查看: 2902|回复: 11
i2c问题
ID:100982 发表于 2022-8-14 08:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include <reg52.h>
  2. extern void write_str(unsigned char x,unsigned char y,unsigned char *str);
  3. extern void init_1602();
  4. extern bit i2c_addr(unsigned char addr);
  5. void main()
  6. {
  7.         unsigned char str[12];
  8.            bit ack;
  9.         init_1602();
  10.         ack = i2c_addr(0x50); <span style="background-color: yellow;"> //程序跑到这一行就死掉了</span>
  11.         str[0] = '5';
  12.         str[1] = '0';
  13.         str[2] = ':';
  14.         str[3] = (unsigned char)ack + '0';
  15.         str[4] = '\0';
  16.
  17.         write_str(0,0,str);
  18.         ack = i2c_addr(0x61);
  19.         str[0] = '6';
  20.         str[1] = '1';
  21.         str[2] = ':';
  22.         str[3] = (unsigned char)ack + '0';
  23.         str[4] = '\0';
  24.
  25.         write_str(0,1,str);
  26.         while(1);
  27. }
ack = i2c_addr(0x50); 程序跑到这行就死掉了,想不明白为啥
ID:100982 发表于 2022-8-14 08:18 | 只看该作者
  2. #include <intrins.h>
  3. sbit sda = P2^0;
  4. sbit scl = P2^1;
  5. #define        i2c_delay()  {_nop_();_nop_();_nop_();_nop_();}
  6. void i2c_start()
  7. {
  8.         scl = 1;
  9.         sda = 1;
  10.         i2c_delay();
  11.         sda = 0;
  12.         i2c_delay();
  13.         scl = 0;
  14. }
  15. void i2c_stop()
  16. {
  17.         scl = 0;
  18.         sda = 0;
  19.         i2c_delay();
  20.         scl = 1;
  21.         i2c_delay();
  22.         sda = 1;
  23.         i2c_delay();
  24. }
  25. bit i2c_write(unsigned char dat)
  26. {
  27.         bit ack = 0;
  28.         unsigned char mask;
  29.
  30.         for(mask = 0x80; mask != 0; mask >> 1)
  31.         {
  32.                 if((mask&dat) == 0)
  33.                 {
  34.                          sda = 0;
  35.                 }
  36.                 else
  37.                 {
  38.                         sda = 1;
  39.                 }
  40.
  41.                 i2c_delay();
  42.                 scl = 1;
  43.                 i2c_delay();
  44.                 scl = 0;
  45.         }
  46.
  47.         sda = 1;
  48.         i2c_delay();
  49.
  50.         scl = 1;
  51.         i2c_delay();
  52.
  53.         ack = sda;
  54.         i2c_delay();
  55.         scl = 0;
  56.
  57.         return ack;
  58. }
  59. bit i2c_addr(unsigned char addr)
  60. {
  61.         bit ack;
  62.
  63.         i2c_start();
  64.         ack = i2c_write(addr << 1);
  65.         i2c_stop();
  66.         return ack;
  67. }
这是i2c部分的程序
  2. #define db P0
  3. sbit lcde = P2^7;
  4. sbit rs = P2^6;
  5. sbit rw = P2^5;
  6. void wait_ready()        //等待液晶不忙
  7. {
  8.         unsigned char sta = 0;
  9.         db = 0xff;
  10.         rs = 0;
  11.         rw = 1;
  12.         do
  13.         {
  14.                 lcde = 1;
  15.                 sta = db;
  16.                 lcde = 0;
  17.         }while(sta & 0x80);
  18. }
  19. void write_dat(unsigned char dat)//写数据
  20. {
  21.         wait_ready();
  22.         rs = 1;
  23.         rw = 0;
  24.         db = dat;
  25.         lcde = 1;
  26.         lcde = 0;
  27. }
  28. void write_com(unsigned char com)//写命令
  29. {
  30.         wait_ready();
  31.         rs = 0;
  32.         rw = 0;
  33.         db = com;
  34.         lcde = 1;
  35.         lcde = 0;
  36. }
  37. void set_cursor(unsigned char x,unsigned char y) //设定坐标
  38. {
  39.         unsigned char addr = 0;
  40.         if(y == 0)
  41.         {
  42.                 addr = 0x00 + x;
  43.         }
  44.         else
  45.         {
  46.                 addr = 0x40 + x;
  47.         }
  48.         write_com(0x80 + addr);
  49. }
  50. void write_str(unsigned char x,unsigned char y,unsigned char *str)
  51. {
  52.         set_cursor(x,y);
  53.         while(*str != '\0')
  54.         {
  55.                 write_dat(*str++);
  56.         }
  57. }
  58. void clean_screen()  //清屏
  59. {
  60.         write_com(0x01);
  61. }
  62. void init_1602()   //初始化
  63. {
  64.         write_com(0x38);
  65.         write_com(0x06);
  66.         write_com(0x0c);
  67.         write_com(0x01);
  68. }
  69. void lcdareaclean(unsigned char x,unsigned char y,unsigned char len)
  70. {
  71.                  set_cursor(x,y);
  72.                  while(len--)
  73.                  {
  74.                           write_dat(' ');
  75.                  }
  76. }
这是1602
ID:100982 发表于 2022-8-14 08:19 | 只看该作者
1602程序是没有问题的
ID:161164 发表于 2022-8-14 22:45 | 只看该作者
什么叫"死掉"?
你这I2C通讯的是什么芯片?
ID:139866 发表于 2022-8-15 09:08 | 只看该作者
问就是时序不对,照个示波器自己调时序
ID:401564 发表于 2022-8-15 11:48 | 只看该作者
我是半路出家的,谁能告诉我这个是什么意思?在Keil下能正常编译吗?
ID:647261 发表于 2022-8-15 18:52 | 只看该作者
示波器量一下I2C地址对得上吗,应答位是“1”还是“0”?
地址不对就改地址,地址没问题没应答就硬件上查一下从设备的问题吧
ID:139866 发表于 2022-8-16 14:03 | 只看该作者
这是html的,应该是复制的时候网页有问题加上的
ID:100982 发表于 2022-8-20 10:54 | 只看该作者
lkc8210 发表于 2022-8-14 22:45
什么叫"死掉"?
你这I2C通讯的是什么芯片?
51单片机io口模拟的
ID:100982 发表于 2022-8-20 17:28 | 只看该作者
问题找到了,
  1. bit i2c_write(unsigned char dat)
  2. {
  3.         bit ack = 0;
  4.         unsigned char mask;
  5.
  6.         for(mask = 0x80; mask != 0; mask >> 1)
  7.         {
  8.                 if((mask&dat) == 0)
  9.                 {
  10.                          sda = 0;
  11.                 }
  12.                 else
  13.                 {
  14.                         sda = 1;
  15.                 }
出现在mask这个地方
ID:100982 发表于 2022-8-22 08:52 | 只看该作者
mask  >>= 1
