查看: 1102|回复: 1
compiling 4Check_Busy': missing functio...
ID:982112 发表于 2021-11-18 10:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#include<intrins.h>
sbit RS= P1^0;
sbit RW= P1^1;
sbit EN= P2^5;
#define RS_CLR RS=0
#define RS_SET RS=1
#define RW_CLR RW=0
#define RW_SET RW=1
#define EN_CLR EN=0
#define EN_SET EN=1
#define Dataport P0
void DelayUs2x(unsigned char t)
       while(--t);
         void        DelayMs(unsigned char t )
             while (t--)
                   DelayUs2x(245);
                    DelayUs2x(245);
                  bit LCD_check_Busy(void)
                   RS_CLR;
                   RW_SET;
                   EN_CLR;
           _nop_();
               EN_SET;
           return (bit)(Dataport & 0x80);
           void LCD_Write_Com(unsigned char com)
                while (LCD_Check_Busy());
                        RS_CLR;
                        RW_CLR;
                        EN_SET;
                        Dataport=com;
                        _nop_();
                        EN_CLR;
             void LCD_Write_Date(unsigned char Date)
                          while(LCD_Check_Busy());
                            RS_SET;
                                RW_CLR;
                            EN_SET;
                                Dataport=Date;
                                _nop_();
                                EN_CLR;
                        void LCD_Write_String(unsigned char x,unsigned char y , unsigned char *s)
                               if(y==0)
                                      LCD_Write_Com(0x80 +x);
                                             LCD_Write_Com(0xC0 + x);
                                                 while (*s)
                                        LCD_Write_Date(  *s);
                                        void LCD_Write_char (unsigned char x, unsigned char y, unsigned char Data)
                                            if (y==0)
                                                   LCD_Write_Com(0x80 + x);
                                                     LCD_Write_Com(0xC0 +x);
                                                         LCD_Write_Date (Data);
                                                         void LCD_Init(void)
                                                         LCD_Write_Com(0x38);
                                                         DelayMs (5);
                                                         DelayMs (5);
                                                         DelayMs (5);
                                                          LCD_Write_Com(0x08);;
                                                          LCD_Write_Com(0x01);
                                                          LCD_Write_Com(0x06);
                                                          DelayMs (5);
                                                          LCD_Write_Com(0x0C);
                                        void main(void)
                                          LCD_Init();
                                          LCD_Clear();
                                          while (1)
                                          LCD_Write_Char (7,0,'O');
                                          LCD_Write_Char (8,0,'k');
                                          LCD_Write_String  (1,1 "hello word");
                                          while (1);
一直显示
Build target '目标 1'
compiling 44.C...
44.C(46): warning C206: 'LCD_Check_Busy': missing function-prototype
44.C(119): warning C206: 'LCD_Clear': missing function-prototype
44.C(122): warning C206: 'LCD_Write_Char': missing function-prototype
44.C(122): error C267: 'LCD_Write_Char': requires ANSI-style prototype
44.C(124): error C141: syntax error near '<string>'
目标未创建
求解
ID:277550 发表于 2021-11-18 13:27 | 只看该作者
调用 LCD_Check_Busy 和 LCD_Write_Char 的大小写不对应。
应该仔细检查
