查看: 2029|回复: 2
stm8003单片机驱动lcd1602 四线驱动出现问题 求大神帮忙
现在发现驱动出现乱码 以及 不显示 ,功能很不正常
下面附上代码以及 原理图
#ifndef __LCD1602_H
#define __LCD1602_H
/***********LCD1602 四线驱动***********/
#include "system.h"
#include "delay.h"
/***********Definition***********/
#define LINE0   0x80
#define LINE1   0xC0
#define Rx_PORT (GPIOD)//RS= PD6  RW=PD5 EN=PD4
#define RS_PIN (GPIO_PIN_6) /* PD6 */
//#define RW_PIN (GPIO_PIN_5) /* PD5 */ /* NOT USE(RW接地) */
#define EN_PIN (GPIO_PIN_4) /* PD4 */
#define Rx_FOUR_PINS (RS_PIN | EN_PIN)
//#define Rx_ALL_PINS (RS_PIN | RW_PIN | EN_PIN) /* NOT USE */
#define Dx_PORT (GPIOC)
//#define D0_PIN (GPIO_PIN_0) /* PC0 */ /* NOT USE */
//#define D1_PIN (GPIO_PIN_1) /* PC1 */ /* NOT USE */
//#define D2_PIN (GPIO_PIN_2) /* PC2 */ /* NOT USE */
//#define D3_PIN (GPIO_PIN_3) /* PC3 */ /* NOT USE */
#define D4_PIN (GPIO_PIN_4) /* PC4 */
#define D5_PIN (GPIO_PIN_5) /* PC5 */
#define D6_PIN (GPIO_PIN_6) /* PC6 */
#define D7_PIN (GPIO_PIN_7) /* PC7 */
#define Dx_FOUR_PINS (D4_PIN | D5_PIN | D6_PIN | D7_PIN)
//#define Dx_ALL_PINS (D0_PIN | D1_PIN | D2_PIN | D3_PIN | D4_PIN | \
                     D5_PIN | D6_PIN | D7_PIN) /* NOT USE */
#define RS_LOW  GPIO_WriteLow (Rx_PORT, RS_PIN)
#define RS_HIGH GPIO_WriteHigh(Rx_PORT, RS_PIN)
#define EN_LOW  GPIO_WriteLow (Rx_PORT, EN_PIN)
#define EN_HIGH GPIO_WriteHigh(Rx_PORT, EN_PIN)
#define Dx_CLR  GPIO_Write(Dx_PORT, 0x00)
/***********Function***********/
void LCD1602_Cmd(uint8_t cmd);
void LCD1602_Data(uint8_t data);
void LCD1602_Init(void);
void LCD1602_SetCursor(uint8_t x, uint8_t y);
void LCD1602_PrintStr(uint8_t x, uint8_t y, uint8_t *str);
#endif /* __LCD1602_H */
#include "lcd1602.h"
/******发送命令******/
  delay_ms(2000);
  EN_LOW;
  RS_LOW; /* RS=0,写入命令 */
  delay_us(10);
  GPIO_Write(Dx_PORT, (cmd&0xf0));     /* 接收高四位命令 */
  EN_HIGH;
  delay_ms(1);
  EN_LOW;
  GPIO_Write(Dx_PORT, (cmd&0xf0)<<4); /* 接收低四位命令 */
  EN_HIGH;
  delay_ms(1);
  EN_LOW;
/******发送数据******/
  delay_ms(200);
  EN_LOW;
  RS_HIGH; /* RS=1,写入数据 */
  delay_us(10);
  GPIO_Write(Dx_PORT, (data&0xf0));     /* 接收高四位数据 */
  EN_HIGH;
  delay_ms(1);
  EN_LOW;
  delay_us(10);
  GPIO_Write(Dx_PORT, (data&0xf0)<<4); /* 接收低四位数据 */
  EN_HIGH;
  delay_ms(1);
  EN_LOW;
/******LCD初始化******/
    delay_ms(200);
//  LCD1602_Cmd(0x20);
//  LCD1602_Cmd(0x32);
//  delay_ms(5);
//  LCD1602_Cmd(0x28);  // 最后发0x28,进入4线模式,设置16*2显示,115*7点阵,4位数据接口
//  delay_ms(5);
//  delay_ms(5);
//  EN_HIGH;
//  EN_LOW;
  LCD1602_Cmd(0x30);
  delay_ms(5);
  LCD1602_Cmd(0x30);
  delay_ms(5);
  LCD1602_Cmd(0x30);
  delay_ms(5);
  LCD1602_Cmd(0x28);
  LCD1602_Cmd(0x08);
  LCD1602_Cmd(0x01); /* 清屏 */
  LCD1602_Cmd(0x06);
  LCD1602_Cmd(0x0f);
  delay_ms(2);
  //LCD1602_Cmd(0x06); /* 写入数据光标右移,写入新数据显示屏不移动 */
  //LCD1602_Cmd(0x0C); /* 开显示,有光标,光标闪烁 */
/* 0x80和0xC0分别是两行的开始地址,将字符的序号加上行的地
   址作为命令发送给LCD1602会让下一个字符输出在指定的位置  */
/******发送地址******/
void LCD1602_SetCursor(uint8_t x, uint8_t y) // x:列坐标 y:行坐标
  LCD1602_Cmd(x + (y ? LINE1:LINE0));
/******连续发送数据******/
  LCD1602_SetCursor(x, y);
  while(*str != '\0')
    LCD1602_Data(*str++);
ID:517951 发表于 2022-1-3 13:24 | 只看该作者
发下乱码显示照片, 注意一下上电复位时序,还有发送数据的速度。lcd1602是慢速器件,不能太快。
另外论坛里有PCF8574驱动LCD1602的例程,你可以参照他们的程序来,也是采用4线驱动方式做的。
ID:543220 发表于 2022-1-5 14:27 | 只看该作者
另外论坛 ...
感谢  , 已经解决与了 ,由于用的是ST_LINK仿真, 虽然程序初始化  有显示清空的程序, 但还是不行, 需要重新上电。  所以 不重新上电会导致乱码  , 还是得感谢你
