查看: 2993|回复: 0
Arduino驱动LCD1602液晶程序
ID:873089 发表于 2021-10-24 20:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
LCD1602的V0是背光可接Arduino的GND
  1. #define RS_CLR digitalWrite(13,LOW);
  2. #define RS_SET digitalWrite(13,HIGH);
  3. #define RW_CLR digitalWrite(12,LOW);
  4. #define RW_SET digitalWrite(12,HIGH);
  5. #define EN_CLR digitalWrite(11,LOW);
  6. #define EN_SET digitalWrite(11,HIGH);
  7. unsigned char arr[]="Hello Word!";  //16个字符以内
  8. void setup() {
  9.   pinMode(2,OUTPUT);//D7
  10.   pinMode(3,OUTPUT);//D6
  11.   pinMode(4,OUTPUT);//D5
  12.   pinMode(5,OUTPUT);//D4
  13.   pinMode(6,OUTPUT);//D3
  14.   pinMode(7,OUTPUT);//D2
  15.   pinMode(8,OUTPUT);//D1
  16.   pinMode(9,OUTPUT);//D0
  17. // pinMode(10,OUTPUT);
  18.   pinMode(11,OUTPUT);//EN
  19.   pinMode(12,OUTPUT);//RW
  20.   pinMode(13,OUTPUT);//RS
  21. }
  22. void loop() {
  23.   LCD_Init();
  24.   LCD_Clear();//清屏
  25.   LCD_Write_Char(7,0,'o');
  26.   LCD_Write_Char(8,0,'k');
  27.   LCD_Write_String(1,1,arr);
  28.   delay(1000);
  29.   delay(1000);
  30.   delay(1000);
  31.   delay(1000);
  32.   delay(1000);
  33. }
  34. //模拟单片机八位输出
  35. void DataPort(unsigned char data)
  36. {
  37. if(data&0x80)digitalWrite(2,1);
  38. else         digitalWrite(2,0);
  39. if(data&0x40)digitalWrite(3,1);
  40. else         digitalWrite(3,0);
  41. if(data&0x20)digitalWrite(4,1);
  42. else         digitalWrite(4,0);
  43. if(data&0x10)digitalWrite(5,1);
  44. else         digitalWrite(5,0);
  45. if(data&0x08)digitalWrite(6,1);
  46. else         digitalWrite(6,0);
  47. if(data&0x04)digitalWrite(7,1);
  48. else         digitalWrite(7,0);
  49. if(data&0x02)digitalWrite(8,1);
  50. else         digitalWrite(8,0);
  51. if(data&0x01)digitalWrite(9,1);
  52. else         digitalWrite(9,0);
  53. }
  54. /*------------------------------------------------
  55.               判忙函数
  56. ------------------------------------------------*/
  57. char LCD_Check_Busy(void)
  58. {
  59.   unsigned char x;
  60. DataPort(0xFF);
  61. RS_CLR;
  62. RW_SET;
  63. EN_CLR;
  64. delay(1);
  65. EN_SET;
  66. pinMode(13,INPUT);
  67. x=digitalRead(13);
  68. pinMode(13,OUTPUT);
  69. if(x) return 0;
  70. else return 1;
  71. }
  72. /*------------------------------------------------
  73.               写入命令函数
  74. ------------------------------------------------*/
  75. void LCD_Write_Com(unsigned char com)
  76. {
  77. while(LCD_Check_Busy()); //忙则等待
  78. delay(5);
  79. RS_CLR;
  80. RW_CLR;
  81. EN_SET;
  82. DataPort(com);
  83. delay(1);
  84. EN_CLR;
  85. }
  86. /*------------------------------------------------
  87.               写入数据函数
  88. ------------------------------------------------*/
  89. void LCD_Write_Data(unsigned char Data)
  90. {
  91. //while(LCD_Check_Busy()); //忙则等待
  92. delay(5);
  93. RS_SET;
  94. RW_CLR;
  95. EN_SET;
  96. DataPort( Data);
  97. delay(1);
  98. EN_CLR;
  99. }
  100. /*------------------------------------------------
  101.                 清屏函数
  102. ------------------------------------------------*/
  103. void LCD_Clear(void)
  104. {
  105. LCD_Write_Com(0x01);
  106. delay(5);
  107. }
  108. /*------------------------------------------------
  109.               写入字符串函数
  110. ------------------------------------------------*/
  111. void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
  112. {
  113. if (y == 0)
  114.   {
  115.    LCD_Write_Com(0x80 + x);     //表示第一行
  116.   }
  117. else
  118.   {
  119.   LCD_Write_Com(0xC0 + x);      //表示第二行
  120.   }
  121. while (*s)
  122.   {
  123. LCD_Write_Data( *s);
  124. s ++;
  125.   }
  126. }
  127. /*------------------------------------------------
  128.               写入字符函数
  129. ------------------------------------------------*/
  130. void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data)
  131. {
  132. if (y == 0)
  133.   {
  134.   LCD_Write_Com(0x80 + x);
  135.   }
  136. else
  137.   {
  138.   LCD_Write_Com(0xC0 + x);
  139.   }
  140. LCD_Write_Data( Data);
  141. }
  142. /*------------------------------------------------
  143.               初始化函数
  144. ------------------------------------------------*/
  145. void LCD_Init(void)
  146. {
  147.    LCD_Write_Com(0x38);    /*显示模式设置*/
  148.    delay(5);
  149.    LCD_Write_Com(0x38);
  150.    delay(5);
  151.    LCD_Write_Com(0x38);
  152.    delay(5);
  153.    LCD_Write_Com(0x38);
  154.    LCD_Write_Com(0x08);    /*显示关闭*/
  155.    LCD_Write_Com(0x01);    /*显示清屏*/
  156.    LCD_Write_Com(0x06);    /*显示光标移动设置*/
  157.    delay(5);
  158.    LCD_Write_Com(0x0C);    /*显示开及光标设置*/
  159. }
  160.
收藏收藏2 分享淘帖 顶顶 踩踩
