查看: 1915|回复: 0
12位总线控制数码管,显示图
12位总线控制数码管,显示图,实际运行图
  1. #include<reg52.h>
  2. #include<absacc.h>
  3. #define hc273_U3 XBYTE[0x1fff]        //Y0:0x1fff(无关位用1),U1 74HC273 ,段码        四位
  4. #define hc273_U6 XBYTE[0x7fff]        //Y3:0x7fff(无关位用1),U6 74Hc273 ,位选
  5. #define hc273_U5 XBYTE[0x5fff]        //Y2:0x5fff(无关位用1),U3 74HC273 ,段码        四位
  6. #define hc273_U4 XBYTE[0x3fff]  //Y1:0x5fff(无关位用1),U1 74HC273 ,段码        四位
  7. unsigned char code c[10] = {0x81,0xcf,0x92,0x86,0xcc,0xa4,0xa0,0x8f,0x80,0x84}; // 数码管0-9段码 共阳数码管(修改)
  8. unsigned char code w[5] = {0x7f,0xfe,0xfd,0xfb,0xf7};//数码管位码
  9.
  10. void main()
  11. {
  12.   unsigned int t;
  13.   unsigned char i;
  14.   unsigned char PA = 0x01;
  15.   unsigned char a[4] = {2,3,4,5};
  16.   unsigned char b[4] = {7,8,0,9};
  17.   unsigned char e[4] = {1,6,8,3};
  18.   while(1)
  19.   {
  20.
  21.         for(i=0;i<4;i++)
  22.         {
  23.          hc273_U3 = c[a[i]];
  24.          hc273_U4 = c[b[i]];
  25.          hc273_U5 = c[e[i]];
  26.          hc273_U6 = ~PA;
  27.      for(t=0;t<1000;t++);
  28.          PA<<=1;
  29.         }
  30.         PA = 0x01;
  31.   }
  32. }
