查看: 5154|回复: 0
基于arduino+TM1637的计时器程序(包含倒计时、暂停功能)Proteus仿真
基于arduino的计时器(包涵倒计时、暂停、重置),在proteus8中仿真通过。用了两组1673的时钟芯片。
Arduino代码如下:
  1. #include <SevenSegmentTM1637.h>
  2. #include <SevenSegmentExtended.h>
  3. volatile int minute;
  4. volatile int second;
  5. volatile int order;
  6. volatile int full;
  7. volatile int empty;
  8. volatile int setvalue;
  9. volatile int topvalue;
  10. boolean  timerState=LOW;
  11. SevenSegmentExtended  display(8,9);
  12. void setup(){
  13. pinMode(2, INPUT);
  14.   minute = 0;
  15.   second = 0;
  16.   order = 0;
  17.   full = 0;
  18.   empty = 0;
  19.   setvalue = 5;
  20.   topvalue = 0;
  21.   display.begin();
  22.   order = 0;
  23.   // 倒计时时sencond与minute从full开始计时,顺计时从empty开始计时
  24.   if (order == 0) {
  25.     empty = 0;
  26.     full = 59;
  27.     minute = setvalue;
  28.     second = 0;
  29.     topvalue = 0;
  30.   } else {
  31.     empty = 59;
  32.     full = 0;
  33.     minute = 0;
  34.     // 设置为x分钟,加上秒钟走59,实际多走了一分钟,所以减一
  35.     topvalue = setvalue - 1;
  36.   }
  37.   attachInterrupt(digitalPinToInterrupt(2),interruptFun,LOW);
  38. }
  39. void loop(){
  40.   // 决定顺计时倒计时0为倒计时,1为顺计时
  41.   // 设置计时的最大数值
  42.   // 倒计时时topvalue=0时minute重置为setvalue
  43.   // 顺计时topvalue=setvalue值时被重置
  44.   // minute=0
  45. if(timerState)
  46. {
  47.   display.printTime(minute,second,true);
  48.   delayMicroseconds(1);
  49.   if (second == empty && minute == topvalue) {
  50.     if (order == 0) {
  51.       // 当minute达到设定的值则
  52.       minute = setvalue;
  53.       second = empty;
  54.     } else {
  55.       // 当minute达到设定的值则
  56.       minute = full;
  57.       second = full;
  58.     }
  59.   } else if (second == empty) {
  60.     if (order == 0) {
  61.       second = 59;
  62.       minute = minute - 1;
  63.     } else {
  64.       second = 0;
  65.       minute = minute + 1;
  66.     }
  67.   } else {
  68.     if (order == 0) {
  69.       second = second - 1;
  70.     } else {
  71.       second = second + 1;
  72.     }
  73.   }
  74. }
  75. }
  76. void interruptFun()
  77. {
  78. timerState=!timerState;
  79.     digitalWrite(5,timerState);
  80.     // Inside the attached function, delay() won't work and the value returned by millis() will not increment.
  81.   //  delay(5000);
  82.
  83. }
Proteus8.8版本的仿真图下载:
countDowntimer.zip (31.11 KB, 下载次数: 53)
收藏收藏1 分享淘帖 顶顶1 踩踩
