查看: 2093|回复: 2
NRF24L01使用问题 附单片机代码
ID:985217 发表于 2022-3-9 21:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
NRF24L01使用出了问题,但找不到原因,发此帖向各位前辈请教一下
需求:采用NRF24L01作无线传输,接收端接收到特定数组,蜂鸣器就会响,当接收到数组不为此数组时,蜂鸣器关闭
问题:接收端不能正常工作
部分代码如下:
(一)NRF24L01配置
  1. #include "bsp_spi_nrf.h"
  2. u8 RX_BUF[RX_PLOAD_WIDTH];                //接收数据缓存
  3. u8 TX_BUF[TX_PLOAD_WIDTH];                //发射数据缓存
  4. u8 TX_ADDRESS[TX_ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01};  // 定义一个静态发送地址
  5. u8 RX_ADDRESS[RX_ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01};
  6. void Delay(__IO u32 nCount)
  7. {
  8.   for(; nCount != 0; nCount--);
  9. }
  10. /*------------------------------------------------------------SPI的 I/O配置-------------------------------------------------------------------*/
  11. void SPI_NRF_Init(void)
  12. {
  13.   SPI_InitTypeDef  SPI_InitStructure;
  14.   GPIO_InitTypeDef GPIO_InitStructure;
  15.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA
  16.                          |NRF_CSN_GPIO_CLK
  17.                          |NRF_CE_GPIO_CLK
  18.                          |NRF_IRQ_GPIO_CLK,ENABLE);
  19.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
  20.   /*SCK,MISO,MOSI引脚(PA5,PA6,PA7)*/
  21.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  22.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  23.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用功能
  24.   GPIO_Init(GPIOA, &GPIO_InitStructure);
  25.   /*CSN引脚*/
  26.   GPIO_InitStructure.GPIO_Pin = NRF_CSN_PIN;
  27.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  28.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  29.   GPIO_Init(NRF_CSN_GPIO_PORT, &GPIO_InitStructure);
  30.   /*CE引脚*/
  31.   GPIO_InitStructure.GPIO_Pin = NRF_CE_PIN;
  32.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  33.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  34.   GPIO_Init(NRF_CE_GPIO_PORT, &GPIO_InitStructure);
  35.   /*IRQ引脚*/
  36.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
  37.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  38.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU ;  //上拉输入
  39.   GPIO_Init(NRF_IRQ_GPIO_PORT, &GPIO_InitStructure);
  40.
  41.   NRF_CSN_HIGH(); //拉高csn引脚,NRF进入空闲状态
  42.   /*配置SPI*/
  43.   SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;           //双线全双工
  44.   SPI_InitStructure.SPI_Mode = SPI_Mode_Master;                                                            //主模式
  45.   SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;                                                    //数据大小8位
  46.   SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;                                                        //时钟极性,空闲时为低
  47.   SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;                                                           //第1个边沿有效,上升沿为采样时刻
  48.   SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;        //NSS信号由软件产生
  49.   SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8;           //8分频,9MHz
  50.   SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;                                             //高位在前
  51.   SPI_InitStructure.SPI_CRCPolynomial = 7;
  52.   SPI_Init(SPI1, &SPI_InitStructure);
  53.   SPI_Cmd(SPI1, ENABLE);//使能SPI
  54. }
  55. /*----------------------------------------------------向NRF读/写一字节数据--------------------------------------------------------------*/
  56. u8 SPI_NRF_RW(u8 dat)
  57. {
  58.   while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);     //当SPI发送缓冲器非空时等待
  59.   SPI_I2S_SendData(SPI1, dat);                                                  //通过SPI发送一字节数据
  60.   while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);    //当SPI接收缓冲器为空时等待
  61.   return SPI_I2S_ReceiveData(SPI1);                                   //返回从SPI接收到的数据
  62. }
  63. /*---------------------------------------------------向NRF特定的寄存器写入数据----------------------------------------------------------------*/
  64. //reg:NRF的命令+寄存器地址\
  65.   dat:将要向寄存器写入的数据\
  66. status:NRF的status寄存器的状态
  67. u8 SPI_NRF_WriteReg(u8 reg,u8 dat)
  68. {
  69.          u8 status;
  70.         NRF_CE_LOW();
  71.     NRF_CSN_LOW();                       //置低CSN,使能SPI传输
  72.         status = SPI_NRF_RW(reg);      //发送命令及寄存器号
  73.     SPI_NRF_RW(dat);               //向寄存器写入数据
  74.           NRF_CSN_HIGH();                       //CSN拉高,完成
  75.         return(status);                //返回状态寄存器的值
  76. }
  77. /*--------------------------------------------------从NRF特定的寄存器读出数据-----------------------------------------------------------------*/
  78. //reg:NRF的命令+寄存器地址\
  79.   reg_val:寄存器中的数据
  80. u8 SPI_NRF_ReadReg(u8 reg)
  81. {
  82.          u8 reg_val;
  83.         NRF_CE_LOW();
  84.          NRF_CSN_LOW();                        //置低CSN,使能SPI传输
  85.         SPI_NRF_RW(reg);                //发送寄存器号
  86.     reg_val = SPI_NRF_RW(NOP);      //读取寄存器的值
  87.         NRF_CSN_HIGH();                            //CSN拉高,完成
  88.
  89.         return reg_val;
  90. }
  91. /*------------------------------------------------------向NRF的寄存器中写入一串数据----------------------------------------------------------*/
  92. //reg : NRF的命令+寄存器地址\
  93.   pBuf:用于存储将被读出的寄存器数据的数组,外部定义\
  94.   bytes: pBuf的数据长度\
  95.   status:NRF的status寄存器的状态\
  96. u8 SPI_NRF_ReadBuf(u8 reg,u8 *pBuf,u8 bytes)
  97. {
  98.          u8 status, byte_cnt;
  99.         NRF_CE_LOW();
  100.         NRF_CSN_LOW();                                   //置低CSN,使能SPI传输
  101.
  102.
  103.         status = SPI_NRF_RW(reg);                        //发送寄存器号
  104.     for(byte_cnt=0;byte_cnt<bytes;byte_cnt++)                 //读取缓冲区数据
  105.            pBuf[byte_cnt] = SPI_NRF_RW(NOP);
  106.         NRF_CSN_HIGH();                                         //CSN拉高,完成
  107.
  108.          return status;                                             //返回寄存器状态值
  109. }
  110. /*-----------------------------------------------------向NRF的寄存器中写入一串数据-------------------------------------------------------------*/
  111. //reg : NRF的命令+寄存器地址\
  112.   pBuf:存储了将要写入写寄存器数据的数组,外部定义\
  113.   bytes: pBuf的数据长度\
  114.   status: NRF的status寄存器的状态
  115. u8 SPI_NRF_WriteBuf(u8 reg ,u8 *pBuf,u8 bytes)
  116. {
  117.          u8 status,byte_cnt;
  118.          NRF_CE_LOW();
  119.          NRF_CSN_LOW();                                              //置低CSN,使能SPI传输
  120.            status = SPI_NRF_RW(reg);                    //发送寄存器号
  121.           for(byte_cnt=0;byte_cnt<bytes;byte_cnt++)    //向缓冲区写入数据
  122.                 SPI_NRF_RW(*pBuf++);
  123.
  124.         NRF_CSN_HIGH();                                              //CSN拉高,完成
  125.           return (status);                                  //返回NRF24L01的状态
  126. }
  127. /*----------------------------------------------------------配置并进入接收模式-------------------------------------------------------------*/
  128. void NRF_RX_Mode(void)
  129. {
  130.    NRF_CE_LOW();
  131.    SPI_NRF_WriteBuf(NRF_WRITE_REG+RX_ADDR_P0,RX_ADDRESS,RX_ADR_WIDTH);//写RX节点地址
  132.    SPI_NRF_WriteReg(NRF_WRITE_REG+EN_AA,0x01);                        //使能通道0的自动应答
  133.    SPI_NRF_WriteReg(NRF_WRITE_REG+EN_RXADDR,0x01);                    //使能通道0的接收地址
  134.    SPI_NRF_WriteReg(NRF_WRITE_REG+RF_CH,CHANAL);                      //设置RF通信频率
  135.    SPI_NRF_WriteReg(NRF_WRITE_REG+RX_PW_P0,RX_PLOAD_WIDTH);           //选择通道0的有效数据宽度
  136.    SPI_NRF_WriteReg(NRF_WRITE_REG+RF_SETUP,0x0f);                     //设置TX发射参数,0db增益,2Mbps,低噪声增益开启
  137.    SPI_NRF_WriteReg(NRF_WRITE_REG+CONFIG, 0x0f);                      //配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,接收模式
  138.    NRF_CE_HIGH();          //CE拉高,进入接收模式
  139. }
  140. /*----------------------------------------------------------配置发送模式-----------------------------------------------------------*/
  141. void NRF_TX_Mode(void)
  142. {
  143.    NRF_CE_LOW();
  144.    SPI_NRF_WriteBuf(NRF_WRITE_REG+TX_ADDR,TX_ADDRESS,TX_ADR_WIDTH);    //写TX节点地址
  145.    SPI_NRF_WriteBuf(NRF_WRITE_REG+RX_ADDR_P0,RX_ADDRESS,RX_ADR_WIDTH); //设置TX节点地址,主要为了使能ACK
  146.    SPI_NRF_WriteReg(NRF_WRITE_REG+EN_AA,0x01);                         //使能通道0的自动应答
  147.    SPI_NRF_WriteReg(NRF_WRITE_REG+EN_RXADDR,0x01);                     //使能通道0的接收地址
  148.    SPI_NRF_WriteReg(NRF_WRITE_REG+SETUP_RETR,0x1a);                    //设置自动重发间隔时间:500us + 86us;最大自动重发次数:10次
  149.    SPI_NRF_WriteReg(NRF_WRITE_REG+RF_CH,CHANAL);                       //设置RF通道为CHANAL
  150.    SPI_NRF_WriteReg(NRF_WRITE_REG+RF_SETUP,0x0f);                      //设置TX发射参数,0db增益,2Mbps,低噪声增益开启
  151.    SPI_NRF_WriteReg(NRF_WRITE_REG+CONFIG,0x0e);                        //配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,发射模式,开启所有中断
  152.    NRF_CE_HIGH();  //CE拉高,进入发送模式
  153.    Delay(0xffff); //CE要拉高一段时间才进入发送模式
  154. }
  155. /*---------------------------------------------------------主要用于NRF与MCU是否正常连接--------------------------------------------------------*/
  156. //retval: SUCCESS/ERROR 连接正常/连接失败
  157. u8 NRF_Check(void)
  158. {
  159.         u8 buf[5]={0xC2,0xC2,0xC2,0xC2,0xC2};
  160.         u8 buf1[5];
  161.         u8 i;
  162.
  163.
  164.         SPI_NRF_WriteBuf(NRF_WRITE_REG+TX_ADDR,buf,5);//写入5个字节的地址
  165.         SPI_NRF_ReadBuf(TX_ADDR,buf1,5);              //读出写入的地址
  166.         for(i=0;i<5;i++)                              //判断是否连接成功
  167.         {
  168.                 if(buf1[i]!=0xC2)
  169.                 break;
  170.         }
  171.         if(i==5)
  172.                 return SUCCESS ;        //MCU与NRF成功连接
  173.         else
  174.                 return ERROR ;        //MCU与NRF不正常连接
  175. }
  176. /*-----------------------------------------------------向NRF的发送缓冲区中写入数据--------------------------------------------------------------*/
  177. //txBuf:存储了将要发送的数据的数组,外部定义\
  178.   retval: 发送结果,成功返回TXDS,失败返回MAXRT或ERROR
  179. u8 NRF_Tx_Dat(u8 *txbuf)
  180. {
  181.         u8 state;
  182.         NRF_CE_LOW();                                           //CE为低,进入待机模式1
  183.     SPI_NRF_WriteBuf(WR_TX_PLOAD,txbuf,TX_PLOAD_WIDTH);//写数据到TX BUF 最大 32个字节
  184.          NRF_CE_HIGH();                                     //CE为高,txbuf非空,发送数据包
  185.
  186.         while(NRF_Read_IRQ()!=0);                                //等待发送完成中断
  187.         state = SPI_NRF_ReadReg(STATUS);                   //读取状态寄存器的值
  188.     SPI_NRF_WriteReg(NRF_WRITE_REG+STATUS,state);            //清除TX_DS或MAX_RT中断标志
  189.     SPI_NRF_WriteReg(FLUSH_RX,NOP);                    //清除TX FIFO寄存器
  190.          /*判断中断类型*/
  191.         if(state&MAX_RT)                     //达到最大重发次数
  192.                          return MAX_RT;
  193.         else if(state&TX_DS)                 //发送完成
  194.                          return TX_DS;
  195.          else
  196.                         return ERROR;                //其他原因发送失败
  197. }
  198. /*--------------------------------------------------------从NRF的接收缓冲区中读出数据------------------------------------------------------------*/
  199. //rxBuf :用于接收该数据的数组,外部定义\
  200.   retval: 接收结果
  201. u8 NRF_Rx_Dat(u8 *rxbuf)
  202. {
  203.         u8 state;
  204.         NRF_CE_HIGH();         //进入接收状态
  205.          /*轮询标志*/
  206.         while(NRF_Read_IRQ()==0)
  207.   {
  208.     NRF_CE_LOW();                                               //进入待机状态
  209.     state=SPI_NRF_ReadReg(NRF_READ_REG+STATUS);          //读取status寄存器的值
  210.     SPI_NRF_WriteReg(NRF_WRITE_REG+STATUS,state);        //清除中断标志
  211.     /*判断是否接收到数据*/
  212.     if(state&RX_DR)                                      //接收到数据
  213.     {
  214.       SPI_NRF_ReadBuf(RD_RX_PLOAD,rxbuf,RX_PLOAD_WIDTH); //读取数据
  215.       SPI_NRF_WriteReg(FLUSH_RX,NOP);                    //清除RX FIFO寄存器
  216.       return RX_DR;
  217.     }
  218.     else
  219.       return ERROR;                    //没收到任何数据
  220.   }
  221.   return ERROR;                    //没收到任何数据
  222. }
  223. void Beep_ON(void)
  224. {
  225.         GPIO_InitTypeDef  GPIO_InitBeep;
  226.
  227.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE);
  228.
  229.         GPIO_InitBeep.GPIO_Mode=GPIO_Mode_Out_PP;
  230.         GPIO_InitBeep.GPIO_Pin=GPIO_Pin_0;
  231.         GPIO_InitBeep.GPIO_Speed=GPIO_Speed_50MHz;
  232.         GPIO_Init(GPIOC,&GPIO_InitBeep);
  233.
  234.         GPIO_SetBits(GPIOC, GPIO_Pin_0);
  235. }
  236. void Beep_OFF(void)
  237. {
  238.         GPIO_InitTypeDef  GPIO_InitBeep;
  239.
  240.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE);
  241.
  242.         GPIO_InitBeep.GPIO_Mode=GPIO_Mode_Out_PP;
  243.         GPIO_InitBeep.GPIO_Pin=GPIO_Pin_0;
  244.         GPIO_InitBeep.GPIO_Speed=GPIO_Speed_50MHz;
  245.         GPIO_Init(GPIOC,&GPIO_InitBeep);
  246.
  247.         GPIO_ResetBits(GPIOC, GPIO_Pin_0);
  248. }
  249. (二)接收端main.c部分代码
  250. int compare(u8 x[],u8 y[])
  251. {
  252.     int a=0;
  253.     for(i=0;i<32;i++)
  254.     {
  255.         if(x[i]==y[i])
  256.             a++;
  257.     }
  258.     if(a==32)
  259.         return 1;
  260.     else
  261.         return 0;
  262. }
  263. void main(void)
  264. {
  265.     int ans=0;
  266.     SPI_NRF_Init();
  267.     LED_GPIO_Config();
  268.     NRF_RX_Mode();
  269.     for(i=0;i<32;i++)
  270.        mishi[i]=i;
  271.     while(1)
  272.     {
  273.         status=NRF_Rx_Dat(rxbuf);
  274.         if(status==RX_DR)
  275.             ans=compare(rxbuf,mishi);
  276.         if(ans==1)
  277.             Beep_ON();
  278.         else
  279.             Beep_OFF();
  280.     }
  281. //    LED_RGB('R');
  282. }
  283. (三)发射端部分代码
  284. SPI_NRF_Init();
  285. NRF_TX_Mode();
  286. if (count>57600)
  287.     {
  288.         //Beep_ON();
  289.         NRF_Tx_Dat(mishi);
  290.     }
  291.     else NRF_Tx_Dat(errorbuf);
收藏收藏2 分享淘帖 顶顶 踩踩
ID:45879 发表于 2022-3-10 09:32 | 只看该作者
排查思路:
1.检查SPI读写功能
2.检查双方的地址,配置模式等等
3.接收方尝试通过串口打印信息
ID:115923 发表于 2022-3-26 21:51 | 只看该作者
接收 建议用 中断, 你这样 接收程序要改一下。 要么你 在while里面加一个延时50ms试一试。
发送程序基本没有问题。如果间隔发送时间在50ms以上。
