查看: 2098|回复: 2
52单片机用12864液晶制作时钟,请大家帮忙看看,感谢error C141: syntax error near ...
ID:986164 发表于 2022-1-9 16:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用keil uvision4编译错误
Build target '时钟'compiling main.c.....\BSP\24C02.H(13): error C141: syntax error near 'date', expected ')'
..\BSP\24C02.H(14): error C129: missing ';' before 'read_byte'
compiling pbdata.c.....\BSP\24C02.H(13): error C141: syntax error near 'date', expected ')'..\BSP\24C02.H(14): error C129: missing ';' before 'read_byte'
compiling 24c02.c.....\BSP\24C02.H(13): error C141: syntax error near 'date', expected ')'..\BSP\24C02.H(14): error C129: missing ';' before 'read_byte'
compiling key.c.....\BSP\24C02.H(13): error C141: syntax error near 'date', expected ')'..\BSP\24C02.H(14): error C129: missing ';' before 'read_byte'
compiling xianshi.c.....\BSP\24C02.H(13): error C141: syntax error near 'date', expected ')'..\BSP\24C02.H(14): error C129: missing ';' before 'read_byte'Target not created
头文件
#ifndef __24C02_H_
#define __24C02_H_
bit write=0;        //写24C02的标志
sbit sda =P2^0;
sbit scl =P2^1;
void delay0();
void start();                                        //开始信号
void stop();                                        //停止
void respons();                                        //应答
void init_24c02();                                //I^2C初始化函数
void write_byte(uchar date);        //写一个字节函数
uchar read_byte();                        //读一个字节函数
void write_add(uchar address,uchar date);        //指定地址写一个字节
void read_add(uchar address);                                //指定地址读一个字节
#endif
函数
#include "pbdata.h"
void delay0()
void start()                //开始信号
        sda=1;
        delay0();
        scl=1;
        delay0();
        sda=0;
        delay0();
void stop()                        //停止
        sda=0;
        delay0();
        scl=1;
        delay0();
        sda=1;
        delay0();
void respons()                //应答
        uchar i;
        scl=1;
        delay0();
        while((sda==1)&&(i<250))
                i++;
        scl=0;
        delay0();
void init_24c02()        //I^2C初始化函数
        sda=1;
        delay0();
        scl=1;
        delay0();
void write_byte(uchar date)                //写一个字节函数
        uchar i,temp;
        temp=date;
        for(i=0;i<8;i++)
                temp=temp<<1;
                scl=0;
                delay0();
                sda=CY;
                delay0();
                scl=1;
                delay0();
        scl=0;
        delay0();
        sda=1;
        delay0();
uchar read_byte()                //读一个字节函数
        uchar i,k;
        scl=0;
        delay0();
        sda=1;
        delay0();
        for(i=0;i<8;i++)
                scl=1;
                delay0();
                k=(k<<1)|sda;
                scl=0;
                delay0();
        return k;
void write_add(uchar address,uchar date)        //指定地址写一个字节
        start();
        write_byte(0xa0);
        respons();
        write_byte(address);
        respons();
        write_byte(date);
        respons();
        stop();
void read_add(uchar address)        //指定地址读一个字节
        uchar date;
        start();
        write_byte(0xa0);
        respons();
        respons();
        start();
        write_byte(0xa1);
        respons();
        date=read_byte();
        stop();
        return date;
ID:68189 发表于 2022-1-10 14:10 | 只看该作者
头文件中的 uchar 没有定义,而报错.在前面定义一下:#define uchar unsigned char
ID:986164 发表于 2022-1-10 15:02 | 只看该作者
好的,知道了,感谢
