查看: 2343|回复: 0
程序出了点小问题,求大神不吝赐教
ID:54183 发表于 2013-9-12 00:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用定时器以间隔500MS6位数码管上依次显示0123….CDEF,重复#include<reg52.h.>
sbit dula=P2^0;
sbit wela=P2^1;
uchar num,num1;
uchar code table[]={
0xc0,0xf9,0xa4,0xb0,
0x99,0x92,0x82,0xf8,
0x80,0x90,0x88,0x83,
0xc6,0xa1,0x84,0x8e};
        num1=0;
        wela=1;
        P1=0xed;
        wela=0;
        dula=1;
        P1=0xc0;
        dula=0;
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
          if(num==10)
                  num=0;
                ++num1;
                dula=1;
                P1=table[num1];
                dula=0;
                if(num1==15)
                        num1=-1;
void time0() interrupt 1
        num++;
请问为什么在主程序中num1=-1,而不是0
