查看: 3569|回复: 6
为什么单片机倒计时变为0是不停止,是什么问题,该怎么修改呢?求解
#include<reg51.h>
uchar min,sec,count,sec1,sec2,min0,min1,min2,keystopc,temp;
sbit keystop=P3^0;
sbit keyh=P3^1;
sbit keym=P3^2;
sbit keys=P3^3;
sbit lcden=P3^4;
sbit lcdrw=P3^6;
sbit lcdrs=P3^5;
uchar code table[]={'0','1','2','3','4','5','6','7','8','9',':'};
void init()                                                //定时器初始化
        count=0;
        min=0;
        sec=59;
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        TR0=1;
        ET0=1;
        EA=1;
void delay(uint z)                //延时程序
        uint x,y;
        for(x=z;x>0;x--)
         for(y=110;y>0;y--);
------LCD1602显示函数------
void write_com(uchar com)
        lcdrs=0;
        P0=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_data(uchar date)
        lcdrs=1;
        P0=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void init_1602()                                //初始化1602
        lcden=0;
        lcdrw=0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        write_com(0x80);
void write_Char(unsigned char x,unsigned char y,unsigned char date)
         if (y == 0)
                write_com(0x80 + x);
                write_com(0xC0 + x);
        write_data(date);
void display(uchar min0,uchar min1,uchar min2,uchar sec1,uchar sec2)         //显示程序
        write_Char(3,0,table[min0]);
        write_Char(4,0,table[min1]);
        write_Char(5,0,table[min2]);
        write_Char(6,0,table[0x0a]);
        write_Char(7,0,table[sec1]);
        write_Char(8,0,table[sec2]);
------计时器/定时器0-----
void count0() interrupt 1
        count++;
        if(count==20)
                        count=0;
                        sec--;
                        if(sec==0)
                                        sec=60;
                                    min--;
------主函数------
        init();
        init_1602();
                if(keystop==0)                             //检测是否停止键按下
                        delay(10);
                        if(keystop==0)
                                if(keystopc!=1)   keystopc++;      //按停止键的次数
                                else              keystopc=0;
                                while(keystop==0);                 //松手检测
                                delay(5);
                                while(keystop==0);
                        switch(keystopc)
                                case 1:TR0=0;break;                // 按键一次就停止计数
                                case 0:TR0=1;break;
                                default:break;
                if(keyh==0)                 //实现小时加一
                        delay(50);
                        if(keyh==0)
                                if(min!=110)
                                        min++;
                        while(!keym);                  //松手检测
                        delay(5);
                        while(!keym);
                if(keym==0)              //实现分钟加一
                        delay(50);
                        if(keym==0)
                                if(min!=0)
                                        min--;
                        while(!keyh);                //松手检测
                        delay(5);
                        while(!keyh);
                min0=min/100;
                min1=min%100/10;
                min2=min%10;
                sec1=sec/10;
                sec2=sec%10;
               display(min0,min1,min2,sec1,sec2);  //一直显示时钟
收藏收藏1 分享淘帖 顶1 踩
ID:883242 发表于 2021-10-4 17:51 | 只看该作者
void count0() interrupt 1 里面 min--; 这句话改成:
  if (min)min--;
ID:858009 发表于 2021-10-4 18:00 | 只看该作者
  if (min)min--;
不行,秒到零,没有停下来,继续倒计时60
ID:624769 发表于 2021-10-4 18:01 | 只看该作者
if(count==20) 的里面要这样写:
     if(count==20)
                        count=0;
                        if(sec==0)
                                   if(min != 0)
                                           sec=59;
                                           min--;
                        else   sec--;
ID:824490 发表于 2021-10-4 22:12 | 只看该作者
  if(count==20)
  if (sec==0)
    sec=59;
   if (min==0) min=59;
  else     min--;
else sec--;
ID:578842 发表于 2021-10-5 06:38 | 只看该作者
秒到0,把中断停止不就行了
ID:578842 发表于 2021-10-5 06:40 | 只看该作者
TR0=0;
