查看: 1898|回复: 4
单片机汇编怎么定义蜂鸣器引脚?
一直叫不出声,救救孩子吧
ID:261025 发表于 2021-12-11 21:38 | 只看该作者
BUZZER  BIT  P1.5
ID:261025 发表于 2021-12-11 21:42 | 只看该作者
播放 祝你平安
ORG 0000H
LJMP START
ORG 000BH
INC 20H ;中断服务,中断计数器加1
MOV TH0,#0D8H
MOV TL0,#0EFH ;12M晶振,形成10毫秒中断
RETI
START:
MOV SP,#50H
MOV TH0,#0D8H
MOV TL0,#0EFH
MOV TMOD,#01H
MOV IE,#82H
MUSIC0:
NOP
MOV DPTR,#DAT ;表头地址送DPTR
MOV 20H,#00H ;中断计数器清0
MOV B,#00H ;表序号清0
MUSIC1:
NOP
CLR A
MOVC A,@A+DPTR ;查表取代码
JZ END0 ;是00H,则结束
CJNE A,#0FFH,MUSIC5
LJMP MUSIC3
MUSIC5:
NOP
MOV R6,A
INC DPTR
MOV A,B
MOVC A,@A+DPTR ;取节拍代码送R7
MOV R7,A
SETB TR0 ;启动计数
MUSIC2:
NOP
CPL P3.3
MOV A,R6
MOV R3,A
LCALL DEL
MOV A,R7
CJNE A,20H,MUSIC2 ;中断计数器(20H)=R7否?
;不等,则继续循环
MOV 20H,#00H ;等于,则取下一代码
INC DPTR
; INC B
LJMP MUSIC1
MUSIC3:
NOP
CLR TR0 ;休止100毫秒
MOV R2,#0DH
MUSIC4:
NOP
MOV R3,#0FFH
LCALL DEL
DJNZ R2,MUSIC4
INC DPTR
LJMP MUSIC1
END0:
NOP
MOV R2,#64H ;歌曲结束,延时1秒后继续
MUSIC6:
MOV R3,#00H
LCALL DEL
DJNZ R2,MUSIC6
LJMP MUSIC0
DEL:
NOP
DEL3:
MOV R4,#02H
DEL4:
NOP
DJNZ R4,DEL4
NOP
DJNZ R3,DEL3
RET
NOP
DAT:
db 26h,20h,20h,20h,20h,20h,26h,10h,20h,10h,20h,80h,26h,20h,30h,20h
db 30h,20h,39h,10h,30h,10h,30h,80h,26h,20h,20h,20h,20h,20h,1ch,20h
db 20h,80h,2bh,20h,26h,20h,20h,20h,2bh,10h,26h,10h,2bh,80h,26h,20h
db 30h,20h,30h,20h,39h,10h,26h,10h,26h,60h,40h,10h,39h,10h,26h,20h
db 30h,20h,30h,20h,39h,10h,26h,10h,26h,80h,26h,20h,2bh,10h,2bh,10h
db 2bh,20h,30h,10h,39h,10h,26h,10h,2bh,10h,2bh,20h,2bh,40h,40h,20h
db 20h,10h,20h,10h,2bh,10h,26h,30h,30h,80h,18h,20h,18h,20h,26h,20h
db 20h,20h,20h,40h,26h,20h,2bh,20h,30h,20h,30h,20h,1ch,20h,20h,20h
db 20h,80h,1ch,20h,1ch,20h,1ch,20h,30h,20h,30h,60h,39h,10h,30h,10h
db 20h,20h,2bh,10h,26h,10h,2bh,10h,26h,10h,26h,10h,2bh,10h,2bh,80h
db 18h,20h,18h,20h,26h,20h,20h,20h,20h,60h,26h,10h,2bh,20h,30h,20h
db 30h,20h,1ch,20h,20h,20h,20h,80h,26h,20h,30h,10h,30h,10h,30h,20h
db 39h,20h,26h,10h,2bh,10h,2bh,20h,2bh,40h,40h,10h,40h,10h,20h,10h
db 20h,10h,2bh,10h,26h,30h,30h,80h,00H
END
ID:884147 发表于 2021-12-11 23:30 | 只看该作者
P1.5总给高电平是不会响的,要不断改变状态,可以把SETB P1.5改为CPL P1.5
ID:624769 发表于 2021-12-11 23:39 | 只看该作者
按你电路看,BZ和单片机之间应该接个3级管,不然带不动,然后BZ的那个电阻应该去掉,不知道你单片机型号,你要用NPN管的话,没有推挽输出功能的单片机需要上拉电阻。用PNP管的话,要接VCC那头,并且驱动蜂鸣器需要 CLR  P1.5
