查看: 2300|回复: 0
单片机红外NEC解码代码
ID:592337 发表于 2022-6-29 11:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
*函数名称:ir_drive
*功           能:NEC红外解码
*调用时间:定时器125us中断
typedef        union{
struct{
unsigned char bit0:1;
unsigned char bit1:1;
unsigned char bit2:1;
unsigned char bit3:1;
unsigned char bit4:1;
unsigned char bit5:1;
unsigned char bit6:1;
unsigned char bit7:1;
}bits;
unsigned char byte;
}bit_struct;
#define ir_io        FP51
volatile bit_struct ir_flag;
volatile unsigned char ir_phase,ir_l_count,ir_h_count,ir_recv_bit_count;
volatile unsigned char ir_buf_tem,ir_buf[4];//[0]地址[1]地址反码[2]键值[3]键值反码
#define        ir_io_stare                        ir_flag.bits.bit0
#define ir_io_stare_old                ir_flag.bits.bit1
#define        ir_ok                                ir_flag.bits.bit2
#define        ir_repeat                        ir_flag.bits.bit3
void ir_drive(void)
        ir_io_stare = ir_io;
        if(ir_io_stare)
                if(ir_l_count != 0)
                        ir_h_count++;
                ir_l_count++;
        if(ir_io_stare_old != ir_io_stare)
                ir_io_stare_old = ir_io_stare;
                if(ir_io_stare_old == 0)
                        if(ir_phase == 0)
                        {//9ms低电平+4.5ms高电平
                                if(ir_l_count >= 60)
                                        if(ir_h_count >= 31)
                                        {//起始码
                                                ir_phase++;
                                                ir_recv_bit_count = 0;
                                        else if(ir_h_count >= 15)
                                        {//重复码
                                                ir_buf_tem++;
                                                if(ir_buf_tem > 4)
                                                        ir_buf_tem = 0;
                                                        ir_repeat = 1;
                        else if(ir_phase == 1)
                        {//解码,1:560us低电平+1690us高电平
                                if(ir_l_count >= 2)
                                        ir_buf_tem <<= 1;
                                        if(ir_h_count >= 11)
                                                ir_buf_tem++;
                                        ir_buf[ir_recv_bit_count/8] = ir_buf_tem;
                                        ir_recv_bit_count++;
                                        if(ir_recv_bit_count == 32)
                                                ir_phase = 0;
                                                ir_buf_tem = 0;
                                                ir_ok = 1;
                                        ir_phase = 0;
                        ir_h_count = 0;
                        ir_l_count = 0;
void ir_task(void)
        if(ir_ok)
                ir_ok = 0;
        if(ir_repeat)
                ir_repeat = 0;
参与人数 1黑币 +30 收起 理由
admin + 30 共享资料的黑币奖励!
