查看: 3868|回复: 4
51单片机贴片心形灯原理图PCB程序 亚克力外壳.dwg资料
Altium Designer画的51单片机贴片心形灯原理图和PCB图如下:(51hei附件中可下载工程文件)
单色心形灯CAD亚克力外壳设计图
  1. /*******************************************************************/
  2. /* 作品:单色心形流水灯
  3. /* 主控采用STC89c52RC单片机 晶振12M
  4. /*******************************************************************/
  5.
  6. #include<reg52.h>
  7. #define uchar unsigned char
  8. #define uint unsigned int
  9. uchar code table0[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//LED从低位往高位移
  10. uchar code table1[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};//LED从高位往低位移
  11. uchar code table2[]={0xfe,0xfc,0xf8,0xf0,0xe0,0xc0,0x80,0x00};//LED从1个亮到8个都点亮(从低位往高位)
  12. uchar code table3[]={0x7f,0x3f,0x1f,0x0f,0x07,0x03,0x01,0x00};//LED从1个亮到8个都点亮(从高位往低位)
  13. uchar code table4[]={0x00,0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff};//LED从8个全亮到一个都不亮(从低位往高位)
  14. uchar code table5[]={0x00,0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff};//LED从8个全亮到一个都不亮(从高位往低位)
  15. uchar code table6[]={0xfe,0xfc,0xfa,0xf6,0xee,0xde,0xbe,0x7e};//LED从低位往高位移(最低位始终为0)
  16. uchar code table7[]={0x7f,0x3f,0x5f,0x6f,0x77,0x7b,0x7d,0x7e};//LED从高位往低位移(最高位始终为0)
  17. uchar code Tab1[]={0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,0xFF};//暗中左移  向下
  18. uchar code Tab2[]={0x7F,0xBF,0xDF,0xEF,0xF7,0xFB,0xFD,0xFE,0xFF};//暗中右移  向上
  19. uchar code Tab3[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,0x00};//亮中左移         向下
  20. uchar code Tab4[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01,0x00};//亮中右移  向上
  21. uchar code Tab11[]={0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00,0xff};//暗中左移  向下
  22. uchar code Tab22[]={0x7F,0x3F,0x1F,0x0F,0x07,0x03,0x01,0x00,0xff};
  23. uchar code Tab33[]={0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF};
  24. uchar code Tab44[]={0x01,0x03,0x07,0x0F,0x1F,0x3F,0x7F,0xFF};
  25. uchar code Tab55[]={0x08,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff,0xff};
  26. uchar code Tab5[]={0x00,0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xff};
  27. uchar code Tab6[]={0x00,0x01,0x03,0x07,0x0F,0x1F,0x3F,0x7F,0xff};
  28. uchar code Tab7[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
  29. uchar code Tab8[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
  30. uchar i,j,flag=200;        //定义循环变量
  31. uint tt=70,temp,cycle=350,xunhuan;                //定义时间指数
  32. void shansuo();
  33. void xl();
  34. void delay()
  35. {
  36.            uchar m,n;
  37.          for(m=0;m<flag;m++)
  38.              for(n=0;n<250;n++);
  39.
  40. }
  41. void delay1(uint z)        //延时函数
  42. {
  43.         uint x,y;
  44.         for(x=z;x>0;x--)
  45.             for(y=110;y>0;y--);
  46. }
  47. void delay2(uint x)  //延时函数,要足够快,否则灯会闪烁,而不是慢慢变化。
  48. {
  49.         uint i;
  50.          for(i=x;i>0;i--);
  51.
  52. }
  53. void liushuideng1()
  54. {
  55.         for(xunhuan=0;xunhuan<2;xunhuan++)
  56.         {
  57.                  for(temp=0;temp<cycle;temp++) //由暗到亮(灯的亮度是亮和灭保持时间的平均值)
  58.                   {
  59.                           P0=P1=P2=P3=0x00;
  60.                         delay2(temp);         //延时逐渐加大,led=0(亮)保持的时间越来越长,亮度随之变大。
  61.                         P0=P1=P2=P3=0xff;
  62.                         delay2(cycle-temp);        //延时减短,led=1(灭)保持的时间越来越短,结合上一句,整体亮度变大
  63.                   }
  64.
  65.                   for(temp=cycle;temp>0;temp--)//由亮到暗
  66.                   {
  67.                           P0=P1=P2=P3=0x00;
  68.                         delay2(temp);  //延时逐渐减短,led=0(亮)保持的时间越来越短,亮度随之变小。
  69.                             P0=P1=P2=P3=0xff;
  70.                         delay2(cycle-temp);        //延时增长,led=1(灭)保持的时间越来越长,结合上一句,整体亮度变小
  71.                   }
  72.          }
  73. }
  74. void liushuideng2()
  75. {
  76.          P0=P1=P2=P3=0x00;
  77.          delay1(600);
  78.         for(xunhuan=0;xunhuan<2;xunhuan++)
  79.         {
  80.                  for(temp=0;temp<cycle;temp++) //由暗到亮(灯的亮度是亮和灭保持时间的平均值)
  81.                   {
  82.                           P0=P1=P2=P3=0x55;
  83.                         delay2(temp);         //延时逐渐加大,led=0(亮)保持的时间越来越长,亮度随之变大。
  84.                         P0=P1=P2=P3=0xaa;
  85.                         delay2(cycle-temp);        //延时减短,led=1(灭)保持的时间越来越短,结合上一句,整体亮度变大
  86.                   }
  87.                             delay1(600);
  88.                  for(temp=cycle;temp>0;temp--)//由亮到暗
  89.                   {
  90.                     P0=P1=P2=P3=0xaa;
  91.                         delay2(temp);  //延时逐渐减短,led=0(亮)保持的时间越来越短,亮度随之变小。
  92.                 P0=P1=P2=P3=0x55;
  93.                         delay2(cycle-temp);        //延时增长,led=1(灭)保持的时间越来越长,结合上一句,整体亮度变小
  94.                   }
  95.
  96.                             delay1(600);
  97.         }
  98.
  99. }
  100. void liushuideng3()
  101. {
  102.          delay1(1000);
  103.         for(xunhuan=0;xunhuan<2;xunhuan++)
  104.         {
  105.                  for(temp=0;temp<cycle;temp++) //由暗到亮(灯的亮度是亮和灭保持时间的平均值)
  106.                   {
  107.                           P0=P1=P2=P3=0x0f;
  108.                         delay2(temp);         //延时逐渐加大,led=0(亮)保持的时间越来越长,亮度随之变大。
  109.                         P0=P1=P2=P3=0xf0;
  110.                         delay2(cycle-temp);        //延时减短,led=1(灭)保持的时间越来越短,结合上一句,整体亮度变大
  111.                   }
  112.                  delay1(600);
  113.                  for(temp=cycle;temp>0;temp--)//由亮到暗
  114.                   {
  115.                     P0=P1=P2=P3=0xf0;
  116.                         delay2(temp);  //延时逐渐减短,led=0(亮)保持的时间越来越短,亮度随之变小。
  117.                 P0=P1=P2=P3=0x0f;
  118.                         delay2(cycle-temp);        //延时增长,led=1(灭)保持的时间越来越长,结合上一句,整体亮度变小
  119.                   }
  120.                   delay1(600);
  121.
  122.         }
  123.
  124. }
  125. void liushuideng4()
  126. {
  127.         for(xunhuan=0;xunhuan<1;xunhuan++)
  128.         {
  129.                  for(temp=0;temp<cycle;temp++) //由暗到亮(灯的亮度是亮和灭保持时间的平均值)
  130.                   {
  131.                           P0=P2=0x00;
  132.                         delay2(temp);         //延时逐渐加大,led=0(亮)保持的时间越来越长,亮度随之变大。
  133.                     P0=P2=0xff;
  134.                         delay2(cycle-temp);        //延时减短,led=1(灭)保持的时间越来越短,结合上一句,整体亮度变大
  135.                   }
  136.
  137.                   for(temp=cycle;temp>0;temp--)//由亮到暗
  138.                   {
  139.                           P0=P2=0x00;
  140.                         delay2(temp);  //延时逐渐减短,led=0(亮)保持的时间越来越短,亮度随之变小。
  141.                             P0=P2=0xff;
  142.                         delay2(cycle-temp);        //延时增长,led=1(灭)保持的时间越来越长,结合上一句,整体亮度变小
  143.                   }
  144.                   for(temp=0;temp<cycle;temp++) //由暗到亮(灯的亮度是亮和灭保持时间的平均值)
  145.                   {
  146.                           P1=P3=0x00;
  147.                         delay2(temp);         //延时逐渐加大,led=0(亮)保持的时间越来越长,亮度随之变大。
  148.                             P1=P3=0xff;
  149.                         delay2(cycle-temp);        //延时减短,led=1(灭)保持的时间越来越短,结合上一句,整体亮度变大
  150.                   }
  151.
  152.                   for(temp=cycle;temp>0;temp--)//由亮到暗
  153.                   {
  154.                           P1=P3=0x00;
  155.                         delay2(temp);  //延时逐渐减短,led=0(亮)保持的时间越来越短,亮度随之变小。
  156.                             P1=P3=0xff;
  157.                         delay2(cycle-temp);        //延时增长,led=1(灭)保持的时间越来越长,结合上一句,整体亮度变小
  158.                   }
  159.          }
  160. }
  161. void liushuideng5()
  162. {
  163.         for(xunhuan=0;xunhuan<1;xunhuan++)
  164.         {
  165.                  for(temp=0;temp<cycle;temp++) //由暗到亮(灯的亮度是亮和灭保持时间的平均值)
  166.                   {
  167.                           P1=P0=0x00;
  168.                         delay2(temp);         //延时逐渐加大,led=0(亮)保持的时间越来越长,亮度随之变大。
  169.                             P1=P0=0xff;
  170.                         delay2(cycle-temp);        //延时减短,led=1(灭)保持的时间越来越短,结合上一句,整体亮度变大
  171.                   }
  172.
  173.                   for(temp=cycle;temp>0;temp--)//由亮到暗
  174.                   {
  175.                           P1=P0=0x00;
  176.                         delay2(temp);  //延时逐渐减短,led=0(亮)保持的时间越来越短,亮度随之变小。
  177.                             P1=P0=0xff;
  178.                         delay2(cycle-temp);        //延时增长,led=1(灭)保持的时间越来越长,结合上一句,整体亮度变小
  179.                   }
  180.                   for(temp=0;temp<cycle;temp++) //由暗到亮(灯的亮度是亮和灭保持时间的平均值)
  181.                   {
  182.                           P3=P2=0x00;
  183.                         delay2(temp);         //延时逐渐加大,led=0(亮)保持的时间越来越长,亮度随之变大。
  184.                     P3=P2=0xff;
  185.                         delay2(cycle-temp);        //延时减短,led=1(灭)保持的时间越来越短,结合上一句,整体亮度变大
  186.                   }
  187.
  188.                   for(temp=cycle;temp>0;temp--)//由亮到暗
  189.                   {
  190.                           P3=P2=0x00;
  191.                         delay2(temp);  //延时逐渐减短,led=0(亮)保持的时间越来越短,亮度随之变小。
  192.                             P3=P2=0xff;
  193.                         delay2(cycle-temp);        //延时增长,led=1(灭)保持的时间越来越长,结合上一句,整体亮度变小
  194.                   }
  195.          }
  196. }
  197. void liushuideng6()
  198. {
  199.         for(xunhuan=0;xunhuan<1;xunhuan++)
  200.         {
  201.                  for(temp=0;temp<cycle;temp++) //由暗到亮(灯的亮度是亮和灭保持时间的平均值)
  202.                   {
  203.                           P0=P3=0x00;
  204.                         delay2(temp);         //延时逐渐加大,led=0(亮)保持的时间越来越长,亮度随之变大。
  205.                     P0=P3=0xff;
  206.                         delay2(cycle-temp);        //延时减短,led=1(灭)保持的时间越来越短,结合上一句,整体亮度变大
  207.                   }
  208.
  209.                   for(temp=cycle;temp>0;temp--)//由亮到暗
  210.                   {
  211.                           P0=P3=0x00;
  212.                         delay2(temp);  //延时逐渐减短,led=0(亮)保持的时间越来越短,亮度随之变小。
  213.                             P0=P3=0xff;
  214.                         delay2(cycle-temp);        //延时增长,led=1(灭)保持的时间越来越长,结合上一句,整体亮度变小
  215.                   }
  216.                   for(temp=0;temp<cycle;temp++) //由暗到亮(灯的亮度是亮和灭保持时间的平均值)
  217.                   {
  218.                           P1=P2=0x00;
  219.                         delay2(temp);         //延时逐渐加大,led=0(亮)保持的时间越来越长,亮度随之变大。
  220.                     P1=P2=0xff;
  221.                         delay2(cycle-temp);        //延时减短,led=1(灭)保持的时间越来越短,结合上一句,整体亮度变大
  222.                   }
  223.
  224.                   for(temp=cycle;temp>0;temp--)//由亮到暗
  225.                   {
  226.                           P1=P2=0x00;
  227.                         delay2(temp);  //延时逐渐减短,led=0(亮)保持的时间越来越短,亮度随之变小。
  228.                             P1=P2=0xff;
  229.                         delay2(cycle-temp);        //延时增长,led=1(灭)保持的时间越来越长,结合上一句,整体亮度变小
  230.                   }
  231.          }
  232. }
  233. void disp0()                        //状态0 所有LED闪烁3次
  234. {
  235.         for(i=0;i<3;i++)
  236.         {
  237.                 P0=0x00; P2=0x00; P3=0x00; P1=0x00;
  238.                 delay1(300);
  239. ……………………
  240. …………限于本文篇幅 余下代码请从51黑下载附件…………
所有资料51hei附件下载:
单色心形流水灯工程项目.zip (949.92 KB, 下载次数: 59)
收藏收藏3 分享淘帖 顶顶 踩踩
ID:78271 发表于 2022-5-15 22:02 | 只看该作者
设计的挺巧妙,估计做闪动表格的费不少时间。挺佩服的。
ID:230742 发表于 2022-5-16 19:54 | 只看该作者
做的挺好!继续加油。
下次做个2812的。绝对高大上。
ID:484897 发表于 2024-4-12 09:37 | 只看该作者
很棒,资料很齐全
ID:876947 发表于 2024-5-10 12:02 | 只看该作者
大侠可以将这个程序移植到STC32上吗?也赋值到所有I/Ok?
