查看: 1732|回复: 2
请问一下程序为什么会出现这种情况
IO_init();
        Uart_Init();
        Lcd12864Init();
        Lcd12864PutString(2,0,"电量监测");
        Lcd12864PutString(0,1,"电压:");
        Lcd12864PutString(0,2,"电流:");
        Lcd12864PutString(0,3,"功率:");
        while(1){
                if(SUI_101A_Get(1)==0){//获取地址为1的SUI-101A的测量值
                        Delay_ms(2);
                        Lcd12864SetAddress(3,1);
                        lcd12864_display_int(3,Vrms/1000);
                        Lcd12864SendData('.');
                        lcd12864_display_int(3,Vrms%1000);
                        Lcd12864SendData(' ');
                        Lcd12864SendData('V');
                        Delay_ms(2);
                        Lcd12864SetAddress(3,2);
                        lcd12864_display_int(3,Irms/1000);
                        lcd12864_display_int(3,Irms%1000);
                        Lcd12864SendData('A');
                        Delay_ms(2);
                        Lcd12864SetAddress(3,3);
                        lcd12864_display_int(3,Power_active/1000000);
                        lcd12864_display_int(3,Power_active%1000000/1000);
                        Lcd12864SendData('K');
                        Lcd12864SendData('W');
                Delay_ms(800);
ID:965189 发表于 2022-5-19 12:39 | 只看该作者
显示定位不对。
ID:883242 发表于 2022-5-19 15:00 | 只看该作者
你要显示的数字没有转成ASCII码,当然是乱码啦!
