查看: 3146|回复: 5
关于单片机中断那些事,数码管闪烁过快
感觉进入中断时间没问题,但数码管闪烁过快,代码如下
#include <reg52.h>
sbit BEEP = P1^5; //跟中断无关
bit flagls = 0;
unsigned char Ledbuf;
unsigned char T0RH = 0;
unsigned char T0RL = 0;
unsigned char code LedChar[] = {0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d, 0x07, 0x7f, 0x6f};
void ConfigTimer0(unsigned int ms)         //配置T0
         unsigned long tmp;
        tmp = 11059200/12;
        tmp = (tmp*ms)/1000;
        tmp = 65536 - tmp;
        T0RH = (unsigned char)(tmp >> 8);
        T0RL = (unsigned char)tmp;
        TMOD &= 0xf0;
        TMOD |= 0x01;
        TH0=T0RH;
        TL0=T0RL;
        EA = 1;
        ET0 = 1;
        TR0 = 1;
void LedScan()         //在中断中使用,每进中断扫描一次
         P0 = 0x00;
        P2 = (P2&0xe3);
        P0 = Ledbuf;
         unsigned int i = 0;
        unsigned int sec = 0;
        ConfigTimer0(1);        //设置定时器1ms
        for(i = 0; i < 50000; i++)
                 BEEP = ~BEEP;
                if(flagls == 1)
                        flagls = 0;
                        sec++;                                  //每次进入sec加1
                        Ledbuf = LedChar[9 - sec%10];
void InterruptTimer0() interrupt 1
         static unsigned int tmr1s = 0;
         TH0=T0RH;                           //设置断点看进入时间          第一次0.00266602s,第二次 0.00367405, 相差0.001s左右,进入正常
        TL0=T0RL;
        tmr1s++;
        if(tmr1s >= 1000);           //1s时改变flagls
                tmr1s = 0;
                flagls = 1;
        LedScan();
ID:123289 发表于 2021-7-26 13:30 | 只看该作者
你想达成的效果是什么?实际效又是什么呢?
ID:955347 发表于 2021-7-26 13:49 | 只看该作者
想每秒数码管改变一个数,实际上改变太快,肉眼分辨不了,就是数码管每个led全亮
ID:161164 发表于 2021-7-26 14:01 | 只看该作者
低级错误:多了个分号
ID:955347 发表于 2021-7-26 14:26 | 只看该作者
低级错误:多了个分号
ok,我去试试
ID:955347 发表于 2021-7-26 14:28 | 只看该作者
低级错误:多了个分号
ok,以解决,麻烦大家了
