查看: 2352|回复: 2
关于单片机同时运行两个简单程序
ID:283883 发表于 2021-9-24 22:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
下面这两个程序一个是逐个点亮的流水灯,一个是呼吸灯,如何同时执行?谢谢!就是P1流水灯和另外一个呼吸灯一起工作,类似中断,但不太会搞。谢谢!
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. #define uint unsigned int
  5. int yanshi=600;
  6. sbit P10 = P1^0;
  7. sbit P11 = P1^1;
  8. sbit P12 = P1^2;
  9. sbit P13 = P1^3;
  10. sbit P14 = P1^4;
  11. sbit P15 = P1^5;
  12. sbit P16 = P1^6;
  13. sbit P17 = P1^7;
  14. /*1MS delay*/
  15. void delay_1ms(uchar x)
  16. {
  17.     uchar j;
  18.     while(x--){
  19.         for(j=0;j<250;j++)
  20.             {;}
  21.         }
  22. }
  23. void main()
  24. {
  25.         while(1){
  26.                 P10 = 1;P11 = 1;P12 = 1;P13 = 1;P14 = 1;P15 = 1;P16 = 1;P17 = 0;
  27.                 delay_1ms(yanshi);delay_1ms(yanshi);
  28.                 P10 = 1;P11 = 1;P12 = 1;P13 = 1;P14 = 1;P15 = 1;P16 = 0;P17 = 0;
  29.                 delay_1ms(yanshi);delay_1ms(yanshi);
  30.                 P10 = 1;P11 = 1;P12 = 1;P13 = 1;P14 = 1;P15 = 0;P16 = 0;P17 = 0;
  31.                 delay_1ms(yanshi);delay_1ms(yanshi);
  32.                 P10 = 1;P11 = 1;P12 = 1;P13 = 1;P14 = 0;P15 = 0;P16 = 0;P17 = 0;
  33.                 delay_1ms(yanshi);delay_1ms(yanshi);
  34.                 P10 = 1;P11 = 1;P12 = 1;P13 = 0;P14 = 0;P15 = 0;P16 = 0;P17 = 0;
  35.                 delay_1ms(yanshi);delay_1ms(yanshi);
  36.                 P10 = 1;P11 = 1;P12 = 0;P13 = 0;P14 = 0;P15 = 0;P16 = 0;P17 = 0;
  37.                 delay_1ms(yanshi);delay_1ms(yanshi);
  38.                 P10 = 1;P11 = 0;P12 = 0;P13 = 0;P14 = 0;P15 = 0;P16 = 0;P17 = 0;
  39.                 delay_1ms(yanshi);delay_1ms(yanshi);
  40.                 P10 = 0;P11 = 0;P12 = 0;P13 = 0;P14 = 0;P15 = 0;P16 = 0;P17 = 0;
  41.                 delay_1ms(yanshi);delay_1ms(yanshi);
  42.                 P10 = 1;P11 = 1;P12 = 1;P13 = 1;P14 = 1;P15 = 1;P16 = 1;P17 = 1;
  43.                 delay_1ms(yanshi);delay_1ms(yanshi);
  44.                 }
  45. }
  1. #include <reg51.h>
  2. #define uint unsigned int
  3. sbit led1=P2^0;  //定义控制灯的端口
  4. int HXD,Clock=1000;
  5. void delay(uint x) //设置延迟函数
  6. {
  7.        int i;
  8.        for(i=0;i<x;i++);
  9. }
  10.
  11. void main(void)
  12. {
  13. while(1)
  14.    {
  15.       for(HXD=Clock;HXD>0;HXD--) //led逐渐变暗
  16.        {
  17.        led1=1;
  18.        delay(HXD);
  19.        led1=0;
  20.        delay(Clock-HXD);
  21.
  22.          }
  23. for(HXD=0;HXD<Clock;HXD++)   //led逐渐变亮
  24.        {
  25.         led1=1;
  26.        delay(HXD);
  27.        led1=0;
  28.        delay(Clock-HXD);
  29.
  30.         }
  31.     }
  32. }
谢谢大家!
ID:83553 发表于 2021-9-25 11:02 | 只看该作者
可以用RTOS
ID:716656 发表于 2021-9-25 11:28 | 只看该作者
把第一个程序里主函数部分的逻辑放到第二个程序的中断里,当然延时取消了,用中断计数。计数到一定程度,计数清零,状态改变一次P1 = 0xff;P1 = 0xfe;……
参与人数 1黑币 +20 收起 理由
admin + 20 回帖助人的奖励!
