查看: 1636|回复: 4
单片机信号发生器程序 主函数文件有几个疑问,求大佬看看
回帖奖励 100 黑币 回复本帖可获得 10 黑币奖励! 每人限 1 次
ID:941176 发表于 2022-5-7 16:11 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
以上是主程序,问题放在了程序中,还请大家帮忙看看
#include "reg51.H"
#include "ad9834.h"
#include "LCD1602.h"
#include "keyScan.h"
#define  MAX_VOLT   47   //为啥47代表4.7V
//sbit LED = P0^0;
//sbit key1 = P1^2;
//sbit key2 = P1^3;
//sbit key3 = P1^4;
//sbit key4 = P1^5;
//sbit key5 = P1^6;
//sbit FSK = P3^6;
*        函 数 名: DelayMs
*        功能说明: 时钟延时
*        形    参: ms 以毫秒为单位.
*        返 回 值: 无
void DelayMs( unsigned int ms)
        unsigned int i,j;
        for (i = 0; i < ms; i++)
                for(j=0;j<1000;j++);        //单片机晶振12MHZ,j是随便取吗
        unsigned long FreqData=20000;
  unsigned int volt=MAX_VOLT;
                unsigned int ratio;
        unsigned char AmpData=255;        //不懂这两行,255是啥
        unsigned char WaveModle=0;
        unsigned char  keyNum = 16;
        unsigned char SetFreq_flag=0;//设置频率的标志
        ratio=2550/MAX_VOLT;// 5.7= 255/47; ratio放大10倍了取整数, 44最高输出4.7V
   InitLCD();
   DelayMs( 100);
   DispStrAt("AD9834", 0, 0);
         DispStrAt("sinWave", 8, 0);
          DispDecSpaceAt(FreqData, 0, 1, 7);DispStrAt("HZ", 7, 1);        //0,1,7的0是啥
    AD9834_WaveSeting(FreqData,0,SIN_WAVE,0 );//2KHz,        频率寄存器0,正弦波输出 ,初相位0
    AD9834_AmpSet(AmpData);        //设置幅值,幅值最大 255
           DispStrAt("am   V", 10, 1);
                 DispDecShiftAt(volt, 12, 1, 1);
          keyNum = keyScan();
    if(keyNum!=16)
                        if(SetFreq_flag==0) //不是键盘输入设置频率状态, 步进设置状态
                                                if(keyNum==10 && SetFreq_flag==0)
                                                        SetFreq_flag=1;
                                                        FreqData=0;
                                                        DispDecSpaceAt(FreqData, 0, 1, 7);DispStrAt("  ", 7, 1);
                                                        //AD9833_WaveSeting(FreqData,0,SIN_WAVE,0 );
                                        if(keyNum==12)
                                                FreqData=FreqData+1000;
                                                AD9834_WaveSeting(FreqData,0,WaveModle,0 );
                                                //while(key1==0);
                                 else if(keyNum==13)
                                                if(FreqData>=1000)
                                                FreqData=FreqData-1000;
                                                //while(key2==0);
                                 else if(keyNum==14)
                                                if(volt<MAX_VOLT)
                                                volt=volt+1;
                                                AmpData=volt*ratio/10;
                                                //DispDecSpaceAt(AmpData, 13, 1, 3);
                                                //while(key3==0);
                                 else if(keyNum==15)
                                                        if(volt>0)
                                                        volt=volt-1;
                                                        //while(key4==0);
                                 else if(keyNum==11)
                                         WaveModle=WaveModle+1;
                                         if(WaveModle==3)WaveModle=0;
                                         if(WaveModle==0){AD9834_WaveSeting(FreqData,0,SIN_WAVE,0 );DispStrAt("sinWave", 8, 0);}
                                         else if(WaveModle==1){AD9834_WaveSeting(FreqData,0,TRI_WAVE,0 );DispStrAt("TriWave", 8, 0);}
                                         else if(WaveModle==2){AD9834_WaveSeting(FreqData,0,SQU_WAVE,0 );DispStrAt("SquWave", 8, 0);}
                                         //else if(WaveModle==3){AD9834_SetFSK(1000,5000);DispStrAt("FSKWave", 8, 0);}
                                         //else if(WaveModle==4){AD9834_SetPSK(0,180,5000);DispStrAt("PSKWave", 8, 0);}
                                                //while(key5==0);
                                 else if(SetFreq_flag==1) //是矩阵键盘输入设置频率状态
                                                if(keyNum<10)//输入频率
                                                        FreqData=FreqData*10+keyNum;
                                                else if(keyNum==15)//输错倒退
                                                        FreqData=FreqData/10;
                                                        DispDecSpaceAt(FreqData, 0, 1,7);
                                                else if(keyNum==10)//HZ确定输出
                                                        SetFreq_flag=0;
                                                else if(keyNum==11)////KHZ确定输出
                                                        DispDecSpaceAt(FreqData, 0, 1, 6);DispStrAt("KHZ", 6, 1);
                                                        FreqData=FreqData*1000;
                                                        SetFreq_flag=0;
                                                else if(keyNum==12)////MHZ确定输出
                                                        DispDecSpaceAt(FreqData, 0, 1, 6);DispStrAt("MHZ", 6, 1);
                                                        FreqData=FreqData*1000000;
                                                        SetFreq_flag=0;
ID:123289 发表于 2022-5-9 14:58 | 只看该作者
遇到此类问题的处理方式:
1、粗略读通逻辑关系。
2、弄清程序的输入是什么,程序的目的是什么?
3、如果自己去设计程序,如何架构。
4、试作写一写。
估计你会遇到同样的问题需要解决,这时再回头看他人的程序,或许理解就深刻了。
ID:213173 发表于 2022-5-7 21:17 | 只看该作者
能用整数尽量不用小数。如ADC转换计算电压时VCC采用5000mV,显示时在千位加小数点即可,既方便又精确。
ID:514254 发表于 2022-5-7 18:36 | 只看该作者
MAX_VOLT是后面计算扩大了10倍
j的取值其实是个估算的,这个延时不够准确,能用
ID:121859 发表于 2022-5-7 17:27 | 只看该作者
那个255,就是最大幅值呀,后面0,1,7的0应该是X坐标。
