查看: 1942|回复: 1
c51单片机音乐程序
ID:989448 发表于 2021-12-8 11:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#define uint  unsigned int
uchar Count;
sbit Speak =P1^3;                                  //蜂鸣器器控制脚
/*以下数组是音符编码*/
unsigned char code SONG[] ={      //祝你平安
0x26,0x20,0x20,0x20,0x20,0x20,0x26,0x10,0x20,0x10,0x20,0x80,0x26,0x20,0x30,0x20,
0x30,0x20,0x39,0x10,0x30,0x10,0x30,0x80,0x26,0x20,0x20,0x20,0x20,0x20,0x1c,0x20,
0x20,0x80,0x2b,0x20,0x26,0x20,0x20,0x20,0x2b,0x10,0x26,0x10,0x2b,0x80,0x26,0x20,
0x30,0x20,0x30,0x20,0x39,0x10,0x26,0x10,0x26,0x60,0x40,0x10,0x39,0x10,0x26,0x20,
0x30,0x20,0x30,0x20,0x39,0x10,0x26,0x10,0x26,0x80,0x26,0x20,0x2b,0x10,0x2b,0x10,
0x2b,0x20,0x30,0x10,0x39,0x10,0x26,0x10,0x2b,0x10,0x2b,0x20,0x2b,0x40,0x40,0x20,
0x20,0x10,0x20,0x10,0x2b,0x10,0x26,0x30,0x30,0x80,0x18,0x20,0x18,0x20,0x26,0x20,
0x20,0x20,0x20,0x40,0x26,0x20,0x2b,0x20,0x30,0x20,0x30,0x20,0x1c,0x20,0x20,0x20,
0x20,0x80,0x1c,0x20,0x1c,0x20,0x1c,0x20,0x30,0x20,0x30,0x60,0x39,0x10,0x30,0x10,
0x20,0x20,0x2b,0x10,0x26,0x10,0x2b,0x10,0x26,0x10,0x26,0x10,0x2b,0x10,0x2b,0x80,
0x18,0x20,0x18,0x20,0x26,0x20,0x20,0x20,0x20,0x60,0x26,0x10,0x2b,0x20,0x30,0x20,
0x30,0x20,0x1c,0x20,0x20,0x20,0x20,0x80,0x26,0x20,0x30,0x10,0x30,0x10,0x30,0x20,
0x39,0x20,0x26,0x10,0x2b,0x10,0x2b,0x20,0x2b,0x40,0x40,0x10,0x40,0x10,0x20,0x10,
0x20,0x10,0x2b,0x10,0x26,0x30,0x30,0x80,0x00,
                                  //路边的野华不要采
0x30,0x1C,0x10,0x20,0x40,0x1C,0x10,0x18,0x10,0x20,0x10,0x1C,0x10,0x18,0x40,0x1C,
0x20,0x20,0x20,0x1C,0x20,0x18,0x20,0x20,0x80,0xFF,0x20,0x30,0x1C,0x10,0x18,0x20,
0x15,0x20,0x1C,0x20,0x20,0x20,0x26,0x40,0x20,0x20,0x2B,0x20,0x26,0x20,0x20,0x20,
0x30,0x80,0xFF,0x20,0x20,0x1C,0x10,0x18,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,
0x20,0x2B,0x40,0x20,0x20,0x1C,0x10,0x18,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,
0x20,0x2B,0x40,0x20,0x30,0x1C,0x10,0x18,0x20,0x15,0x20,0x1C,0x20,0x20,0x20,0x26,
0x40,0x20,0x20,0x2B,0x20,0x26,0x20,0x20,0x20,0x30,0x80,0x20,0x30,0x1C,0x10,0x20,
0x10,0x1C,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,0x20,0x2B,0x40,0x20,0x15,0x1F,
0x05,0x20,0x10,0x1C,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,0x20,0x2B,0x40,0x20,
0x30,0x1C,0x10,0x18,0x20,0x15,0x20,0x1C,0x20,0x20,0x20,0x26,0x40,0x20,0x20,0x2B,
0x20,0x26,0x20,0x20,0x20,0x30,0x30,0x20,0x30,0x1C,0x10,0x18,0x40,0x1C,0x20,0x20,
0x20,0x26,0x40,0x13,0x60,0x18,0x20,0x15,0x40,0x13,0x40,0x18,0x80,0x00,
* 名称 : Time0_Init()
* 功能 : 定时器的初始化,定时时间可用光碟中软件计算,11.0592MZ晶振,10ms
* 输入 : 无
* 输出 : 无
void Time0_Init()
        TMOD = 0x01;
        IE          = 0x82;
        TH0  = 0xDC;
        TL0  = 0x00;
* 名称 : Time0_Int()
* 功能 : 定时器中断,中断中实现 Count 加一
* 输入 : 无
* 输出 : 无
void Time0_Int() interrupt 1
        TH0 = 0xDC;
        TL0 = 0x00;
        Count++;                        //长度加1
* 名称 : Delay_xMs()
* 功能 : 延时子程序,经过软件调试,测得延时程序大概为55us.
* 输入 : x
* 输出 : 无
void Delay_xMs(uint x)
    uint i,j;
    for(i=0; i<x; i++)
        for(j=0; j<3; j++);
* 名称 : Play_Song()
* 功能 : 播放蜂鸣器控制程序
* 输入 : i (选择播放哪首歌曲,0为“祝你平安”,1为“路边的野花你不要采”
* 输出 : 无
void Play_Song(uchar i)
        uchar Temp1,Temp2;
        uint Addr;
        Count = 0;                                                //中断计数器清0
        Addr = i * 217;
                Temp1 = SONG[Addr++];
            if (Temp1 == 0xFF)          //休止符
                    TR0 = 0;
                    Delay_xMs(100);
            else if (Temp1 == 0x00)          //歌曲结束符
                    return;
                    Temp2 = SONG[Addr++];
                    TR0 = 1;
                            Speak = ~Speak;
                            Delay_xMs(Temp1);
                            if(Temp2 == Count)
                                    Count = 0;
                                    break;
* 名称 : Main()
* 功能 : 主函数
* 输入 : 无
* 输出 : 无
void Main()
        Time0_Init();                        //定时器0中断初始化
                Play_Song(0);                //Play_Song(0)为祝你平安    Play_Song(1)为路边的野花你不要裁
参与人数 1黑币 +10 收起 理由
admin + 10
收藏收藏2 分享淘帖 顶顶 踩踩
ID:1105755 发表于 2024-1-10 23:15 | 只看该作者
受教啦,试一下去
