查看: 4064|回复: 2
51单片机豆浆机仿真电路+程序源码
豆浆机仿真电路图+程序源码
  u8 jiyi=0;
  beep=1;
  Motor=0;//关电机
  M_LED=1;//关电机指示灯
  LED=0;
  LCD_Initial();
  LCD_Print(2,0, "soybean milk");
  LCD_Print(4,1, "machine");
  delayms(300);
  LCD_Write(0x00, 0x01);//清屏
  LCD_Print(0,0, "Please Add Water");
  LCD_Print(0,1, "Percentage:000  ");
  TIME_INIT_0();//开定时器
    KEY();
/***********************************************浆液溢出***********************************************/
        if(yichu_flag==1)
          LCD_Print(0,0,"Foam Over");
          LCD_Print(0,1,"Time:  S");
          Motor=0;//关电机
          M_LED=1;//关电机指示灯
          jiyi=Star_Flag;//记录系统运行状态
          Star_Flag=0;
          Timeyichu_Set=10;//设置10秒消泡沫
          yichu_flag=2;
        if(yichu_flag==2)
          Timeyichu=yichu_fen*60+yichu_miao;//计算时间
      dis[1]=Timeyichu/10+'0';
      dis[2]=Timeyichu%10+'0';
      LCD_Print(5,1,&dis[1]);
      LCD_Print(6,1,&dis[2]);
          if(Timeyichu>=Timeyichu_Set)//达到预设
            Timeyichu_Set=0;
            yichu_haomiao=0;
            yichu_miao=0;
            yichu_fen=0;
                  yichu_flag=0;
                if(jiyi%2==0)
                  Star_Flag=jiyi-1;//恢复系统运行状态
                    Star_Flag=jiyi;//恢复系统运行状态
/***************************************1600W加热到80℃*******************************************/
        if(Star_Flag==1)//正常启动
          LCD_Print(0,0,"Power:1600W");
          LCD_Print(0,1,"Tempe:  ");
          LCD_Print(10,1,WD);
          Star_Flag=2;//将进入1600W加热到80度
        if(Star_Flag==2)//1600W加热到80度
                if(temp>0&&temp<=1600)
                    chuli(temp,Temp_Dis);          //数据处理
              LCD_PutChar(6,1,&Temp_Dis[0]);
                    LCD_PutChar(7,1,&Temp_Dis[1]);
                  LCD_Print(8,1,".");
          LCD_PutChar(9,1,&Temp_Dis[2]);
                  if(temp>800)
                    break;
      haomiao=0;
          miao=0;
          fen=0;
          Star_Flag=3;//将进入启动电机打浆,加热功率1600W
/****************************************打浆120S不加热*****************************************/
        if(Star_Flag==3)//启动电机打浆120s
          Motor=1;//启动电机打浆
          M_LED=0;//开电机指示灯
          LCD_Print(0,0,"No Heating");
          LCD_Print(0,1,"Motor Star:   S");
          Time_Set=120;//设定电机打浆120秒
          Star_Flag=4;//将进入等待打浆时间到
        if(Star_Flag==4)//等待打浆时间到
          Time=fen*60+miao;//计算时间
          dis[0]=Time/100+'0';
      dis[1]=Time%100/10+'0';
      dis[2]=Time%100%10+'0';
          LCD_Print(11,1,&dis[0]);
      LCD_Print(12,1,&dis[1]);
      LCD_Print(13,1,&dis[2]);
          if(Time>=Time_Set)
                  Time_Set=0;
            haomiao=0;
            miao=0;
            fen=0;
                  Star_Flag=5;//将进入800W加热,打浆同时进行,60s
/*****************************************800W煮浆同时打浆*****************************************/
        if(Star_Flag==5)//800W加热,打浆同时进行,60s
          Motor=1;//启动电机打浆
          M_LED=0;//开电机指示灯
          LCD_Print(0,0,"Power:800W");
          Time_Set=60;//设定800W加热同时电机打浆60秒
          Star_Flag=6;//将进入等待煮浆打浆时间到
        if(Star_Flag==6)//等待煮浆打浆时间到
      dis[1]=Time/10+'0';
      dis[2]=Time%10+'0';
          if(Time>=Time_Set)
                  Time_Set=0;
            haomiao=0;
            miao=0;
            fen=0;
                Motor=0;//关闭电机打浆
                M_LED=1;//关电机指示灯
                  Star_Flag=7;//将进入煮浆
/*******************************************450W煮浆60s,350W煮浆120s*****************************************/
        if(Star_Flag==7)//煮浆
          Time_Set=180;//设定180s煮浆
          Star_Flag=8;//将进入等待煮浆打浆时间到
        if(Star_Flag==8)//煮浆
          if(Time<=60)//400W煮浆
             LCD_Print(0,0,"Power:400W");
        dis[1]=(Time)/10+'0';
        dis[2]=(Time)%10+'0';
        LCD_Print(6,1,&dis[1]);
        LCD_Print(7,1,&dis[2]);
          if(Time>60&&Time<=180)//350W煮浆
                   LCD_Print(0,0,"Power:350W");
                dis[0]=(Time-60)/100+'0';
        dis[1]=(Time-60)%100/10+'0';
        dis[2]=(Time-60)%100%10+'0';
        LCD_Print(5,1,&dis[0]);
          if(Time>=Time_Set)
                  Time_Set=0;
            haomiao=0;
            miao=0;
            fen=0;
                  Star_Flag=9;//将进结束
/********************************************结束10s**************************************/
        if(Star_Flag==9)//结束
          LCD_Print(0,0,"End of Run");
          Time_Set=10;//设定10s
          Star_Flag=10;
        if(Star_Flag==10)//结束
      dis[1]=Time/10+'0';
      dis[2]=Time%10+'0';
          if(Time>=Time_Set)
                  Time_Set=0;
            haomiao=0;
            miao=0;
            fen=0;
                  Star_Flag=11;//将进入蜂鸣器
/********************************************10后报警*******************************************/
        if(Star_Flag==11)//蜂鸣器
          Time_Set=2;//设定10s
          Star_Flag=12;
        if(Star_Flag==12)//蜂鸣器
          if(Time>0&&Time<=1)
                  beep=0;
          if(Time>1&&Time<=2)
                  beep=1;
          if(Time>=Time_Set)
            haomiao=0;
            miao=0;
            fen=0;
Proteus7.5版本的仿真工程dsn文件和代码下载: 豆浆机.zip (233.21 KB, 下载次数: 127)
收藏收藏6 分享淘帖 顶顶 踩踩
ID:130230 发表于 2021-8-24 17:14 | 只看该作者
建议模块化编程,魔鬼数字用宏替代增加代码可读性。真正工作后就能体会到,好的程序员不是能实现多么牛叉的功能,而是把简单的功能实现的清晰明了。程序可维护性,健壮性都是靠层次和规范来保证的。
参与人数 1黑币 +20 收起 理由
admin + 20 回帖助人的奖励!
ID:1024528 发表于 2022-5-7 15:19 | 只看该作者
这个程序前面定义的部分能发一下吗
