查看: 3023|回复: 2
超声波模块测距(1602显示)
ID:687726 发表于 2021-12-6 14:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用1602显示超声波测出的距离,源码如下:
#include<AT89X52.H>
#include<intrins.h>
#include<1602.H>
uint t=0;
uint s;
uchar w[]={0,0,0,0,0,0,0,0};
void zhuanhuancsb(uint l)
        w[0]=(l/10000)+'0';
        w[1]=(l%10000/1000)+'0';
        w[2]=(l%1000/100)+'0';
        w[3]='.';
        w[4]=(l%100/10)+'0';
        w[5]=(l%10)+'0';
        w[6]='c';
        w[7]='m';
void csb_int()
        P1_0=1;
        _nop_();_nop_();_nop_();_nop_();_nop_();
        P1_0=0;
        while(P1_1==0);
        TR0=1;
        while(P1_1==1);
        TR0=0;
        s=(t*340)/3;
void time_int()
        TMOD=0x01;
        TH0=(65536-10)/256;
        TL0=(65536-10)%256;
        IE=0x82;
main()
        uint j;
        lcd_init();
        time_int();
                t=0;
                csb_int();
                zhuanhuancsb(s);
                write_add(1,1);
                j=0;
                while(w[j]!='\0')
                        write_Data(w[j]);
                        j++;
void timer0() interrupt 1
        TH0=(65536-50)/256;
        TL0=(65536-50)%256;
        t++;
1602.c:
#include<AT89X52.h>
#include<intrins.h>
sbit rs=P2^0;
sbit rw=P2^1;
sbit ep=P2^2;
#define lcddata P0
void delay(uchar ms)
        uchar i;
        while(ms--)
                for(i=0;i<250;i++)
                        _nop_();
                        _nop_();
                        _nop_();
                        _nop_();
void lcd_busy()
        uchar flag=0x80;
        lcddata=0xff;
        rs=0;
        rw=1;
        ep=1;
        delay(1);
        while(flag & 0x80)
                flag=P0;
        ep=0;
void write_cmd(uchar cmd,busy)
        if(busy==1)
        lcd_busy();
        rs=0;
        rw=0;
        ep=0;
        lcddata=cmd;
        delay(1);
        ep=1;
        delay(1);
        ep=0;
void write_Data(uchar Data)
        lcd_busy();
        rs=1;
        rw=0;
        ep=0;
        lcddata=Data;
        delay(1);
        ep=1;
        delay(1);
        ep=0;
void write_add(uchar x,y)
        if(x==1)
                y=(y-1)|0x80;
                write_cmd(y,1);
                y=(y-1)|0xc0;
                write_cmd(y,1);
void lcd_init()
        lcddata=0x00;
        delay(15);
        write_cmd(0x38,0);
        delay(5);
        write_cmd(0x38,0);
        delay(5);
        write_cmd(0x38,0);
        delay(5);
        write_cmd(0x38,1);
        write_cmd(0x08,1);
        write_cmd(0x01,1);
        write_cmd(0x06,1);
        write_cmd(0x0c,1);
有了.c文件,我相信大家也一定会写.h文件的,是吧。
ID:95059 发表于 2022-5-16 10:10 | 只看该作者
写得挺好的,谢谢楼主分享
ID:371895 发表于 2024-7-30 22:03 | 只看该作者
为什么这个定时器的初始化函数void time_int(),溢出时间为10us,而中断服务服务函数里的却是50us?
