查看: 2121|回复: 0
单片机+Max7219两片连级第一片正常,第二片交替显示第一第二片数据程序
ID:1053761 发表于 2022-11-24 16:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
#define uint  unsigned int
//定义Max7219端口
sbit Max7219_pinCLK = P0^2;
sbit Max7219_pinCS  = P0^1;
sbit Max7219_pinDIN = P0^0;
void Delay_xms(uint x)
uint i,j;
for(i=0;i<x;i++)
  for(j=0;j<112;j++);
//功能:向MAX7219(U3)写入字节
//入口参数:DATA
//出口参数:无
//说明:
void Write_Max7219_byte(uchar DATA)
            uchar i;
                Max7219_pinCS=0;
            for(i=8;i>=1;i--)
            Max7219_pinCLK=0;
            Max7219_pinDIN=DATA&0x80;
            DATA=DATA<<1;
            Max7219_pinCLK=1;
//功能:向MAX7219写入数据
//入口参数:address、dat
//出口参数:无
//说明:
void Write_Max7219(uchar address,uchar dat)
     Max7219_pinCS=0;
         Write_Max7219_byte(address);           //写入地址,即数码管编号
     Write_Max7219_byte(dat);               //写入数据,即数码管显示数字
         Max7219_pinCS=1;
//功能:向第二片MAX7219写入数据
//入口参数:address、dat
//出口参数:无
//说明:
void Write_Max7219_2(uchar address,uchar dat)
     Max7219_pinCS=0;
     Max7219_pinCLK=1;
     Write_Max7219_byte(0X00);              //对第一片执行空操作
         Max7219_pinCS=1;
//MAX7219初始化
void Init_MAX7219(void)
Write_Max7219(0x09, 0xff);       //译码方式:BCD码
Write_Max7219_2(0x09, 0xff);       //译码方式:BCD码
Write_Max7219(0x0a, 0x02);       //亮度
Write_Max7219_2(0x0a, 0x02);       //亮度
Write_Max7219(0x0b, 0x07);       //扫描界限;8个数码管显示
Write_Max7219_2(0x0b, 0x07);       //扫描界限;8个数码管显示
Write_Max7219(0x0c, 0x01);       //掉电模式:0,普通模式:1
Write_Max7219_2(0x0c, 0x01);       //掉电模式:0,普通模式:1
Write_Max7219(0x0f, 0x00);       //显示测试:1;测试结束,正常显示:0
Write_Max7219_2(0x0f, 0x00);       //显示测试:1;测试结束,正常显示:0
void main(void)
Delay_xms(50);
Init_MAX7219();
Write_Max7219(1,1);
Write_Max7219(2,2);
Write_Max7219(3,3);
Write_Max7219(4,4);
Write_Max7219(5,5);
Write_Max7219(6,6);
Write_Max7219(7,7);
Write_Max7219(8,8);
Write_Max7219_2(1,8);
Write_Max7219_2(2,7);
Write_Max7219_2(3,6);
Write_Max7219_2(4,5);
Write_Max7219_2(5,4);
Write_Max7219_2(6,3);
Write_Max7219_2(7,2);
Write_Max7219_2(8,1);
