查看: 2274|回复: 0
CT107 STC15F2K60S2单片机18B20温度显示程序
ID:957828 发表于 2021-7-31 10:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "STC15F2K60S2.h"
#include "onewire.h"
#include "absacc.h"
#include "intrins.h"
typedef unsigned char uchar;
typedef unsigned int uint;
uchar code tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff};//duan ma
uchar dspbuf[8]={10,10,10,10,10,10,10,10};//huan cong qu
bit temp_flag = 0;//wen du
void Enable(uchar yc);
void cls_buzz();
void cls_led();
void display(void);
        char temperature;
        cls_buzz();cls_led();
        TMOD &= 0xF0;                //???????
        TL0 = 0xCD;                //1ms
        TH0 = 0xD4;                //??????
        TF0 = 0;                //??TF0??
        TR0 = 1;                //???0????
        ET0 = 1;
        EA = 1;
                if(temp_flag)
                        temp_flag = 0;
                        temperature = rd_temperature();
                (temperature > 10) ? (dspbuf[6] = temperature/10) : (dspbuf[6] = 10);
                dspbuf[7] = temperature % 10;
void timer0() interrupt 1
        static uchar ms=0;
        if(++ms == 50)
                ms = 0;
                temp_flag = 1;
        display();
        switch (yc)
                case 4:
                        P2 = (P2 & 0x1f) | 0x80;break;
                case 5:
                        P2 = (P2 & 0x1f) | 0xa0;break;
                case 6:
                        P2 = (P2 & 0x1f) | 0xc0;break;
                case 7:
                        P2 = (P2 & 0x1f) | 0xe0;break;
void cls_buzz()
        Enable(5);
        P0 = 0x00;
        P2 &= 0x1f;
void cls_led()
        Enable(4);
        P0 = 0xff;
        P2 &= 0x1f;
void display(void)
        static uchar dspcom = 0;
        Enable(7);
        P0 = 0xff;//xiao yin
        P2 &= 0x1f;
        P0 = 1<<dspcom;
        Enable(6);//wei xuan
        P2 &= 0x1f;
        Enable(7);//duan xuan
        P0 = tab[dspbuf[dspcom]];
        P2 &= 0x1f;
        if(++dspcom == 8)
                dspcom = 0;
初学,如有错误 请大家多多指教,代码下载:
my.rar (80.53 KB, 下载次数: 11)
参与人数 1黑币 +10 收起 理由
admin + 10 共享资料的黑币奖励!
