查看: 2267|回复: 5
stm32f103单片机+LCD12864一直蓝屏,无任何显示 改如何调试?
.h
#ifndef _LCD12864_H_
#define _LCD12864_H_
#include "stm32f10x.h"
#include "sys.h"
typedef struct{
        u8 c51 ;
        u8 num ;
        u8 *dat;
}LCD_InitTypeDef;
#define CS  GPIO_Pin_1 //RS
#define SID GPIO_Pin_2 //RW
#define CLK GPIO_Pin_3 //EN
#define PSB GPIO_Pin_4 //串并选择 H并 L串
#define CMD_PROT GPIOA
#define CS_HIGH GPIO_SetBits(CMD_PROT,CS)
#define CS_LOW GPIO_ResetBits(CMD_PROT,CS)
#define SID_HIGH GPIO_SetBits(CMD_PROT,SID)
#define SID_LOW GPIO_ResetBits(CMD_PROT,SID)
#define CLK_HIGH GPIO_SetBits(CMD_PROT,CLK)
#define CLK_LOW GPIO_ResetBits(CMD_PROT,CLK)
#define PSB_HIGH GPIO_SetBits (CMD_PROT,PSB)
#define PSB_LOW GPIO_ResetBits(CMD_PROT,PSB)
#define CMD 0XF8
#define DAT 0XFA
void LCD12864_UserConfig(void);
void LCD12864_Write_Init(void);
void LCD12864_Opne(void);
void LCD12864_Shut(void);
void LCD12864_Write_Cmd_Data(u8 cmd,u8 data);
void LCD12864_Write_Word(LCD_InitTypeDef LCD_InitStructure);
void LCD12864_Write_Number(u8 c51,u16 num);
#endif
.c
#include "Delay.h"
#include "LCD12864.h"
void LCD12864_UserConfig(void){
        GPIO_InitTypeDef GPIO_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
        GPIO_InitStructure.GPIO_Pin   = CS|SID|CLK|PSB; //CMD
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
        GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_Out_PP;
        GPIO_Init(CMD_PROT,&GPIO_InitStructure);
void LCD12864_Write_Byte(u8 data){
        CS_HIGH;
        for(u8 i=0;i<8;i++){ // 1000 0000 << 0 >>
                ((data<<i)&0x80) ? SID_HIGH:SID_LOW;
                CLK_LOW;
                CLK_HIGH;
        CS_LOW;
void LCD12864_Write_Cmd_Data(u8 cmd,u8 data){
        LCD12864_Write_Byte(cmd);
        LCD12864_Write_Byte(data&0xf0);//HIGH 0X38 1000 0000 & 1111 0000 1000 <<4
        LCD12864_Write_Byte((data<<4)&0xf0);
        Delay_ms(2);
void LCD12864_Write_Init(void){
        PSB_LOW;
        LCD12864_Write_Cmd_Data(CMD,0x30);
        LCD12864_Write_Cmd_Data(CMD,0x06);
        LCD12864_Write_Cmd_Data(CMD,0x0C);
        LCD12864_Write_Cmd_Data(CMD,0x01); //清屏
        LCD12864_Write_Cmd_Data(CMD,0x80);
void LCD12864_Opne(void){
void LCD12864_Shut(void){
        LCD12864_Write_Cmd_Data(CMD,0x08);
void LCD12864_Write_Word(LCD_InitTypeDef LCD_InitStructure){
        LCD12864_Write_Cmd_Data(CMD,LCD_InitStructure.c51);
        for(u8 i=0;i<LCD_InitStructure.num;i++){
                LCD12864_Write_Cmd_Data(DAT,*LCD_InitStructure.dat++);
                Delay_ms(200);
void LCD12864_Write_Number(u8 c51,u16 num){
        const u8 number[] = {"0123456789"};
        LCD12864_Write_Cmd_Data(CMD,c51);
        LCD12864_Write_Cmd_Data(DAT,number[num/1000]);    //1314 1
        LCD12864_Write_Cmd_Data(DAT,number[num%1000/100]);//1314 3
        LCD12864_Write_Cmd_Data(DAT,number[num%100/10]);  //1314 1
        LCD12864_Write_Cmd_Data(DAT,number[num%100%10]);  //1314 4
main
#include "Delay.h"
LCD_InitTypeDef LCD_InitStructure;
int main(void){
        LCD12864_UserConfig();
    LCD12864_Write_Init();
        LCD12864_Opne();
        LCD_InitStructure.c51 = 0X80; //0X80-0X8F 16 8
        LCD_InitStructure.num = 16;
        LCD_InitStructure.dat = (u8*)&"胜日寻芳泗水滨,";
        LCD12864_Write_Word(LCD_InitStructure);
        LCD_InitStructure.c51 = 0X90; //0X90-0X9F 16 8
        LCD_InitStructure.dat = (u8*)&"无边光景一时新。";
        LCD_InitStructure.c51 = 0X88; //0X88-0X8F 16 8
        LCD_InitStructure.dat = (u8*)&"等闲识得东风面,";
        LCD_InitStructure.c51 = 0X98; //0X98-0X9F 16 8
        LCD_InitStructure.dat = (u8*)&"万紫千红总是春。";
        Delay_ms(500);
        LCD12864_Write_Number(0x80,1314);//u8 0-255 u16 0-65535
        while(1){
                for(u8 i=0;i<200;i++){
                        LCD12864_Write_Number(0x90,i);//u8 0-255 u16 0-65535
                        Delay_ms(200);
ID:771630 发表于 2023-1-26 02:11 | 只看该作者
调一下对比度,你这是对比度有问题
ID:1061573 发表于 2023-1-26 05:05 来自触屏版 | 只看该作者
我看csdn上 很多直接vo对比度空接  根本不管
ID:1061573 发表于 2023-1-26 06:45 来自触屏版 | 只看该作者
XLinliY.Zhang 发表于 2023-1-26 02:11
调一下对比度,你这是对比度有问题
我按照csdn 上例程来的  很多csdn博主都把VO对比度空接了
ID:1059013 发表于 2023-1-26 13:13 | 只看该作者
如何代码没有bug,那么调低单片机的主频试试
ID:965189 发表于 2023-1-26 14:19 | 只看该作者
有一些12864的背面有对比度调节电位器。
