查看: 2348|回复: 1
单片机DAC0832函数波形信号发生器程序与Proteus仿真原理图
  1. #include "reg51.h"
  2. #include <data.h>
  3. #include <LCD1602.h>
  5. #define uint unsigned int
  6. #define key P1
  7. #define dataout P3
  8. uchar fre[5] ="001Hz";
  9. uint data THHL=65536-3906;
  10. uchar data keyword,n=0;
  11. uchar data Signal_chose = 0;
  12. uchar data div = 1;
  13. void keyscan()
  14. {
  15. keyword=key&0x3f;
  16. if(keyword!=0x3f)
  17. {
  18.   while((key&0x3f)!=0x3f);        //等待按键松开
  19.   switch(keyword)
  20.   {
  21.                 case 62: {
  22.                                                         if(div>=100) THHL=65536-39; else {div++;THHL=65536-3906/div;}//频率up
  23.                                                         fre[0]=div/100 + '0';fre[1]=div/10%10 + '0';fre[2]=div%10 + '0';
  24.                                                         TR1=0;LCD_send(2,11,fre,5);TR1=1; break;
  25.                                                         }
  26.                 case 61: {
  27.                                                         if(div<=1) THHL=65536-3906; else {div--;THHL=65536-3906/div;}//频率down
  28.                                                         fre[0]=div/100 + '0';fre[1]=div/10%10 + '0';fre[2]=div%10 + '0';
  29.                                                         TR1=0;LCD_send(2,11,fre,5);TR1=1; break;
  30.                                                         }
  31.
  32.                 case 59: {Signal_chose=0;TR1=0;LCD_send(1,5,"Sin       ",10);TR1=1; break;}          //正弦波
  33.                 case 55:        {Signal_chose=1;TR1=0;LCD_send(1,5,"Triangular",10);TR1=1; break;}                //三角波
  34.                 case 47:        {Signal_chose=2;TR1=0;LCD_send(1,5,"Square    ",10);TR1=1; break;}                //方波
  35.                 case 31: {Signal_chose=3;TR1=0;LCD_send(1,5,"Sawtooth  ",10);TR1=1; break;}                //锯齿波
  36.                 default:{break;}
  37.    }
  38. }
  39. }
  40.
  41. void init()        //初始化
  42. {
  43. key=0x3f;P2=0x00;dataout=0x00;THHL=65536-3906;  ///初始频率为1Hz
  44. TH1=THHL/256;TL1=THHL%256;
  45. TMOD=0x11;ET1=1;TR1=1;EA=1;
  46. }
  47.
  48. void main()
  49. {
  50.         LCD_init();
  51.         LCD_send(1,0,"Type:Sin",8);
  52.         LCD_send(2,0,"frequency:",10);
  53.         LCD_send(2,11,fre,5);
  54.         init();
  55.         while(1)
  56.         {
  57.                 keyscan();
  58.                 switch(Signal_chose)
  59.                         {
  60.                                 case 0: {dataout=sin_tab[n]; break;}  //正弦波
  61.                                 case 1: {dataout=thr_tab[n]; break;}  //三角波
  62.                                 case 2: {dataout=squ_tab[n]; break;}  //方波
  63.                                 case 3: {dataout=255-n;break;}                                //锯齿波
  64.                                 default:{break;}
  65.                          }
  66.         }
  67. }
  68.
  69. void time_intt1(void) interrupt 3
  70. {
  71.         TL1=THHL%256;TH1=THHL/256;
  72. //        if(n>=255) {n=0;} else {n++;}
  73.         n++;
  74. }
Keil5代码与Proteus8.8仿真下载:
信号发生器Proteus仿真程序.7z (87.94 KB, 下载次数: 57)
ID:1053522 发表于 2022-11-23 20:23 | 只看该作者
方波,正弦
