查看: 1357|回复: 2
关于单片机开发板点阵动画用定时器显示有闪烁的问题
ID:1002235 发表于 2022-1-16 23:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我抄了uid:164602大侠的一个ES2.0开发板点阵动画,我将他改成用定时器显示后,画面有严重的闪烁及重影,请高手帮我看看,我的代码哪里有问题?
普中科技ES2.0单片机源程序如下:
#include<reg51.h>
#include<intrins.h>
sbit SRCLK=P3^6;
sbit RCLK=P3^5;
sbit SER=P3^4;
sbit P10=P1^0;
#define LKZ P0
unsigned char code TAB[8]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
unsigned char code XS[17][8]=
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*以下是箭头向左移动*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10},
{0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x38},
{0x00,0x00,0x00,0x00,0x00,0x10,0x38,0x38},
{0x00,0x00,0x00,0x00,0x10,0x38,0x38,0x54},
{0x00,0x00,0x00,0x10,0x38,0x38,0x54,0x10},
{0x00,0x00,0x10,0x38,0x38,0x54,0x10,0x10},
{0x00,0x10,0x38,0x38,0x54,0x10,0x10,0x10},
{0x10,0x38,0x38,0x54,0x10,0x10,0x10,0x10},
{0x38,0x38,0x54,0x10,0x10,0x10,0x10,0x00},
{0x38,0x54,0x10,0x10,0x10,0x10,0x00,0x00},
{0x54,0x10,0x10,0x10,0x10,0x00,0x00,0x00},
{0x10,0x10,0x10,0x10,0x00,0x00,0x00,0x00},
{0x10,0x10,0x10,0x00,0x00,0x00,0x00,0x00},
{0x10,0x10,0x00,0x00,0x00,0x00,0x00,0x00},
{0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
unsigned int Times;        //为定时器计数,初值为100,产生一个1s的定时
unsigned char i,j,k;
void XP74HC595(unsigned char dat)//向74H595发送一个字节的数据
        //函数名必须由字母开始
        unsigned char a;
        SRCLK=0;
        RCLK=0;
        for(a=0;a<8;a++)
                if ((dat<<a)&0x80)//从高位开始发送数据
                        SER=1;
                        SER=0;
                SRCLK=1;
                _nop_();
                _nop_();
                SRCLK=0;
        RCLK=1;
        _nop_();
        _nop_();
        RCLK=0;
void DispConfig() {
        i=0;j=0;k=0;
void TimerConfig()
    Times = 1000;
        TMOD = 0x00; //选择工作方式0
    TH0 = 0x18;         //设置初始值
    TL0 = 0x0fc;
    EA = 1;                         //打开总中断
    ET0 = 1;                 //打开定时器0中断
    TR0 = 1;                 //启动定时器0
void Proc_1S(){
//        P10=!P10;
void Proc_Disp_1ms(){
        LKZ=0xff;
        XP74HC595(0x00);
        XP74HC595(XS[ i][j]);[ i]
        LKZ=TAB[j];
        if (j<8) {
                j++;
        } else {
                j=0;
                if (k<50) {
                        k++;
                } else {
                        k=0;
                        if (i<17) {
                                i++;
                        } else {
                                i=0;
void Timer0() interrupt 1
        Times--;
                if (Times==0){
                        Times=1000;
                        Proc_1S();
                } else {
                        Proc_Disp_1ms();
void main ()
        TimerConfig();
                DispConfig();
        while (1)
ID:161164 发表于 2022-1-17 10:15 | 只看该作者
  1. void TimerConfig()
  2. {
  3.     Times = 1000;
  4.     TMOD = 0x01; //选择工作方式1//<<<<<<<<<<<<<<<<<<<<<TH, TL 的值是16位定时器用的
  5.     TL0 = 0x18;         //设置初始值//<<<<<<<<<<<<<<<<<<<<TH, TL 的值掉转了
  6.     TH0 = 0xfc;//<<<<<<<<<<<<<<<<<<<<TH, TL 的值掉转了
  7.     EA = 1;                         //打开总中断
  8.     ET0 = 1;                 //打开定时器0中断
  9.     TR0 = 1;                 //启动定时器0
  10. }
  11. void Proc_1S() {
  12. //        P10=!P10;
  13. }
  14. void Proc_Disp_1ms() {
  15.     LKZ = 0xff;
  16. //        XP74HC595(0x00);//<<<<<<<<<<<<<<<<<<<<595无需清零
  17.     XP74HC595(XS[ i][j]);//[ i]
  18.     LKZ = TAB[j];
  19.     if (j < 7) { //<<<<<<<<<<<<<<<<<<<<小于8,下个循环就会出现XS[ i][8]和TAB[8]
  20.         j++;
  21.     } else {
  22.         j = 0;
  23.         if (k < 50) {
  24.             k++;
  25.         } else {
  26.             k = 0;
  27.             if (i < 16) { //<<<<<<<<<<<<<<<<<<<<小于17,下个循环就会出现XS[17][8]
  28.                 i++;
  29.             } else {
  30.                 i = 0;
  31.             }
  32.         }
  33.     }
  34. }
  35. void Timer0() interrupt 1
  36. {
  37.     TL0 = 0x18;         //设置初始值//<<<<<<<<<<<<<<<<<<<<工作方式1要手动重装
  38.     TH0 = 0xfc;//<<<<<<<<<<<<<<<<<<<<
  39.     Times--;
  40.     if (Times == 0) {
  41.         Times = 1000;
  42.         Proc_1S();
  43.     } else {
  44.         Proc_Disp_1ms();
  45.     }
  46. }
ID:752974 发表于 2022-1-17 11:29 | 只看该作者
显示屏刷新速度慢就有闪烁。
