查看: 2283|回复: 6
关于51单片机C语言求数组大小的问题
ID:1065477 发表于 2023-3-7 22:57 | 显示全部楼层 |阅读模式
单片机C语言源程序如下:
/*MODE:Triangle*/
char code Mode_Tri[]=
{0x08,0xF8,0xF8,0x00,0xF8,0xF8,0x08,0x00,0x20,0x3F,0x01,0x3E,0x01,0x3F,0x20,0x00,/*"M",0*/
0xE0,0x10,0x08,0x08,0x08,0x10,0xE0,0x00,0x0F,0x10,0x20,0x20,0x20,0x10,0x0F,0x00,/*"O",1*/
0x08,0xF8,0x08,0x08,0x08,0x10,0xE0,0x00,0x20,0x3F,0x20,0x20,0x20,0x10,0x0F,0x00,/*"D",2*/
0x08,0xF8,0x88,0x88,0xE8,0x08,0x10,0x00,0x20,0x3F,0x20,0x20,0x23,0x20,0x18,0x00,/*"E",3*/
0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,/*":",4*/
0x18,0x08,0x08,0xF8,0x08,0x08,0x18,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00,/*"T",5*/
0x80,0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x20,0x20,0x3F,0x21,0x20,0x00,0x01,0x00,/*"r",6*/
0x00,0x80,0x98,0x98,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,/*"i",7*/
0x00,0x00,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x19,0x24,0x24,0x12,0x3F,0x20,0x00,/*"a",8*/
0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x3F,0x21,0x00,0x00,0x20,0x3F,0x20,/*"n",9*/
0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x6B,0x94,0x94,0x94,0x93,0x60,0x00,/*"g",10*/
0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,/*"l",11*/
0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x1F,0x24,0x24,0x24,0x24,0x17,0x00};/*"e",12*/
我想求如上字模数组的字符数
void getCharSize(unsigned char zk*)
     unsigned char charNum = sizeof(zk)/sizeof(*(zk))/16;
     //这里用Keil Debug看了,charNum =0x03;
麻烦请教一下大佬,如何才能在函数体内求得正确的字符数大小
ID:1012735 发表于 2023-3-8 01:24 | 显示全部楼层
strlen(char*)
ID:1034262 发表于 2023-3-8 09:53 | 显示全部楼层
你试试  unsigned char charNum = sizeof(zk)/16,就可以得到字符数。
ID:1065477 发表于 2023-3-8 10:56 | 显示全部楼层
这个方法已经试过了,不太管用
ID:97322 发表于 2023-3-9 10:04 | 显示全部楼层
sizeof(zk)/sizeof(zk[0])
ID:353115 发表于 2023-3-9 10:54 | 显示全部楼层
不可以的,数组经过函数形参传参后,会退化为指针的。得使用sizeof(Mode_Tri)/16
ID:807182 发表于 2023-3-9 14:22 | 显示全部楼层
直接strlen就可以啊
