查看: 2605|回复: 0
STM32 GPIO/USART/timer 控制(寄存器版)
ID:964867 发表于 2021-9-8 14:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本文出自:zhishi-zhishi点net
在开发板上试验了GPIO点亮LED,串口中断和定时器。
  1. #include "stm32f10x.h"
  2. /*
  3. GPIO :
  4.       PC.14  PC.15 <---> LED
  5.               PB.7 <---> Button
  6.         PA.9 PA.10 <---> USART
  7. */
  8. #define RCC_APB2ENR    *(uint32_t*)(0x40021000+0x18)
  9. #define RCC_APB1ENR    *(uint32_t*)(0x40021000+0x1C)
  10. #define GPIOC_CRH    *(uint32_t*)(0x40011000+0x04)
  11. #define GPIOC_ODR    *(uint32_t*)(0x40011000+0x0C)
  12. #define GPIOB_CRL    *(uint32_t*)(0x40010C00+0x00)
  13. #define GPIOB_ODR    *(uint16_t*)(0x40010C00+0x0C)
  14. #define GPIOB_BSRR   *(uint16_t*)(0x40010C00+0x10)
  15. #define SETENA_ISER0    *(uint32_t*)(0xe000E100+0x00)
  16. #define EXTI_IMR        *(uint32_t*)(0x40010400+0x00)
  17. #define EXTI_RTSR       *(uint32_t*)(0x40010400+0x08)
  18. #define EXTI_FTSR       *(uint32_t*)(0x40010400+0x0C)
  19. #define EXTI_PR         *(uint32_t*)(0x40010400+0x14)
  20. #define AFIO_EXTICR2    *(uint32_t*)(0x40010000+0x0C)
  21. #define GPIOA_IDR    *(uint32_t*)(0x40010800+0x08)
  22. #define GPIOA_ODR    *(uint32_t*)(0x40010800+0x0C)
  23. #define GPIOA_CRH    *(uint32_t*)(0x40010800+0x04)
  24. #define SETENA_ISER1    *(uint32_t*)(0xe000E100+0x04)
  25. //#define USART1_BASE    *(uint32_t*)(0x40013800+0x00)  //bug : redefinition
  26. #define USART1_SR    *(uint32_t*)(0x40013800+0x00)
  27. #define USART1_DR    *(uint32_t*)(0x40013800+0x04)
  28. #define USART1_BRR    *(uint32_t*)(0x40013800+0x08)
  29. #define USART1_CR1    *(uint32_t*)(0x40013800+0x0C)
  30. #define USART1_CR2    *(uint32_t*)(0x40013800+0x10)
  31. #define USART1_CR3    *(uint32_t*)(0x40013800+0x14)
  32. #define TIM1_CR1      *(uint32_t*)(0x40012c00+0x00)
  33. #define TIM1_DIER     *(uint32_t*)(0x40012c00+0x0C)
  34. #define TIM1_SR       *(uint32_t*)(0x40012c00+0x10)
  35. #define TIM1_PSC      *(uint32_t*)(0x40012c00+0x28)
  36. #define TIM1_ARR      *(uint32_t*)(0x40012c00+0x2C)
  37. #define TIM3_CR1      *(uint32_t*)(0x40000400+0x00)
  38. #define TIM3_DIER      *(uint32_t*)(0x40000400+0x0C)
  39. #define TIM3_SR      *(uint32_t*)(0x40000400+0x10)
  40. #define TIM3_PSC      *(uint32_t*)(0x40000400+0x28)
  41. #define TIM3_ARR      *(uint32_t*)(0x40000400+0x2C)
  42. #if 1
  43. int m = 0;
  44. void EXTI9_5_IRQHandler(void)
  45. {
  46.    EXTI_PR = 0x1 << 7;
  47.      m++;
  48.      if(m%2 == 1)
  49.         GPIOC_ODR   = 0x0 << 14;
  50.      else if(m%2 == 0)
  51.           GPIOC_ODR = 0x3 << 14;
  52. }
  53. #endif
  54. char test_str[128];
  55. char* p;
  56. int i;
  57. volatile int mm = 0;
  58. volatile int old_mm  = 0;
  59. char recv_buf[64];
  60. int  num = 0;
  61. int is_one_line = 0;
  62. void USART1_IRQHandler(void)
  63. {
  64.       USART_ClearITPendingBit(USART1, USART_IT_RXNE);
  65.     mm += 10;
  66.
  67.       recv_buf[num++] = USART1_DR;
  68.       if(num >= 64)
  69.              num = 0;
  70.         if(recv_buf[num-1] == 0x0a && recv_buf[num-2] == 0x0d)
  71.              is_one_line = 1;
  72. }
  73. int time1_out    = 0;
  74. int old_time1_out= 0;
  75. #if 1
  76. void TIM1_UP_IRQHandler(void)
  77. {
  78.     TIM_ClearITPendingBit(TIM1, TIM_FLAG_Update);
  79.     time1_out++;
  80.
  81. }
  82. #else
  83. void TIM3_IRQHandler(void)
  84. {
  85.     TIM_ClearITPendingBit(TIM3, TIM_FLAG_Update);
  86.     time1_out++;
  87.
  88. }
  89. #endif
  90. int main()
  91. {
  92.
  93.
  94.     RCC_APB2ENR = 0x1 << 4 | 0x1 << 3 | 0x1 << 0 | 0x1 << 2 | 0x1 << 14  /*| 0x1 << 11 */ ;     //p53
  95.   GPIOC_CRH = 0x03 << 28 | 0x03 << 24;  //p68
  96.
  97.     GPIOB_CRL   = 0x00 <<28 |  /*0x01*/ /*0x10 --bug */0x02 << 30;
  98.
  99.   GPIOC_ODR = 0x3 << 14;            //p69
  100.
  101.
  102.     EXTI_IMR  = 0x01 << 7;
  103. //EXTI_RTSR = 0x01 << 7;
  104.     EXTI_FTSR = 0x01 << 7;
  105.
  106.     AFIO_EXTICR2 = 0x01  << 12;
  107.   GPIOA_ODR = 0x1 << 9;
  108.   GPIOA_CRH = 0x3 << 4 | 0x2 << 6 | 0x0 << 8 | 0x1 << 10;
  109.     SETENA_ISER0 = 0x1 << 23;
  110.     SETENA_ISER1 = 0x1 << 5;
  111.
  112.
  113.
  114.
  115.
  116.             USART1_BRR = 0x0271;
  117.             USART1_CR1 |= 0x03 << 2;  //TE/RE
  118.
  119.             USART1_CR1 |= 0x1 << 5 /* | 0x1 <<7*/;
  120.
  121.             USART1_CR1 |= 0x1 << 13;
  122.
  123. #if 1
  124.   RCC_APB2ENR |= (0x1 << 11);
  125.   TIM1_CR1  |= 0x1 << 0;   //CEN
  126.     TIM1_DIER |= 0x1 << 0;   //UIE
  127.     TIM1_SR   &= 0xFFFE;     //UIF
  128.
  129.     TIM1_PSC  = 7199;
  130.     TIM1_ARR  = 9999;
  131.   SETENA_ISER0  |=  0x01 << 25;
  132.
  133. #else
  134.   RCC_APB1ENR |= 0x1 << 1;
  135.   TIM3_CR1  |= 0x1 << 0;   //CEN
  136.     TIM3_DIER |= 0x1 << 0;   //UIE
  137.     TIM3_SR   &= 0xFFFE;     //UIF
  138.
  139.     TIM3_PSC  = 7199;
  140.     TIM3_ARR  = 9999;
  141.   SETENA_ISER0  |=  0x01 << 29;
  142. #endif
  143.
  144.
  145.    while(1)
  146.      {
  147.          if(is_one_line == 1)
  148.              {
  149.                         memset(test_str, 0, sizeof(test_str));
  150.                   sprintf( test_str, "%s", recv_buf);
  151.                         p = test_str;
  152.                         while((*p)!='\0')
  153.                         {
  154.                             USART_SendData(USART1, *(p++));
  155.                             for(i=0; i < 1000; i++)
  156.                                  ;
  157.                         }
  158.                         num = 0;
  159.                         is_one_line = 0;
  160.                         memset(recv_buf, 0, sizeof(recv_buf));
  161.              }
  162.
  163.
  164.
  165.              if(old_time1_out == time1_out)
  166.                    ;
  167.              else
  168.              {
  169.                         memset(test_str, 0, sizeof(test_str));
  170.                     sprintf( test_str, "old: %d, time1_out:%d", old_time1_out, time1_out);
  171.                         p = test_str;
  172.                         while((*p)!='\0')
  173.                         {
  174.                             USART_SendData(USART1, *(p++));
  175.                             for(i=0; i < 1000; i++)
  176.                                  ;
  177.                         }
  178.
  179.
  180.                  old_time1_out = time1_out;
  181.              }
  182.
  183.
  184.      }
  185.      return 0;
  186.
  187.
  188. }
至此试验就告完成。用过仿真软件Proteus(后来好象串口COMPIM失效了。)和编译器Keil MDK5,表示谢意。
源文件打包在此: test_timer.7z (268.11 KB, 下载次数: 8)
本文出自:www点zhishi-zhishi点net/working/stm32_timer.html
