查看: 1860|回复: 1
数码管超声波
ID:987366 发表于 2022-6-8 16:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <pic.h>
#include <stdio.h>
__CONFIG(0x3b32);
#define trig        RB0
#define echo        RB1
void clrscn(void);                                                        // prototypes
void cursor(char pos);
void print(char *p);
void setup(void);
unsigned int get_srf04(void);
char s[21];        // buffer used to hold text to print
void main(void)
unsigned int range;
        setup();        // sets up the PIC16F877 I2C port
clrscn();        // clears the LCD03 disply
cursor(2);        // sets cursor to 1st row of LCD03
sprintf(s,"SRF04 Ranger Test");                // text, printed into our buffer
print(s);        // send it to the LCD03
while(1) {        // loop forever
range = get_srf04();                                        // get range from srf04 (round trip flight time in 0.8uS units)
cursor(24);        // sets cursor to 2nd row of LCD03
sprintf(s,"Range = %dcm  ", range/72);        // convert to cm
                cursor(44);        // sets cursor to 3rd row of LCD03
                sprintf(s,"Range = %dinch  ", range/185);        // convert to inches
                TMR1H = 0;        // 52mS delay - this is so that the SRF04 ranging is not too rapid
                TMR1L = 0;        // and the previous pulse has faded away before we start the next one
                T1CON = 0x21;                                                        // 1:4 prescale and running
                TMR1IF = 0;
                while(!TMR1IF);                                                // wait for delay time
                TMR1ON = 0;        // stop timer
        TMR1H = 0xff;                                                // prepare timer for 10uS pulse
        TMR1L = -14;
        TMR1IF = 0;
        trig = 1;                                                        // start trigger pulse
        while(!TMR1IF);                                        // wait 10uS
        trig = 0;                                                        // end trigger pulse
        TMR1H = 0;                                                        // prepare timer to measure echo pulse
        TMR1L = 0;
        T1CON = 0x20;                                                // 1:4 prescale but not running yet
        TMR1IF = 0;
        while(!echo && !TMR1IF);                // wait for echo pulse to start (go high)
        TMR1ON = 1;                                                        // start timer to measure pulse
        while(echo && !TMR1IF);                        // wait for echo pulse to stop (go low)
        return (TMR1H<<8)+TMR1L;                // TMR1H:TMR1L contains flight time of the pulse in 0.8uS units
void clrscn(void)
        SEN = 1;        // send start bit
        while(SEN);                                                        // and wait for it to clear
        SSPIF = 0;
        SSPBUF = 0xc6;                                                // LCD02 I2C address
        while(!SSPIF);                                                // wait for interrupt
        SSPIF = 0;                                                        // then clear it.
        SSPBUF = 0;                                                        // address of register to write to
        while(!SSPIF);                                                //
        SSPIF = 0;                                                        //
        SSPBUF = 12;                                                // clear screen
        while(!SSPIF);                                                //
        SSPIF = 0;                                                        //
        SSPBUF = 4;                                                        // cursor off
        while(!SSPIF);                                                //
        SSPIF = 0;                                                        //
        PEN = 1;        // send stop bit
        while(PEN);                                                        //
        SSPIF = 0;
        while(!SSPIF);                                                //
        SSPIF = 0;                                                        //
        SSPBUF = 2;                                                        // set cursor
        while(!SSPIF);                                                //
        SSPIF = 0;                                                        //
        SSPBUF = pos;                                                //
        while(!SSPIF);                                                //
        SSPIF = 0;                                                        //
        while(PEN);                                                        //
        void print(char *p)
        SSPIF = 0;
        while(!SSPIF);                                //
        SSPIF = 0;                                        //
        while(*p) {
                SSPBUF = *p++;                        // write the data
                while(!SSPIF);                        //
                SSPIF = 0;                                //
        while(PEN);                                        //
void setup(void)
unsigned long x;
        TRISB = 0xfe;                                // RB0 (trig) is output
        PORTB = 0xfe;                                // and starts low
        TRISC = 0xff;
        PORTC = 0xff;
        SSPSTAT = 0x80;
        SSPCON = 0x38;
        SSPCON2 = 0x00;
        SSPADD = 50;                                // SCL = 91khz with 20Mhz Osc
        for(x=0; x<300000L; x++);                // wait for LCD03 to initialise
5717-数码管超声波--普通--OK.7z
13.09 MB, 下载次数: 11, 下载积分: 黑币 -5
ID:67185 发表于 2022-11-30 10:07 | 只看该作者
是全套文件吗?
