查看: 2870|回复: 0
基于51单片机共阳极数码管的交通灯
使用一个数码管显示两个路口的时间,只亮绿灯和黄灯的时间
主路绿灯60秒,黄灯3秒
支路绿灯20秒,黄灯3秒
#include <reg52.h>
sbit ge =P1^1;
sbit shi =P1^0;
sbit sn_red=P0^0;
sbit sn__yellow=P0^1;
sbit sn__green=P0^2;
sbit ew_red=P0^3;
sbit ew__yellow=P0^4;
sbit ew_green=P0^5;
sbit key_sn_allow=P3^2;
sbit key_ew_allow=P3^3;
sbit all_allow=P3^4;
sbit all_not=P3^5;
sbit time_add=P3^0;          //
sbit time_sub=P3^1;          //
sbit time_reset=P3^6;
uchar code s7_table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};        //仿真使用的共阴极数码管,实物烧录时要取反
uint time=0;
uchar i,j;
void delay_ms(uchar z)
    uchar i,j;
        for(i=z;i>0;i--)
            for(j=110;j>0;j--);
void display_time(uchar num)
        shi=0;
        P2=s7_table[num/10];
        delay_ms(2);
        P2=0;
        shi=1;
        ge=0;
        P2=s7_table[num%10];
        delay_ms(2);
        P2=0;
        ge=1;
void keyscan()
        if(key_sn_allow==0)
                delay_ms(2);
                if(key_sn_allow==0)
                                ew_red=0;
                                ew_green=1;
                                ew__yellow=1;
                                sn_red=1;
                                sn__green=0;
                                sn__yellow=1;
                        while(!key_sn_allow)
                        display_time(0);
                        TR0=0;
                if(key_ew_allow==0)
                delay_ms(2);
                if(key_ew_allow==0)
                        ew_red=1;
                        ew_green=0;
                        ew__yellow=1;
                        sn_red=0;
                        sn__green=1;
                        sn__yellow=1;
                        while(!key_ew_allow)
                        display_time(0);
                        TR0=0;
                if(all_allow==0)
                        delay_ms(2);
                        if(all_allow==0)
                                TR0=0;
                                ew_red=1;
                                ew_green=0;
                                ew__yellow=1;
                                sn_red=1;
                                sn__green=0;
                                sn__yellow=1;
                                while(!all_allow);
                        if(all_not==0)
                delay_ms(2);
                if(all_not==0)
                        TR0=0;
                        ew_red=0;
                        ew_green=1;
                        ew__yellow=1;
                        sn_red=0;
                        sn__green=1;
                        sn__yellow=1;
                        while(!all_not);
        TMOD=0X01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
                if(time<63)
                        if(time<60)
                                        if(time_add==0)
                                         delay_ms(2);
                                         if(time_add==0)
                                            time--;
                                            while(!time_add);
                                           if(time_sub==0)
                                         delay_ms(2);
                                         if(time_sub==0)
                                           time++;
                                           while(!time_sub);
                                display_time(60-time);
                                ew_red=0;
                                ew_green=1;
                                ew__yellow=1;
                                sn_red=1;
                                sn__green=0;
                                sn__yellow=1;
                                display_time(63-time);
                                sn_red=1;
                                sn__yellow=0;
                                sn__green=1;
                                 ew_red=0;
                            ew__yellow=1;
                                ew_green=1;
                else if(time<83)
                        if(time_add==0)
                                 delay_ms(2);
                                 if(time_add==0)
                                time--;
                                while(!time_add);
                        if(time_sub==0)
                                         delay_ms(2);
                                         if(time_sub==0)
                                           time++;
                                           while(!time_sub);
                                display_time(83-time);
                                ew_red=1;
                                ew_green=0;
                                sn_red=0;
                                sn__green=1;
                                ew__yellow=1;
                                sn__yellow=1;
                                 display_time(86-time);
                                sn_red=0;
                                sn__yellow=1;
                                sn__green=1;
                                 ew_red=1;
                            ew__yellow=0;
                                ew_green=1;
                keyscan();
void_int0_isr() interrupt 1
        i++;
        if(i==20)
        i=0;
        ++time;
        if(time ==86)
                        time = 0;
