查看: 4022|回复: 1
RISC-V单片机CH32V103的ADC多路采样例程 MounRiver工程文件
使用某1个宝上入手的CH32V103c8t6核心板,用面包板搭建硬件环境。实现了PA0、PA1、PA2和PA7四路模拟量的ADC采样,结果显示在i2c接口的0.91吋oled上,例程见附件。
制作出来的实物图如下:
  1. /*********************** ADC_00 *************************************************
  2. * @工程名称:ADC_00
  3. * @说明:ADC规则通道采样,使用DMA功能,四路模拟量输入采集。
  4. *
  5. *
  6. *******************************************************************************/
  7. #include "debug.h"
  8. #include "codeTab.h"
  9. #include "oled_i2c.h"
  10. /* Global typedef */
  11. /* Global define */
  12. /* Global Variable */
  13. u16 TxBuf[1024];
  14. s16 Calibrattion_Val = 0;
  15. /*********************************************************************
  16. * @fn      ADC_Function_Init
  17. *
  18. * @brief   Initializes ADC collection.
  19. *
  20. * @return  none
  21. */
  22. /*******************************************************************************
  23. * Function Name  : ADC_Function_Init
  24. * Description    : Initializes ADC collection.
  25. * Input          : None
  26. * Return         : None
  27. *******************************************************************************/
  28. void ADC_Function_Init(void)
  29. {
  30.     ADC_InitTypeDef ADC_InitStructure;
  31.     GPIO_InitTypeDef GPIO_InitStructure;
  32.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE );
  33.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE );
  34.     RCC_ADCCLKConfig(RCC_PCLK2_Div8);
  35.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_7;
  36.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  37.     GPIO_Init(GPIOA, &GPIO_InitStructure);
  38.     ADC_DeInit(ADC1);
  39.     ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  40.     ADC_InitStructure.ADC_ScanConvMode = DISABLE;
  41.     ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  42.     ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
  43.     ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  44.     ADC_InitStructure.ADC_NbrOfChannel = 1;
  45.     ADC_Init(ADC1, &ADC_InitStructure);
  46.     ADC_DMACmd(ADC1, ENABLE);
  47.     ADC_Cmd(ADC1, ENABLE);
  48.     ADC_ResetCalibration(ADC1);
  49.     while(ADC_GetResetCalibrationStatus(ADC1));
  50.     ADC_StartCalibration(ADC1);
  51.     while(ADC_GetCalibrationStatus(ADC1));
  52. }
  53. u16 Get_ADC_Val(u8 ch)
  54. {
  55.   u16 val;
  56.     ADC_SoftwareStartConvCmd(ADC1, ENABLE);
  57.     while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC ));
  58.     val = ADC_GetConversionValue(ADC1);
  59.     return val;
  60. }
  61. u16 Get_ADC_Average(u16 *buf,u8 times)
  62. {
  63.     u32 temp_val = 0;
  64.     u8 t;
  65.     u16 val;
  66.     for(t=0;t<times;t++)
  67.     {
  68.         temp_val += buf[t];
  69.     }
  70.     val = temp_val/times;
  71.     return val;
  72. }
  73. /*********************************************************************
  74. * @fn      DMA_Tx_Init
  75. *
  76. * @brief   Initializes the DMAy Channelx configuration.
  77. *
  78. * @param   DMA_CHx - x can be 1 to 7.
  79. *          ppadr - Peripheral base address.
  80. *          memadr - Memory base address.
  81. *          bufsize - DMA channel buffer size.
  82. *
  83. * @return  none
  84. */
  85. void DMA_Tx_Init( DMA_Channel_TypeDef* DMA_CHx, u32 ppadr, u32 memadr, u16 bufsize)
  86. {
  87.     DMA_InitTypeDef DMA_InitStructure;
  88.     RCC_AHBPeriphClockCmd( RCC_AHBPeriph_DMA1, ENABLE );
  89.     DMA_DeInit(DMA_CHx);
  90.     DMA_InitStructure.DMA_PeripheralBaseAddr = ppadr;
  91.     DMA_InitStructure.DMA_MemoryBaseAddr = memadr;
  92.     DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  93.     DMA_InitStructure.DMA_BufferSize = bufsize;
  94.     DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  95.     DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  96.     DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  97.     DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  98.     DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  99.     DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
  100.     DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  101.     DMA_Init( DMA_CHx, &DMA_InitStructure );
  102.     DMA_Cmd( DMA_CHx, ENABLE );
  103. }
  104. /*********************************************************************
  105. * @fn      Get_ConversionVal_3_3V
  106. *
  107. * @brief   Get Conversion Value Under 3.3V.
  108. *
  109. * @param   val - Sampling value
  110. *
  111. * @return  val+Calibrattion_Val - Conversion Value.
  112. */
  113. u16 Get_ConversionVal_3_3V(s16 val)
  114. {
  115.     int32_t y;
  116.     y = 6 * (val + Calibrattion_Val) / 1000 - 12;
  117.     if(val == 0 || val == 4095)
  118.         return val;
  119.     else
  120.     {
  121.         if((val + Calibrattion_Val - y) < 0)
  122.             return 0;
  123.         if((Calibrattion_Val + val - y) > 4095)
  124.             return 4095;
  125.         return (val + Calibrattion_Val);
  126.     }
  127. }
  128. /*********************************************************************
  129. * @fn      Get_ConversionVal_5V
  130. *
  131. * @brief   Get Conversion Value Under 5V.
  132. *
  133. * @param   val - Sampling value
  134. *
  135. * @return  val+Calibrattion_Val - Conversion Value.
  136. */
  137. u16 Get_ConversionVal_5V(s16 val)
  138. {
  139.     int32_t y;
  140.     y = 4 * (val + Calibrattion_Val) / 1000 - 8;
  141.     if(val == 0 || val == 4095)
  142.         return val;
  143.     else
  144.     {
  145.         if((val + Calibrattion_Val - y) < 0)
  146.             return 0;
  147.         if((Calibrattion_Val + val - y) > 4095)
  148.             return 4095;
  149.         return (val + Calibrattion_Val);
  150.     }
  151. }
  152. /*********************************************************************
  153. * @fn      main
  154. *
  155. * @brief   Main program.
  156. *
  157. * @return  none
  158. */
  159. u16 i;
  160. u16 ADC_Average;
  161. u16 s1,s2,s3;
  162. int main(void)
  163. {
  164.     Delay_Init();
  165.     I2C_Configuration();
  166.     OLED_Init();
  167.     USART_Printf_Init(115200);
  168.     OLED_Fill(0xff);
  169.     Delay_Ms(500);
  170.     OLED_Fill(0x00);
  171.     OLED_ShowStr(8, 0, "ADC: ", 2);
  172.     OLED_ShowStr(8, 2, "ADC: ", 2);
  173.     //ADC校准
  174.     //ADC初始化
  175.     ADC_Function_Init();
  176.     //DMA初始化
  177.     DMA_Tx_Init( DMA1_Channel1, (u32)&ADC1->RDATAR, (u32)TxBuf, 10 );
  178.     while(1)
  179.     {
  180.         //PA0输入
  181.         ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_239Cycles5); //配置ADC规则组通道和采样时间
  182.         ADC_SoftwareStartConvCmd(ADC1, ENABLE);
  183.         Delay_Ms(50); //启动ADC采样
  184.         ADC_Average = Get_ADC_Average(TxBuf,10); //启动ADC采样,数据均值滤波
  185.         s1=ADC_Average/1000;
  186.         OLED_ShowSZ(s1, 48, 0, 2);
  187.         s1=ADC_Average-s1*1000;
  188.         s2=s1/100;
  189.         OLED_ShowSZ(s2, 56, 0, 2);
  190.         s2=s1-s2*100;
  191.         s3=s2/10;
  192.         OLED_ShowSZ(s3, 64, 0, 2);
  193.         s3=s2-s3*10;
  194.         OLED_ShowSZ(s3, 72, 0, 2);
  195.         //PA1输入
  196.         ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_239Cycles5);
  197.         ADC_SoftwareStartConvCmd(ADC1, ENABLE);
  198.         Delay_Ms(50); //启动ADC采样
  199.         ADC_Average = Get_ADC_Average(TxBuf,10); //启动ADC采样,数据均值滤波
  200.         s1=ADC_Average/1000;
  201.         OLED_ShowSZ(s1, 96, 0, 2);
  202.         s1=ADC_Average-s1*1000;
  203.         s2=s1/100;
  204.         OLED_ShowSZ(s2, 104, 0, 2);
  205.         s2=s1-s2*100;
  206.         s3=s2/10;
  207.         OLED_ShowSZ(s3, 112, 0, 2);
  208.         s3=s2-s3*10;
  209.         OLED_ShowSZ(s3, 120, 0, 2);
  210.         //PA2输入
  211.         ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 1, ADC_SampleTime_239Cycles5); //配置ADC规则组通道和采样时间
  212.         ADC_SoftwareStartConvCmd(ADC1, ENABLE);
  213.         Delay_Ms(50); //启动ADC采样
  214.         ADC_Average = Get_ADC_Average(TxBuf,10); //启动ADC采样,数据均值滤波
  215.         s1=ADC_Average/1000;
  216.         OLED_ShowSZ(s1, 48, 2, 2);
  217.         s1=ADC_Average-s1*1000;
  218.         s2=s1/100;
  219.         OLED_ShowSZ(s2, 56, 2, 2);
  220.         s2=s1-s2*100;
  221.         s3=s2/10;
  222.         OLED_ShowSZ(s3, 64, 2, 2);
  223.         s3=s2-s3*10;
  224.         OLED_ShowSZ(s3, 72, 2, 2);
  225.         //PA7输入
  226.         ADC_RegularChannelConfig(ADC1, ADC_Channel_7, 1, ADC_SampleTime_239Cycles5); //配置ADC规则组通道和采样时间
  227.         ADC_SoftwareStartConvCmd(ADC1, ENABLE);
  228.         Delay_Ms(50); //启动ADC采样
  229.         ADC_Average = Get_ADC_Average(TxBuf,10); //启动ADC采样,数据均值滤波
  230.         s1=ADC_Average/1000;
  231.         OLED_ShowSZ(s1, 96, 2, 2);
  232.         s1=ADC_Average-s1*1000;
  233.         s2=s1/100;
  234.         OLED_ShowSZ(s2, 104, 2, 2);
  235.         s2=s1-s2*100;
  236.         s3=s2/10;
  237.         OLED_ShowSZ(s3, 112, 2, 2);
  238.         s3=s2-s3*10;
  239.         OLED_ShowSZ(s3, 120, 2, 2);
  240.     }
  241. }
MounRiver工程文件51hei附件下载:
ADC_DMA多路采集.7z (329.32 KB, 下载次数: 10)
收藏收藏1 分享淘帖 顶1 踩
ID:1017639 发表于 2022-4-12 18:19 | 只看该作者
很不错,实用性很高
