查看: 1430|回复: 1
求教单片机点阵LED程序问题
ID:1005226 发表于 2022-2-23 23:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请问大佬们,做点阵led流动字体精确延时移动时,无意间发现设置变量flag1s 与TF0下延时时间不相同,不太明白,求教各位啦
用TF0时
#include <reg52.h>
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
unsigned char code image[]={
        0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
        0x7D,0x01,0x01,0x7D,0xFF,0xFF,0xE3,0xC1,
        0x81,0x03,0x03,0x81,0xC1,0xE3,0xFF,0xFF,
        0x81,0x01,0x3F,0x3F,0x3F,0x01,0x81,0xFF,
        0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF};
        ENLED = 0;
        ADDR3 = 0;
        EA = 1;
        TMOD = 0x01;
        TH0 = 0xFC;
        TL0 = 0x67;
        TR0 = 1;
        ET0 = 1;
                if(TF0 == 1)
                TF0 =0;
void interrupttime0() interrupt 1
        static unsigned char index = 0;
        static unsigned char i = 0;
        static unsigned int tmr = 0;
        TH0 = 0xFC;
        TL0 = 0x67;
        P0 = 0xFF;
        switch(i)
                case 0:ADDR2 = 0;ADDR1 = 0;ADDR0 = 0;i++;P0=image[index+0];break;
                case 1:ADDR2 = 0;ADDR1 = 0;ADDR0 = 1;i++;P0=image[index+1];break;
                case 2:ADDR2 = 0;ADDR1 = 1;ADDR0 = 0;i++;P0=image[index+2];break;
                case 3:ADDR2 = 0;ADDR1 = 1;ADDR0 = 1;i++;P0=image[index+3];break;
                case 4:ADDR2 = 1;ADDR1 = 0;ADDR0 = 0;i++;P0=image[index+4];break;
                case 5:ADDR2 = 1;ADDR1 = 0;ADDR0 = 1;i++;P0=image[index+5];break;
                case 6:ADDR2 = 1;ADDR1 = 1;ADDR0 = 0;i++;P0=image[index+6];break;
                case 7:ADDR2 = 1;ADDR1 = 1;ADDR0 = 1;i=0;P0=image[index+7];break;
        if(TF0 == 0)
                TF0 =1;
                tmr++ ;
                if(tmr>=1000)
                        tmr =0;
                index ++;
                if(index >=32)
                        index = 0;
控制flag1s条件时
#include <reg52.h>
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
unsigned char flag1s = 0;
        ENLED = 0;
        ADDR3 = 0;
        EA = 1;
        TMOD = 0x01;
        TH0 = 0xFC;
        TL0 = 0x67;
        TR0 = 1;
        ET0 = 1;
                if(flag1s == 1)
                flag1s =0;
        TH0 = 0xFC;
        TL0 = 0x67;
        P0 = 0xFF;
        switch(i)
        if(flag1s == 0)
                flag1s =1;
                tmr++ ;
                if(tmr>=1000)
                        tmr =0;
                index ++;
                if(index >=32)
                        index = 0;
ID:213173 发表于 2022-2-24 07:35 | 只看该作者
两种定时方式的基本架构
  1. //查询方式
  2. void main()
  3. {
  4.         TMOD = 0x01;
  5.         TH0 = 0xFC;
  6.         TL0 = 0x67;
  7.         TR0 = 1;
  8.         while(1)
  9.         {
  10.                 if(TF0 == 1)//查询
  11.                 {
  12.                         TF0 =0;//需要软件复位
  13.                         TH0 = 0xFC;
  14.                         TL0 = 0x67;
  15.                         //需要定时的任务
  16.                 }
  17.                 //其它任务
  18.         }
  19. }
  20. //中断方式
  21. void main()
  22. {
  23.         EA = 1;
  24.         TMOD = 0x01;
  25.         TH0 = 0xFC;
  26.         TL0 = 0x67;
  27.         TR0 = 1;
  28.         ET0 = 1;
  29.         while(1)
  30.         {
  31.                 //其他任务
  32.         }
  33. }
  34.
  35. void interrupttime0() interrupt 1
  36. {
  37.   //TF0由内部硬件自动复位
  38.         TH0 = 0xFC;
  39.         TL0 = 0x67;
  40.         //需要定时的任务
  41. }
