查看: 2246|回复: 5
学习单片机按键中断功能切换看了一段代码有地方无法理解
ID:960619 发表于 2021-8-19 18:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教下,这单片机代码中的P0起到什么作用?
#include<reg52.h>//#include "stc8.h"//
sbit beep=P1^5;
sbit k1=P3^1;
sbit k3=P3^2;//外部中断0 p32
sbit led=P2^0;
#define N P2
unsigned char num;
unsigned char aa;
void delay(unsigned int i)
        while(i--);
void fmq()//蜂鸣器
        beep=~beep;
        delay(100);
void led0()//流水灯
        N=0xff;
        N=0xfe;
        fmq();
        delay(50000);
        if(num!=0){return;}
        P0=0xfe;
        N=0xfd;
        fmq();
        delay(50000);
        if(num!=0){return;}
        P0=0xfe;
        N=0xfb;
        fmq();
        delay(50000);
        if(num!=0){return;}
        P0=0xfe;
        N=0xf7;
        fmq();
        delay(50000);
        if(num!=0){return;}
        P0=0xfe;
        N=0xef;
        fmq();
        delay(50000);
        if(num!=0){return;}
        P0=0xfe;
        N=0xdf;
        fmq();
        delay(50000);
        if(num!=0){return;}
        P0=0xfe;
        N=0xbf;
        fmq();
        delay(50000);
        if(num!=0){return;}
        P0=0xfe;
        N=0x7f;
        fmq();
        delay(50000);
  if(num!=0){return;}
        P0=0xfe;
void led1()//led对称亮
                N=0x7e;
                fmq();
                delay(35000);
                //delay(35000);
                if(num!=1){break;}
                P0=0xfc;
                N=0xbd;
                fmq();
                delay(35000);
                //delay(35000);
                if(num!=1){break;}
                P0=0xfc;
                N=0xdb;
                fmq();
                delay(35000);
                //delay(35000);
                if(num!=1){break;}
                P0=0xfc;
                N=0xe7;
                fmq();
                delay(35000);
                //delay(35000);
                if(num!=1){break;}
                P0=0xfc;
                N=0xe7;
                fmq();
                delay(35000);
                //delay(35000);
                if(num!=1){break;}
                P0=0xfc;
                N=0xdb;
                fmq();
                delay(35000);
                //delay(35000);
                if(num!=1){break;}
                P0=0xfc;
                N=0xbd;
                fmq();
                delay(35000);
                //delay(35000);
                if(num!=1){break;}
                P0=0xfc;
                N=0x7e;
                fmq();
                delay(35000);
                //delay(35000);
                if(num!=1){break;}
                P0=0xfc;
void led2()//led分别单双数亮
                N=0xaa;
                fmq();
                delay(50000);
                delay(50000);
                if(num!=2){break;}
                P0=0xf8;
                N=0x55;
                fmq();
                delay(50000);
                delay(50000);
                P0=0xf8;
                if(num!=2){break;}
                P0=0xf8;
void led3()//通过按键k1使led一个一个亮
        unsigned int i;
        N=0xfe;
                if(k1==0)
                  switch(i)
                         case(0):N=0xfd;fmq();i++;break;
                         case(1):N=0xfb;fmq();i++;break;
                         case(2):N=0xf7;fmq();i++;break;
                         case(3):N=0xef;fmq();i++;break;
                         case(4):N=0xdf;fmq();i++;break;
                         case(5):N=0xbf;fmq();i++;break;
                         case(6):N=0x7f;fmq();i++;break;
                         case(7):N=0xff;fmq();i++;break;
                  while(!k1);
                if(i>=8){i=0;break;}
                P0=0xf0;
                if(num!=3){break;}
void init()//中断初始化
        IT0=1;//外部中断0 跳变触发
        EX0=1;//外部中断0 p32
        EA=1;
        init();
                        switch(num)
                         case(0):led0();
                                       P0=0xfe;
                                      break;
                         case(1):led1();
               P0=0xfc;
                                      break;
                         case(2):led2();
                                       P0=0xf8;
                                       break;//num++;
                         case(3):led3();
                                       P0=0xf0;
                                        break;
void init0() interrupt 0//中断程序 k3
        //EX0=0;
        if(num==0){P0=0xfe;}
        num=num+1;
        if(num==1){P0=0xfc;}
        if(num==2){P0=0xf8;}
        if(num==3){P0=0xf0;}
  if(num>3){num=0;}
        //EX0=1;
ID:235200 发表于 2021-8-19 18:58 | 只看该作者
P0接有8个发光二极管,通过按键的次数(中断)改变P0口所接发光二极管的显示状态
ID:960619 发表于 2021-8-19 19:45 | 只看该作者
噢,懂了。他这个是按键一次点亮一个PO口,就是模式切换的指示灯
ID:303735 发表于 2021-8-20 08:32 | 只看该作者
感觉有点复杂
ID:584195 发表于 2021-8-20 09:33 | 只看该作者
你这个delay全是阻塞式的,会不会效果不好呀!
ID:960619 发表于 2021-8-20 19:57 | 只看该作者
啥是阻塞式?这不是我写的,论坛上看到的,我拿来学习的
