查看: 4020|回复: 1
warning: #3731-D: intrinsic is deprecated 请问一下这个警告要怎么消除
ID:514901 发表于 2021-9-11 09:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
100黑币
用的最新的HAL库,uart相关的库代码更新了,加了原子锁还是啥不太懂,绕后然后报警告..\LIB\STM32F4xx_HAL_Driver\Src\stm32f4xx_hal_uart.c(3619): warning:  #3731-D: intrinsic is deprecated
最佳答案
查看完整内容
CAUSE The Arm Compiler does not guarantee to preserve the state of the exclusive monitor. This is why the __ldrex, __ldrexd, __strex and __strexd intrinsics are deprecated. RESOLUTION Either ignore the warnings or update the Arm CMSIS Pack to a version later than 4.3.0 to get these warning messages suppressed. 具体参考:https://www.keil.com/support/docs/3783.htm
ID:875095 发表于 2021-9-11 09:09 | 只看该作者
CAUSE
RESOLUTION
