查看: 2989|回复: 1
P3.75单红64X16半板点阵屏 STC8A单片机驱动
本程序来自http://www.51hei.com/bbs/dpj-205333-1.html更改,驱动P3.75单红64X16。测试了下驱动9块板,sta8a选RC22.018MHz,刷新整屏都在98HZ
实物图如下:
  1. //LED屏控制程序   本程序驱动32*64LED彩色屏
  2. #include <stc15f2k60s2.H>
  3. #include<uart.h>
  4. //#include "common.h"
  5. #include <intrins.h>
  6. #define u8 unsigned        char
  7. #define u16         unsigned int
  8. #define NOP     _nop_()
  9. char Key_Read();
  10. //第1组
  11. //LED端口 共16根,其中3根为GND
  12. sbit XOE     = P1^0;       //传数允许
  13. sbit XSHCP=P1^1;           //S   时钟
  14. sbit XSTCP=P1^2;           //L   锁存输出
  15. sbit XA1     = P1^3;       //A  由138控制的扫描行  共16行
  16. sbit XB1     = P1^4;       //B
  17. sbit XC1     = P1^5;       //C
  18. sbit XD1     = P1^6;       //D
  19. sbit SR1DATA=P1^7;          //数据1  红色
  20. //大字体
  21. u8 code dz1[4][128]={
  22. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x00,0x00,0x00,0x3C,
  23. ***********
  24. u8 code kuaile[]={
  25.
  26. 0x18,0x06,0x18,0x06,0x18,0x06,0xD8,0x3F,0x38,0x36,0x7E,0x36,0x1E,0x36,0x1E,0x36,
  27. 0xFB,0xFF,0x18,0x06,0x18,0x0F,0x18,0x0F,0x98,0x19,0x98,0x19,0xD8,0x30,0x78,0xE0, //快0
  28. 0x00,0x0C,0x00,0x1F,0xF8,0x01,0x18,0x00,0x98,0x01,0x8C,0x01,0x8C,0x01,0xFC,0x7F,
  29. 0x80,0x01,0xB0,0x0D,0xB0,0x19,0x98,0x31,0x8C,0x61,0x86,0x61,0xE0,0x01,0xC0,0x00  //乐1
  30. };
  31.
  32.
  33.
  34.
  35. //第1组上下半部分数据传送  红 1 绿 2 蓝
  36. void shuju_input1(u8 sdat1)    //参数为上半部数据 下半部数据 显示颜色
  37. {
  38.   u8 m;
  39.    sdat1=~sdat1;
  40.   for(m=0;m<8;m++)         //8位数据传送
  41.    {
  42.     if(sdat1 & 0x80)        //判断最高位  上半部数据
  43.                 {
  44.
  45.        SR1DATA=1;
  46.      }
  47.     else
  48.                 {
  49.
  50.
  51.        SR1DATA=0;
  52.
  53.
  54.      }
  55.
  56.
  57.     XSHCP=0;
  58.     XSHCP=1;
  59.     NOP;
  60.     NOP;
  61.     XSHCP=0;
  62.     NOP;
  63.     NOP;
  64.     sdat1=sdat1<<1;
  65.          }
  66. }
  67. /*******************************************************************************************/
  68. void serial_output()
  69. {
  70.     XSTCP=1;
  71.     NOP;
  72.     XSTCP=0;
  73. }
  74. void HC138_scan(u8 temp)
  75. {
  76.          XOE=0;
  77.    XA1=0x01 & temp;
  78.    XB1=0x01 &(temp>>1);
  79.          XC1=0x01 &(temp>>2);
  80.          XD1=0x01 &(temp>>3);
  81. }
  82. //显示  每一单元板为32*64,能够显示二行汉字,每行四字(字模为顺向,逐行式,阴码的算法)
  83. void display(u8 *p)                //4字的首地址
  84. {
  85.   u8 qx=0,qxdata=0,qd=1;//奇数倍
  86.   u16 j=0,k;
  87.   for(k=0;k<16;k++)                  //16行 控制扫描行
  88.    {
  89.     for(j=1;j<5;j++)                //共取8个字符高16X8,4个大字一个字是16X16
  90.     {
  91.     shuju_input1(*(p+(j-1)*32+k));                                      //取上下半汉字的第1个字节
  92. ////////////////////////////////////////////////////////////////////////////////
  93.              qxdata=0;
  94.                  qx=0;
  95.              while(qd)
  96.                  {
  97.                  qxdata++;
  98.                  if(qxdata%2){qx++;}
  99.                  if(qx==j)qd=0;
  100.                  }
  101.                  qd=1;
  102. ////////////////////////////////////////////////////////////////生成1 3 5 7 9 11
  103.         shuju_input1(*(p+(qxdata*16)+k));                                  //取上下半汉字的第2个字节
  104.         }
  105.    XOE=1;
  106.    serial_output();                //允许输出控制
  107.    HC138_scan(k);                  //对应行
  108.   }
  109. }
  110. void main()
  111. {
  112. UartInit(); //串口1初始化        //9600bps@11.0592MHz
  113.   UART1_fs(0x88);
  114.   while(1)
  115.    {
  116.    if(dyjs_1){
  117.          dyjs_1=0;
  118.              UART1_fs(0x99);
  119.              }
  120.          display(dzx4);    //1个单元控制
  121. //                 display1(dzx1,dzx2);   //1个单元控制
  122. //                   display2(dz2);
  123. //                   display3(dz1);
  124.     }
  125. }
Keil代码下载:
p3.75单红半板.zip (58.04 KB, 下载次数: 32)
ID:373 发表于 2022-12-19 14:43 | 只看该作者
还没有做过,不知道能不能讲解一下驱动思路
