查看: 3404|回复: 0
利用c51单片机制作打地鼠游戏的电路程序PCB设计
ID:771881 发表于 2021-7-31 14:18 | 显示全部楼层 |阅读模式
原理图如下
pcb如下
  1. #include<reg51.h>
  2. typedef unsigned int u16;
  3. typedef unsigned char u8;
  4. #define GPIO_DIG P0
  5. #define GPIO_KEY P1
  6. sbit LSA=P2^5;
  7. sbit LSB=P2^6;
  8. sbit LSC=P2^7;
  9. u8 LedNumber;  //存放当前显示LED序号
  10. u8 KeyValue;  //存放读取到的键值
  11. u8 RightValue;  //存放当前计数值
  12. u8 code smg[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
  13.                                                          0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};//存放数码管字形码
  14. u8 code led[]={0x0f,0x0e,0x0d,0x0c,0x0b,0x0a,0x09,0x08,
  15.                                                          0x07,0x06,0x05,0x04,0x03,0x02,0x01,0x00};//存放led字形码
  16. void delay(u16 j)
  17. {
  18.                 while(j--);
  19. }
  20. void LedDisplay(u8 n)
  21. {
  22.                 u8 j;
  23.                 j=(16+7*n)%16;
  24.                 P2=(P2&0xf0)|led[j-1];
  25. }
  26. void Timer1Init()
  27. {
  28.                 TMOD|=0x10;
  29.           TH1=0Xfc;
  30.                 TL1=0x18;
  31.                 EA=1;
  32.                 TR1=1;
  33. }
  34. void Timer1() interrupt 3
  35. {
  36.                 static u16 i;
  37.                 TH1=0Xfc;
  38.                 TL1=0x18;
  39.           TR1=1;
  40.                 i++;
  41.                 if(i==1000)
  42.                 {
  43.                                 i=0;
  44.                                 LedNumber++;
  45.                                 if(LedNumber==16)
  46.                                 {
  47.                                                 LedNumber=0;
  48.                                 }
  49.                 }
  50. }
  51. void KEY_SCAN()
  52. {
  53.                 u8 a=0;
  54.                 GPIO_KEY=0X0f;
  55.                 if(GPIO_KEY!=0X0f)//检查是否有键按下
  56.                 {
  57.                                 delay(1000);//延时10ms消抖
  58.                                 if(GPIO_KEY!=0X0f)//消抖后再次检查是否有键按下
  59.                                 {
  60.                                                 //测试列
  61.                                                 switch(GPIO_KEY)
  62.                                                 {
  63.        case(0x07):KeyValue=0;break;
  64.        case(0x0b):KeyValue=1;break;
  65.        case(0x0d):KeyValue=2;break;
  66.                                                           case(0x0e):KeyValue=3;break;
  67.                                                 }
  68.                                                 //测试行
  69.                                                 GPIO_KEY=0xf0
  70.                                                 switch(GPIO_KEY)
  71.                                                 {
  72.        case(0x70):KeyValue=KeyValue;break;
  73.        case(0xb0):KeyValue=KeyValue+4;break;
  74.        case(0xd0):KeyValue=KeyValue+8;break;
  75.                                                           case(0xe0):KeyValue=KeyValue+12;break;
  76.                                                 }
  77.                                                 if((Lednummer-1)==KeyValue)
  78.                                                 {
  79.        RightValue++;
  80.                                                 }
  81.                                                 while((a<50)&&(GPIO_KEY!=0Xf0))
  82.                                                 {
  83.        delay(1000);
  84.        a++;
  85.                                                 }
  86.                                 }
  87.                 }
  88. }
  89. void DpyDisplay()
  90. {
  91.                 u8 j;
  92.                 u8 code RightValue[];
  93.                 RightValue[2]=RightValue/100;
  94.                 RightValue[1]=(RightValue%100)/10;
  95.                 RightValue[0]=RightValue%10;
  96.                 for(j=2;j>=0;j--)
  97.                 {
  98.                                 switch(j)
  99.                                 {
  100.                                                 case(2):
  101.                                                 LSA=1;LSB=0;LSC=0;break;
  102.                                                 case(1):
  103.                                                 LSA=0;LSB=1;LSC=0;break;
  104.                                                 case(0):
  105.                                                 LSA=0;LSB=0;LSC=1;break;
  106.                                 }
  107.                 P0=smg[RightValue[j]];
  108.                 delay(100);
  109.                 P0=0x00;
  110.                 }
  111. }
  112. void Judge()
  113. {
  114.
  115. }
  116. void (main)
  117. {
  118.                 while()
  119.                 {
  120.                                 GameInit();
  121.                                 Timer1Init();
  122.                                 while(1)
  123.                                 {
  124.                                         if(LedNumber>=1)
  125.                                         {
  126.                                                         LedDisplay(LedNumber);
  127.                                         }
  128.                                 }
  129.                 }
  130. }
初学,如有错误,请大家多多指导,资料仅供参考:
pcb原理图程序.7z (1.63 MB, 下载次数: 43)
