查看: 2985|回复: 0
基于AT89C51单片机的矩阵键盘控制数码管Proteus仿真程序
#include<reg51.h>
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71,0x00};//0-f-最后一个空
uchar j=1;
sbit p37=P3^7;
void delay(uint z)
    uint x,y;
    for(x=z;x>0;x--)
    for(y=110;y>0;y--);
void display(uchar shu)
    P1=table[shu];
    delay(5);
uchar keyscan()
    uchar temp,num;
    P2=0xfe;
    temp=P2;
    temp=temp&0xf0;
    if(temp!=0xf0)
        p37=0;
        delay(5);
        temp=P2;
        temp=temp&0xf0;
        while(temp!=0xf0)
            temp=P2;
            switch(temp)
                case 0xee:num=1;break;
                case 0xde:num=2;break;
                case 0xbe:num=3;break;
default:break;
            while(temp!=0xf0)//**********松手检测 松手后显示
                j=0;
                temp=P2;
                temp=temp&0xf0;
     }p37=1;
   P2=0xfd;
   temp=P2;
    temp=temp&0xf0;
    if(temp!=0xf0)
        p37=0;
        delay(5);
        temp=P2;
        temp=temp&0xf0;
        while(temp!=0xf0)
            temp=P2;
            switch(temp)
                case 0xed:num=4;break;
                case 0xdd:num=5;break;
                case 0xbd:num=6;break;
            while(temp!=0xf0)
                j=0;
                temp=P2;
                temp=temp&0xf0;
    }p37=1;
    P2=0xfb;
   temp=P2;
    temp=temp&0xf0;
    if(temp!=0xf0)
        p37=0;
        delay(5);
        temp=P2;
        temp=temp&0xf0;
        while(temp!=0xf0)
            temp=P2;
            switch(temp)
                case 0xeb:num=7;break;
                case 0xdb:num=8;break;
                case 0xbb:num=9;break;
            while(temp!=0xf0)
                j=0;
                temp=P2;
                temp=temp&0xf0;
    }p37=1;
    P2=0xf7;
    temp=P2;
    temp=temp&0xf0;
    if(temp!=0xf0)
        p37=0;
        delay(5);
        temp=P2;
        temp=temp&0xf0;
        while(temp!=0xf0)
            temp=P2;
            switch(temp)
                case 0xe7:num=16;break;
                case 0xd7:num=0;break;
                case 0xb7:num=16;break;
            while(temp!=0xf0)
                j=0;
                temp=P2;
                temp=temp&0xf0;
        }p37=1;
    //if(j==1)num=16;
    return num;
    p37=1;
    display(keyscan());
        //display(7);
仿真.7z (117.53 KB, 下载次数: 72)
视频.7z (6.02 MB, 下载次数: 14)
参与人数 1黑币 +30 收起 理由
admin + 30 共享资料的黑币奖励!
收藏收藏2 分享淘帖 顶顶 踩踩
