查看: 2998|回复: 0
基于51单片机的八路抢答器代码与Proteus仿真图
//4*4键盘检测程序,按下键后相应的代码显示在数码管上
#include<reg51.h>
sbit beep=P2^3;
sbit dula=P2^6;
sbit wela=P2^7;
         unsigned char i=100;
unsigned char j,k,temp,key,t,time=30,mode=1;
void delay(unsigned char i)
  for(j=i;j>0;j--)
    for(k=125;k>0;k--);
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
                        0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void init()
        TMOD=0x01;
        TH0=0x3C;
        TL0=0x80;
        ET0=1;
        TR0=0;
        EA=1;
void sound()
        beep=0;
        delay(150);
        beep=1;
        delay(20);
void data_tim()
        if(t==20)
                t=0;
                time--;
                if(time==0)
                        TR0=0;
                        mode=1;
                        sound();
void display(uchar q_c,uchar bai_c,uchar sh_c,uchar g_c)                        //显示程序
   P0=table[q_c];                //显示编号
   dula=1;
   dula=0;
   P0=0xfe;
   wela=1;
   wela=0;
   delay(5);
   P0=table[bai_c];                //显示百位
   dula=1;
   dula=0;
   P0=0xf7;
   wela=1;
   wela=0;
   delay(5);
   dula=0;
   P0=table[sh_c];                //显示十位
   dula=1;
   dula=0;
   wela=0;
   P0=0xef;
   wela=1;
   wela=0;
   delay(5);
   P0=table[g_c];                //显示个位
   dula=1;
   dula=0;
   P0=0xdf;
   wela=1;
   wela=0;
   delay(5);
void keyscan()
        P3=0xfe;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xee:
               //key=0;
                           TR0=~TR0;
                           mode=0;
               break;
          case 0xde:
               mode=0;
                           key=0;
                           time=30;
               break;
          case 0xbe:
               //key=2;
                           time+=1;
               break;
          case 0x7e:
               //key=3;
                           time-=1;
               break;
         while(temp!=0xf0)
           temp=P3;
           temp=temp&0xf0;
           beep=0;
         beep=1;
//        display(key);
        // P0=table[key];
/*        P0=0xff;
         dula=1;
         while(i--);
         dula=0;
         P0=0xc0;
         wela=1;
         wela=0;
  dula=0;
  wela=0;
  P0=0xff;
  dula=1;
  dula=0;
  P0=0xc5;
  wela=1;
  wela=0; */
         P1=0xfe;
        if(mode==0)
    P3=0xfd;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xed:
               key=1;
                           TR0=0;
                           mode=1;
               break;
          case 0xdd:
               key=2;
                           TR0=0;
                           mode=1;
               break;
          case 0xbd:
               key=3;
                           TR0=0;
                           mode=1;
               break;
          case 0x7d:
               key=4;
                           TR0=0;
                           mode=1;
               break;
         while(temp!=0xf0)
           temp=P3;
           temp=temp&0xf0;
           //beep=0;
         beep=1;
//         display(key);
/*         P0=table[key];
         dula=1;
      //   while(100--);
         dula=0;
         P0=0xc0;
         wela=1;
         wela=0;
  */       P1=0xfc;
    P3=0xfb;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xeb:
               key=5;
                           mode=1;
                           TR0=0;
               break;
          case 0xdb:
               key=6;
                           TR0=0;
                           mode=1;
               break;
          case 0xbb:
               key=7;
                           TR0=0;
                           mode=1;
               break;
          case 0x7b:
               key=8;
                           TR0=0;
                           mode=1;
               break;
         while(temp!=0xf0)
           temp=P3;
           temp=temp&0xf0;
           //beep=0;
         beep=1;
//        display(key);
     /*    P0=table[key];
         dula=1;
      //   while(100--);
         dula=0;
         P0=0xc0;
         wela=1;
         wela=0;
    */     P1=0xf8;
    P3=0xf7;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xe7:
               key=12;
               break;
          case 0xd7:
               key=13;
               break;
          case 0xb7:
               key=14;
               break;
          case 0x77:
               key=15;
               break;
         while(temp!=0xf0)
           temp=P3;
           temp=temp&0xf0;
           //beep=0;
         beep=1;
//        display(key);
  /*       P0=table[key];
         dula=1;
   //      while(100--);
         dula=0;
         P0=0xc0;
         wela=1;
         wela=0;
    */     P1=0xf0;
  dula=0;
  wela=0;
  init();
     keyscan();
         data_tim();
         display(key,time/100,time%100/10,time%10);
void Timer0() interrupt        1
        t++;
        TH0=0x3C;
        TL0=0x80;
Keil代码与Proteus8.8仿真下载: 八路抢答器.7z (277.74 KB, 下载次数: 37)
