查看: 2336|回复: 3
STC8a8k64S4A12怎么实现流水呼吸灯?只有呼吸灯的PWM代码
ID:997537 发表于 2021-12-27 18:41 | 显示全部楼层 |阅读模式
STC8a8k64S4A12怎么实现流水呼吸灯?只有呼吸灯的PWM代码,现在想实现8个灯呈现波浪式的起伏,也算是流水呼吸灯了
求助大佬们,非常非常感谢!
  1. #include "reg51.h"
  2. #include "intrins.h"
  3. //测试工作频率为11.0592MHz
  4. #define CYCLE           0x1000
  5. sfr     P_SW2       =   0xba;
  6. sfr     PWMCFG      =   0xf1;
  7. sfr     PWMIF       =   0xf6;
  8. sfr     PWMFDCR     =   0xf7;
  9. sfr     PWMCR       =   0xfe;
  10. #define PWMC            (*(unsigned int volatile xdata *)0xfff0)
  11. #define PWMCKS          (*(unsigned char volatile xdata *)0xfff2)
  12. #define TADCP           (*(unsigned int volatile xdata *)0xfff3)
  13. #define PWM0T1          (*(unsigned int volatile xdata *)0xff00)
  14. #define PWM0T2          (*(unsigned int volatile xdata *)0xff02)
  15. #define PWM0CR          (*(unsigned char volatile xdata *)0xff04)
  16. #define PWM0HLD         (*(unsigned char volatile xdata *)0xff05)
  17. #define PWM1T1          (*(unsigned int volatile xdata *)0xff10)
  18. #define PWM1T2          (*(unsigned int volatile xdata *)0xff12)
  19. #define PWM1CR          (*(unsigned char volatile xdata *)0xff14)
  20. #define PWM1HLD         (*(unsigned char volatile xdata *)0xff15)
  21. #define PWM2T1          (*(unsigned int volatile xdata *)0xff20)
  22. #define PWM2T2          (*(unsigned int volatile xdata *)0xff22)
  23. #define PWM2CR          (*(unsigned char volatile xdata *)0xff24)
  24. #define PWM2HLD         (*(unsigned char volatile xdata *)0xff25)
  25. #define PWM3T1          (*(unsigned int volatile xdata *)0xff30)
  26. #define PWM3T2          (*(unsigned int volatile xdata *)0xff32)
  27. #define PWM3CR          (*(unsigned char volatile xdata *)0xff34)
  28. #define PWM3HLD         (*(unsigned char volatile xdata *)0xff35)
  29. #define PWM4T1          (*(unsigned int volatile xdata *)0xff40)
  30. #define PWM4T2          (*(unsigned int volatile xdata *)0xff42)
  31. #define PWM4CR          (*(unsigned char volatile xdata *)0xff44)
  32. #define PWM4HLD         (*(unsigned char volatile xdata *)0xff45)
  33. #define PWM5T1          (*(unsigned int volatile xdata *)0xff50)
  34. #define PWM5T2          (*(unsigned int volatile xdata *)0xff52)
  35. #define PWM5CR          (*(unsigned char volatile xdata *)0xff54)
  36. #define PWM5HLD         (*(unsigned char volatile xdata *)0xff55)
  37. #define PWM6T1          (*(unsigned int volatile xdata *)0xff60)
  38. #define PWM6T2          (*(unsigned int volatile xdata *)0xff62)
  39. #define PWM6CR          (*(unsigned char volatile xdata *)0xff64)
  40. #define PWM6HLD         (*(unsigned char volatile xdata *)0xff65)
  41. #define PWM7T1          (*(unsigned int volatile xdata *)0xff70)
  42. #define PWM7T2          (*(unsigned int volatile xdata *)0xff72)
  43. #define PWM7CR          (*(unsigned char volatile xdata *)0xff74)
  44. #define PWM7HLD         (*(unsigned char volatile xdata *)0xff75)
  45. void PWM_Isr() interrupt 22
  46. {
  47.     static bit dir = 1;
  48.     static int val = 0;
  49.     char store;
  50.     if (PWMCFG & 0x80)
  51.     {
  52.         PWMCFG &= ~0x80;                        //清中断标志
  53.         if (dir)
  54.         {
  55.             val++;
  56.             if (val >= CYCLE) dir = 0;
  57.         }
  58.         else
  59.         {
  60.             val--;
  61.             if (val <= 1) dir = 1;
  62.         }
  63.
  64.         store = P_SW2;
  65.         P_SW2 |= 0x80;
  66.         PWM0T2 = val;
  67.         P_SW2 = store;
  68.     }
  69. }
  70. void main()
  71. {
  72.     P_SW2 = 0x80;
  73.     PWMCKS = 0x00;                              // PWM时钟为系统时钟
  74.     PWMC = CYCLE;                               //设置PWM周期为
  75.     PWM0T1= 0x0000;
  76.     PWM0T2= 0x0001;
  77.     PWM0CR= 0x80;                               //使能PWM0输出
  78.     P_SW2 = 0x00;
  79.     PWMCR = 0xc0;                               //启动PWM模块
  80.     EA = 1;
  81.     while (1);
  82. }
这个代码是定义了一个灯,多个灯定义加上PWM1、2...即可
ID:893997 发表于 2021-12-29 15:37 | 显示全部楼层
呼吸灯函数可以带入口参数,然后采用轮询的方式把每个等赋值给入口参数即可。
ID:488334 发表于 2021-12-29 16:23 | 显示全部楼层
可以不用PWM中断去做。我做过一个呼吸灯产品,思路是:用定时器定时一个1ms的中断,然后根据时间去改变A的PWM占空比,比如20ms改变一次,当A的占空比从0到100%再递减到30%时,你开始递加B的PWM的占空比,当A的占空比0的时候,B的占空比就在30%,类比下去C,D,E等等。我做的不是海浪,不过你可以根据海浪的特性去做。
ID:161164 发表于 2021-12-29 16:58 | 显示全部楼层
手上没有STC8A的单片机
试试这样改
  1. void PWM_Isr() interrupt 22
  2. {
  3.         static char dir[8] = {0, 0, 0, 0, 0, 0, 0, 0};
  4.         static int val[8]= {0, 0, 0, 0, 0, 0, 0, 0};
  5.         static char Enb[8]= {0, 0, 0, 0, 0, 0, 0, 0};
  6.         char store, index;
  7.         static unsigned int delay_on = 0;
  8.         static char delay_on_i = 0;
  9.         if(!delay_on)
  10.         {
  11.                 delay_on = 1500;//~0.5sec
  12.                 if(delay_on_i<8)
  13.                 {
  14.                         Enb[delay_on_i] = 1;
  15.                         delay_on_i++;
  16.                 }
  17.         }else{
  18.                 delay_on--;
  19.         }
  20.     if (PWMCFG & 0x80)
  21.     {
  22.         PWMCFG &= ~0x80;                        //清中断标志
  23.                 for(index = 0;index < 8; index++)
  24.                 {
  25.                         if(Enb[index])
  26.                         {
  27.                                 if (!dir[index])
  28.                                 {
  29.                                         val[index]++;
  30.                                         if (val[index] >= CYCLE) dir[index] = 0;
  31.                                 }
  32.                                 else
  33.                                 {
  34.                                         val[index]--;
  35.                                         if (val[index] <= 1) dir[index] = 1;
  36.                                 }
  37.                         }
  38.                 }
  39.
  40.         store = P_SW2;
  41.         P_SW2 |= 0x80;
  42.         PWM0T2 = val[0];
  43.         PWM1T2 = val[1];
  44.         PWM2T2 = val[2];
  45.         PWM3T2 = val[3];
  46.         PWM4T2 = val[4];
  47.         PWM5T2 = val[5];
  48.         PWM6T2 = val[6];
  49.         PWM7T2 = val[7];
  50.         P_SW2 = store;
  51.     }
  52. }
