查看: 2701|回复: 4
使用单片机+ADC芯片TLC5615时输出正弦波的频率提高不上去
ID:898834 发表于 2021-8-31 15:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求大佬指点为什么我程序这样写最终得到的正弦波频率只有几百赫兹
#include <stc8.h>          //基准电压是2.515V
#define uint8 unsigned char
#define uint16 unsigned int
sbit CS = P2^4;       //片选
sbit SCLK = P2^2;       //时钟
sbit DIN = P2^0;       //数据入口
uint16 code tosin[256]={
0x1FF,0x20C,0x218,0x225,0x231,0x23E,0x24A,0x256,0x263,0x26F,0x27B,0x287,0x293,0x29F,0x2AB,0x2B7
,0x2C3,0x2CE,0x2DA,0x2E5,0x2F0,0x2FB,0x306,0x311,0x31B,0x326,0x330,0x33A,0x343,0x34D,0x357,0x360
,0x369,0x371,0x37A,0x382,0x38A,0x392,0x39A,0x3A1,0x3A8,0x3AF,0x3B6,0x3BC,0x3C2,0x3C8,0x3CD,0x3D3
,0x3D8,0x3DC,0x3E1,0x3E5,0x3E8,0x3EC,0x3EF,0x3F2,0x3F5,0x3F7,0x3F9,0x3FB,0x3FC,0x3FD,0x3FE,0x3FE
,0x3FE,0x3FE,0x3FE,0x3FD,0x3FC,0x3FB,0x3F9,0x3F7,0x3F5,0x3F2,0x3EF,0x3EC,0x3E8,0x3E5,0x3E1,0x3DC
,0x3D8,0x3D3,0x3CD,0x3C8,0x3C2,0x3BC,0x3B6,0x3AF,0x3A8,0x3A1,0x39A,0x392,0x38A,0x382,0x37A,0x371
,0x369,0x360,0x357,0x34D,0x343,0x33A,0x330,0x326,0x31B,0x311,0x306,0x2FB,0x2F0,0x2E5,0x2DA,0x2CE
,0x2C3,0x2B7,0x2AB,0x29F,0x293,0x287,0x27B,0x26F,0x263,0x256,0x24A,0x23E,0x231,0x225,0x218,0x20C
,0x1FF,0x1F2,0x1E6,0x1D9,0x1CD,0x1C0,0x1B4,0x1A8,0x19B,0x18F,0x183,0x177,0x16B,0x15F,0x153,0x147
,0x13B,0x130,0x124,0x119,0x10E,0x103,0x0F8,0x0ED,0x0E3,0x0D8,0x0CE,0x0C4,0x0BB,0x0B1,0x0A7,0x09E
,0x095,0x08D,0x084,0x07C,0x074,0x06C,0x064,0x05D,0x056,0x04F,0x048,0x042,0x03C,0x036,0x031,0x02B
,0x026,0x022,0x01D,0x019,0x016,0x012,0x00F,0x00C,0x009,0x007,0x005,0x003,0x002,0x001,0x000,0x000
,0x000,0x000,0x000,0x001,0x002,0x003,0x005,0x007,0x009,0x00C,0x00F,0x012,0x016,0x019,0x01D,0x022
,0x026,0x02B,0x031,0x036,0x03C,0x042,0x048,0x04F,0x056,0x05D,0x064,0x06C,0x074,0x07C,0x084,0x08D
,0x095,0x09E,0x0A8,0x0B1,0x0BB,0x0C4,0x0CE,0x0D8,0x0E3,0x0ED,0x0F8,0x103,0x10E,0x119,0x124,0x130
,0x13B,0x147,0x153,0x15F,0x16B,0x177,0x183,0x18F,0x19B,0x1A8,0x1B4,0x1C0,0x1CD,0x1D9,0x1E6,0x1F2 };
void DA_Conver(uint16 DA_Value)   //进行DA转换,输入十位DA值,十六位数据,高四位无效,认为0000        //低二位为00
        uint8 i;
        DA_Value <<= 6;
        CS =0;                  //片选DA芯片,低电平有效
        SCLK = 0;               //片选低电平, 时钟为上升沿时开始传送数据
        for(i=0;i<12;i++)        //从高位到地位依次发送
                DIN = (bit)(DA_Value & 0x8000);
                SCLK = 1;
                DA_Value <<= 1;  // 一位一位的进行传输
                SCLK = 0;
        CS = 1;     // 关闭芯片,CS的上升沿和下降沿只有在clk为低的时候才有效
        SCLK = 0;
        uint16 j;
        P2M0=0x00;
        P2M1=0x00;
                for(j=0;j<255;j++)
                        DA_Conver(tosin[j]); //输出正弦波
ID:161164 发表于 2021-8-31 17:07 | 只看该作者
你在一个周期内要处里比较/位移/IO输出等动作 256x12 = 3072次
假设你是用主频12Mhz 1T的单片机
每次动作耗时1us
一个周期耗时3.072ms => 269Hz
很正常啊~
ID:898834 发表于 2021-10-17 19:52 | 只看该作者
假设你是用主频12Mhz 1T的单片机
每次动作 ...
那有什么方法能够把频率提上去吗
ID:401564 发表于 2021-10-18 09:28 | 只看该作者
几个月了哥们,还在折腾这个?
TLC5615本身的刷新频率就只有1.21MHZ,你分成256次,最高的频率也就是4.72KHZ,加上这还是串行通讯,输出的频率也就只能是这么高了
想要提高就要用DAC900E这样的并口DAC
ID:898834 发表于 2021-10-19 21:18 | 只看该作者
Y_G_G 发表于 2021-10-18 09:28
几个月了哥们,还在折腾这个?
TLC5615本身的刷新频率就只有1.21MHZ,你分成256次,最高的频率也就是4.72KHZ, ...
好吧,之前这个问题一直搁置了,这几天找资料记起来了
