查看: 2358|回复: 0
4位共阳数码管模块动态显示0~9999任意实数单片机代码
ID:260656 发表于 2022-11-17 18:23 | 显示全部楼层 |阅读模式
       程序是某一个宝买的4位共阳数码管模块(带两块595)资料改的,原程序只能显示4位整数(少一位都会出错),我改成了能动态显示0~9999任意带小数点的实数,随便几位,实测都完美显示(比如原数3.14159、显示3.141,原数3.02、显示3.020)!
有喜欢的拿走。。。
单片机代码附上
         #include <reg52.h>                        //头文件
         #include <intrins.h>
         #define uchar unsigned char // 数据类型简化-起别名
         uchar i, duan, wei,dw;
         uint num;
          float x=  24.15;        //0~9999任意实数
         static uchar WEI;
     sbit DIO = P1^4;
     sbit R_CLK = P1^3;
     sbit S_CLK = P1^2;
     uchar code smgduan[] = {0x03,0x9f,0x25,0x0d,0x99,0x49,0x41,0x1f,0x01,0x09,0xfd,0xff,0xfe};          //{0,1,2,3,4,5,6,7,8,9,-,全灭,.}
     uchar code smgwei[] = {0x10,0x20,0x40,0x80};
     void display(num)
        if (x>=0 && x<10)        {num=x*1000;dw=0;}
        if (x>=10 && x<100)        {num=x*100;dw=1;}
        if (x>=100 && x<1000)        {num=x*10;dw=2;}
        if (x>=1000 && x<10000)        {num=x*1;dw=3;}
    switch(WEI)
        case 0 :
                if (dw==0)
                {duan = smgduan[num / 1000 % 10]& smgduan[12] ; break;   }
                else  duan = smgduan[num / 1000 % 10];break;
        case 1 :
                if (dw==1)
                { duan = smgduan[num / 100 % 10]& smgduan[12] ; break;   }
            else        duan = smgduan[num / 100 % 10]; break;
        case 2 :
            if (dw==2)
                { duan = smgduan[num / 10 % 10]& smgduan[12] ; break;  }
            else  duan = smgduan[num / 10 % 10];        break;
        case 3 :
                if (dw==3)
                { duan = smgduan[num % 10]& smgduan[12] ;  break;  }
            else  duan = smgduan[num % 10];        break;
    for(i = 0; i < 8; i ++)
        S_CLK = 0;
        R_CLK = 0;
        if(duan & 0x01) DIO = 1;
        else DIO = 0;
        S_CLK = 1;
        duan >>= 1;  //从最低位读入
    wei = smgwei[WEI];
        S_CLK = 0;
        R_CLK = 0;
        if(wei & 0x01) DIO = 1;
        else DIO = 0;
        S_CLK = 1;
        wei >>= 1;
    R_CLK = 1;
    WEI ++;
    if(WEI == 4) WEI = 0;
    void timer0Init()  //定时器0初始化
    EA = 1;    //打开总中断
    ET0 = 1;//打开定时器0中断
    TR0 = 1;     //启动定时器0
    TMOD |= 0X01; //定时器工作模式1,16位定时模式
    TH0 = 0xf5;
    TL0 = 0x33; //定时3ms
    timer0Init();
    while(1);
    void timer0() interrupt 1  //定时器中断服务函数
    TH0 = 0xf5;
    TL0 = 0x33; //定时3ms
    display(num);
