查看: 978|回复: 1
麻烦大佬们看看这段C语言代码,他这个怎么转换成定时时间呀?我C学的不好
ID:1027053 发表于 2022-6-1 19:07 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
//第一段音乐
uchar code tones_array1[][2] = {251,207,251,76,250,104,251,76,252,122,251,207,251,76,251,207,250,104,251,76,251,207,251,76,250,104,249,184,248,244,247,158,251,76,250,104,249,184,249,184,250,104,251,76,251,76,251,207,250,104,249,184,248,244,251,76,250,104,249,184,248,244,247,158,248,244,246,152};
uint code times_array1[] = {1000,333,666,666,666,333,333,1333,666,333,333,666,333,333,333,333,333,333,1333,1000,333,666,333,333,1000,333,1333,1000,333,333,333,333,333,2666};
//第二段音乐
uchar code tones_array2[][2] = {248,244,249,184,250,104,248,244,248,244,249,184,250,104,248,244,250,104,250,184,251,76,250,104,250,184,251,76,251,76,251,207,251,76,250,184,250,104,248,244,251,76,251,207,251,76,250,184,250,104,248,244,249,184,246,152,248,244,249,184,246,152,248,244};
uint code times_array2[] = {250,250,250,250,250,250,250,250,250,250,500,250,250,500,125,125,125,125,250,250,125,125,125,125,250,250,250,250,500,250,250,500};
uchar code scale_array[][2] = {248,244,249,184,250,104,250,184,251,76,251,207,252,68};
ID:883242 发表于 2022-6-1 20:53 | 只看该作者
你贴的是数据,不是代码。
