 湿度大于60%时亮警灯阿
