查看: 3429|回复: 5
51单片机花样流水灯怎么用中断控制启停和切换模式
ID:1012017 发表于 2022-6-3 09:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如题
ID:1024371 发表于 2022-6-3 16:50 | 只看该作者
可以根据这个程序改自己想要的
#include<reg52.h>
sbit beep=P1^5;
sbit k1=P3^1;
sbit k3=P3^2;//外部中断0 p32
sbit led=P2^0;
#define N P2
typedef unsigned int ui;
typedef unsigned char uc;
uc num;
uc zd_bz;
void delay(ui i)
        while(i--);
void fmq()//蜂鸣器
        beep=~beep;
        delay(100);
void led0()//流水灯
        N=0xff;
        N=0xfe;
        fmq();
        delay(50000);
        if(num!=0){return;}
        P0=0xfe;
        N=0xfd;
        fmq();
        delay(50000);
        if(num!=0){return;}
        P0=0xfe;
        N=0xfb;
        fmq();
        delay(50000);
        if(num!=0){return;}
        P0=0xfe;
        N=0xf7;
        fmq();
        delay(50000);
        if(num!=0){return;}
        P0=0xfe;
        N=0xef;
        fmq();
        delay(50000);
        if(num!=0){return;}
        P0=0xfe;
        N=0xdf;
        fmq();
        delay(50000);
        if(num!=0){return;}
        P0=0xfe;
        N=0xbf;
        fmq();
        delay(50000);
        if(num!=0){return;}
        P0=0xfe;
        N=0x7f;
        fmq();
        delay(50000);
  if(num!=0){return;}
        P0=0xfe;
void led1()//led对称亮
                N=0x7e;
                fmq();
                delay(35000);
                //delay(35000);
                if(num!=1){break;}
                P0=0xfc;
                N=0xbd;
                fmq();
                delay(35000);
                //delay(35000);
                if(num!=1){break;}
                P0=0xfc;
                N=0xdb;
                fmq();
                delay(35000);
                //delay(35000);
                if(num!=1){break;}
                P0=0xfc;
                N=0xe7;
                fmq();
                delay(35000);
                //delay(35000);
                if(num!=1){break;}
                P0=0xfc;
                N=0xe7;
                fmq();
                delay(35000);
                //delay(35000);
                if(num!=1){break;}
                P0=0xfc;
                N=0xdb;
                fmq();
                delay(35000);
                //delay(35000);
                if(num!=1){break;}
                P0=0xfc;
                N=0xbd;
                fmq();
                delay(35000);
                //delay(35000);
                if(num!=1){break;}
                P0=0xfc;
                N=0x7e;
                fmq();
                delay(35000);
                //delay(35000);
                if(num!=1){break;}
                P0=0xfc;
void led2()//led分别单双数亮
                N=0xaa;
                fmq();
                delay(50000);
                delay(50000);
                if(num!=2){break;}
                P0=0xf8;
                N=0x55;
                fmq();
                delay(50000);
                delay(50000);
                P0=0xf8;
                if(num!=2){break;}
                P0=0xf8;
void led3()//通过按键k1使led一个一个亮
        ui i;
        N=0xfe;
                if(k1==0)
                  switch(i)
                         case(0):N=0xfd;fmq();i++;break;
                         case(1):N=0xfb;fmq();i++;break;
                         case(2):N=0xf7;fmq();i++;break;
                         case(3):N=0xef;fmq();i++;break;
                         case(4):N=0xdf;fmq();i++;break;
                         case(5):N=0xbf;fmq();i++;break;
                         case(6):N=0x7f;fmq();i++;break;
                         case(7):N=0xff;fmq();i++;break;
                  while(!k1);
                if(i>=8){i=0;break;}
                P0=0xf0;
                if(num!=3){break;}
void init()//中断初始化
        IT0=1;//外部中断0 跳变触发
        EX0=1;//外部中断0 p32
        EA=1;
        init();
                        switch(num)
                         case(0):led0();
                                       P0=0xfe;
                                      break;
                         case(1):led1();
               P0=0xfc;
                                      break;
                         case(2):led2();
                                       P0=0xf8;
                                       break;//num++;
                         case(3):led3();
                                       P0=0xf0;
                                        break;
void init0() interrupt 0//中断程序 k3
        //EX0=0;
        if(num==0){P0=0xfe;}
        num=num+1;
        if(num==1){P0=0xfc;}
        if(num==2){P0=0xf8;}
        if(num==3){P0=0xf0;}
  if(num>3){num=0;}
        //EX0=1;
参与人数 1黑币 +20 收起 理由
admin + 20 回帖助人的奖励!
ID:57657 发表于 2022-6-4 10:48 | 只看该作者
什么中断? 定时器还是外部中断?
ID:123289 发表于 2022-6-6 09:59 | 只看该作者
1、将N个流水灯切割成M个显示状态。
2、每次中断时显示一个状态就可以了。
就看你如何切割了。
ID:1032691 发表于 2022-6-6 19:41 | 只看该作者
使用两个中断函数分别控制启停
ID:1004455 发表于 2022-6-6 22:28 | 只看该作者
分别写两个中断函数,一个用来暂停,一个用来开始,仿真再弄两个外部中断按键
