查看: 2012|回复: 0
基于51单片机的0-99秒表仿真程序 Proteus仿真卡死
完整代码
  1. #include <reg52.h>
  3. #define uint unsigned int
  4. sbit key1 = P3^0;
  5. sbit key2 = P3^1;
  6. sbit key3 = P3^2;
  7. sbit smg1=P2^0;
  8. sbit smg2=P2^1;
  9. sbit beep=P1^0;
  10. sbit led=P1^1;
  11. uchar disp[]={0,0};
  12. uchar scan;
  13. uchar i,i1,Second_Counts;
  14. uchar flag=1;
  15. uchar DSY_CODE[]=
  16. {
  17.          0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f
  18. };
  19. void DelayMS(uint ms)
  20. {
  21.          uchar t;
  22.         while(ms--)
  23.         {
  24.                  for(t=0;t<120;t++);
  25.         }
  26. }
  27. void delay_ms(unsigned int ms) // ms延时函数 (AT89C51 @ 11.0592MHz)
  28. {
  29.         unsigned int i;
  30.         unsigned char j;
  31.         for(i=0;i<ms;i++)
  32.         {
  33.                 for(j=0;j<200;j++);
  34.                 for(j=0;j<102;j++);
  35.         }
  36. }
  37. void Timer0Init()
  38. {
  39.         TMOD=0X01;//选择为定时器0模式,工作方式1,仅用TR0打开启动。
  40.         TH0  = (65535-50000)/256;
  41.         TL0  = (65535-50000)%256;
  42.         ET0=1;//打开定时器0中断允许
  43.         EA=1;//打开总中断
  44.         TR0=0;//关闭定时器
  45. }
  46. void Timer0() interrupt 1
  47. {
  48.         TH0  = (65535-50000)/256;
  49.         TL0  = (65535-50000)%256;   //50ms
  50.         if(flag==1)
  51.         {
  52.                 if(++i==20)
  53.                 {
  54.                         i = 0;
  55.                         ++Second_Counts;
  56.
  57.                         if(Second_Counts > 99) Second_Counts = 0;
  58.                 }
  59.         }
  60.         else if(flag==2)
  61.         {
  62.                 i1++;
  63.                 if(i1==5)
  64.                 {
  65.                         led=!led;
  66.                         P2=0xff;
  67.                 }
  68.                 if(i1==10)
  69.                 {
  70.                         i1=0;
  71.                         led=!led;
  72.                         P2=0x00;
  73.                 }
  74.         }
  75.
  76. }
  77. void scanner(void)  //数码管显示函数
  78. {
  79.   uchar i;
  80.         scan=0x01;
  81.
  82.         if(flag==2&&i1<5)
  83.         {
  84.                 for(i=0;i<2;i++)   //显示ADC获取的电压
  85.                 {
  86.                                 P2=scan;
  87.                                 P0=DSY_CODE[disp[i]];
  88.                                 delay_ms(5);
  89.                                 scan<<=1;  //数码管移位
  90.                 }
  91.         }
  92.         if(flag==1)
  93.         {
  94.                 for(i=0;i<2;i++)   //显示ADC获取的电压
  95.                 {
  96.                                 P2=scan;
  97.                                 P0=DSY_CODE[disp[i]];
  98.                                 delay_ms(5);
  99.                                 scan<<=1;  //数码管移位
  100.                 }
  101.         }
  102. }
  103. void main()
  104. {
  105.         i = 0;
  106.         Second_Counts = 0;
  107.         Timer0Init();
  108.         led=0;
  109.         beep=0;
  110.
  111.         while(1)
  112.         {
  113.                  scanner();
  114.
  115.                 if(key1==0)
  116.                 {
  117.                         delay_ms(10);
  118.                         if(key1==0)
  119.                         {
  120.                                 flag=1;
  121.                                 TR0=1;
  122.                         }
  123.                         while(!key1);
  124.                 }
  125.
  126.                 if(key2==0)
  127.                 {
  128.                         delay_ms(10);
  129.                         if(key2==0)
  130.                         {
  131.                                 flag=2;
  132.                         }
  133.                         while(!key2);
  134.                 }
  135.
  136.                 if(key3==0)
  137.                 {
  138.                         delay_ms(10);
  139.                         if(key3==0)
  140.                         {
  141.                                 Second_Counts=0;
  142.                                 TR0=0;
  143.                                 led=0;
  144.                                 flag=1;
  145.                         }
  146.                         while(!key3);
  147.                 }
  148.
  149.                 disp[0]=Second_Counts%10;
  150.                 disp[1]=Second_Counts/10;
  151.
  152.                 if(flag==1)
  153.                 {
  154.                         if(disp[0]==9&&disp[1]==9)
  155.                         {
  156.                                 TR0=0;
  157.                                 beep=1;
  158.                                 led=1;
  159.                         }
  160.                         else
  161.                         {
  162.                                 beep=0;
  163.                                 led=0;
  164.                         }
  165.                 }
  166.         }
  167. }
秒表0-99.zip
329.02 KB, 下载次数: 24
