查看: 2050|回复: 1
Proteus画PCB出错Connectors have been pre-annotated as J1,J2,J3 and J4 so you ...
Connectors have been pre-annotated as J1,J2,J3 and J4 so you must manually annotate the corresponding connectors in the schematic.接头已预先标注为J1、J2、J3和J4,因此必须手动标注原理图中的相应接头。
请问这个问题应该如何解决呢?
ID:301191 发表于 2022-12-6 06:09 | 只看该作者
顶一下
