查看: 5759|回复: 2
求助编译错误error C141: syntax error near 'void', expected '__asm'
ID:978933 发表于 2021-11-7 16:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
18B20.c(128): error C141: syntax error near 'void', expected '__asm'
新手求助,谢谢大家
  1. #include <reg52.h>
  2. sbit RS=P2^0;
  3. sbit RW=P2^1;
  4. sbit E=P1^2;
  5. sbit DQ=P1^4;
  6. int readtemp=0;
  7. unsigned char str[]={"0123456789"};
  8. unsigned char s[]={"Temperature:"};
  9. void delay(unsigned int n)
  10. {
  11.   unsigned i=0,j=0;
  12.     for(i=0;i<n;i++)
  13.     {
  14.       for(j=0;j<120;j++);
  15.     }
  16. }
  17. void Init_DS18B20(void)         //3õê¼»ˉ
  18. {
  19.   unsigned char x=0;
  20.   DQ = 1;
  21.   delay(8);
  22.   DQ = 0;
  23.   delay(80);
  24.   DQ = 1;
  25.   delay(14);
  26.   x=DQ;
  27.   delay(20);
  28. }
  29. unsigned char ReadOneChar(void)
  30.   {
  31.     unsigned char i=0;
  32.     unsigned char dat = 0;
  33.     for (i=8;i>0;i--)
  34.     {
  35.       DQ = 0;
  36.       dat>>=1;
  37.       DQ = 1;
  38.       if(DQ)
  39.       dat|=0x80;
  40.       delay(4);
  41.      }
  42.      return(dat);
  43.   }
  44.
  45. void WriteOneChar(unsigned char dat)
  46.
  47. {
  48.   unsigned char i=0;
  49.   for (i=8; i>0; i--)
  50.   {
  51.    DQ = 0;
  52.    DQ = dat&0x01;
  53.    if(DQ){delay(1);DQ=1;}
  54.          else{delay(5);DQ = 1;}
  55.    dat>>=1;
  56.    }
  57. }
  58. unsigned char ReadTemperature(void)//¶áζè
  59. {
  60. unsigned char a=0,b=0;
  61. unsigned int temp=0;
  62. Init_DS18B20();
  63. WriteOneChar(0xCC);
  64. WriteOneChar(0x44);
  65. delay(100);    //
  66. Init_DS18B20();
  67. WriteOneChar(0xCC);
  68. WriteOneChar(0xBE);
  69. delay(100);
  70. a=ReadOneChar();
  71. b=ReadOneChar();
  72. temp=((b*256+a)>>4);
  73. return(temp);
  74. }
  75. void writedat(unsigned char dat)
  76. {
  77.   RS=1;
  78.         RW=0;
  79.         E=0;
  80.         P1=dat;
  81.         delay(5);
  82.         E=1;
  83.         E=0;
  84. }
  85. void writecom(unsigned char com)//D′Ãüáîoˉêy
  86. {
  87.   RS=0;
  88.         RW=0;
  89.         E=0;
  90.         P1=com;
  91.         delay(5);
  92.         E=1;
  93.         E=0;
  94. }
  95. //********************************************************
  96. void lcd_send(unsigned char i,unsigned char j,unsigned char str[],unsigned char n)
  97. {
  98.     //??:????i,??j,????,??????n
  99.     unsigned char x=0;
  100.     if(i==1)
  101.     {writecom(0x80+j);}
  102.     else
  103.     {writecom(0x80+0x40+j);}
  104.     for(x=0;x<n;x++)
  105.     {
  106.          writedat(str[x]);
  107.         delay(150);
  108.     }
  109. //********************************************************
  110. void initlcd()//3õê¼»ˉLCD1602
  111. {
  112.   writecom(0x38);
  113.         writecom(0x0c);
  114.         writecom(0x06);
  115.         writecom(0x01);
  116. }
  117. void display()//ÏÔê¾oˉêy
  118. {
  119.         unsigned int temp0=0,temp1=0,temp2=0,i=0;
  120.         temp0=readtemp/100;
  121.         temp1=(readtemp%100)/10;
  122.         temp2=readtemp%10;
  123.         writecom(0x80);
  124.         delay(5);
  125.         while(s[i]!='\0')
  126.         {
  127.           writedat(s[i]);
  128.                 delay(5);
  129.                 i++;
  130.         }
  131.
  132.         writecom(0x80+0x40+5);
  133.         delay(5);
  134.         writedat(str[temp0]);
  135.         delay(5);
  136.         writedat(str[temp1]);
  137.         delay(5);
  138.         writedat(str[temp2]);
  139.         delay(5);
  140.         writedat(0xDF);
  141.         delay(5);
  142.         writedat('C');
  143.         delay(5);
  144. }
  145. void main()
  146. {
  147.         initlcd();
  148.         while(1)
  149.         {
  150.          readtemp=ReadTemperature();
  151.          display();
  152.         }
  153. }
ID:883242 发表于 2021-11-7 18:26 | 只看该作者
lcd_send这个函数缺了最后结束的花括号。
ID:933089 发表于 2021-11-7 22:09 | 只看该作者
在123行底下加上一个反括号 }
