查看: 5083|回复: 4
求助:ATMEG128外部中断程序进不了中断
ID:56375 发表于 2013-10-27 19:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <iom128v.h>
#include <macros.h>
#progma interrupt_handler int2_interrupt:4
/*函数功能:外部中断初始化(按钮下降沿产生中断,中断源INT2)
/*输入参数:无
/*返回值: 无
void extinterrupt_init()
  DDRD&=~BIT(2);//PD2设为输入
  EICRA=0x65;//INT2 下降沿触发
  EIMSK=0X04;//INT2  外部中断使能
  SEI();
/*函数功能:外部中断源2产生下降沿触发中断,按钮按下动作
/*输入参数:
/*返回值: 无
void int2_interrupt()
   PORTE&=~BIT(4);//点亮LED
  CLI();
  DDRE|=BIT(4);
  PORTE|=BIT(4);//LED熄灭
  extinterrupt_init();
请问以上程序为什么在PD2由高电平到低电平时进不了中断呢:谢谢
ID:65146 发表于 2014-9-12 22:50 | 只看该作者
我也是
ID:66032 发表于 2014-9-16 09:27 | 只看该作者
下面是我今天早上写的外部中断, 已经运行还可以
#include<iom128v.h>
#include<macros.h>
#define uchar           unsigned char
#define uint            unsigned int
#pragma interrupt_handler INT0_ISR:2 //ÏÂÃæμÄcodeò2¿éòÔ
//#pragma interrupt_handler  INT0_ISR:iv_INT0
#pragma interrupt_handler INT1_ISR:3  //ÏÂÃæμÄcodeò2¿éòÔ
//#pragma interrupt_handler  INT1_ISR:iv_INT1
uint count,num;
const uchar table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
               0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x40};
void delay(uint ms);
void port_Init(void);
void ExternalInterrupt_init(void);
void Numerical_display(uchar m, uchar n);
void main(void)
    port_Init();
    ExternalInterrupt_init();
     Numerical_display(num/1000,0);
     Numerical_display(num/100%10,1);
     Numerical_display(num/10%10,2);
     Numerical_display(num%10,3);
     Numerical_display(count/1000,4);
     Numerical_display(count/100%10,5);
     Numerical_display(count/10%10,6);
     Numerical_display(count%10,7);             //μ÷óÃoˉêy£¬ÏÔê¾
void INT0_ISR()       //ÖD¶Ï0·tÎñ3ìDò
     count++;
     if(count==9999)
     count=0;
void INT1_ISR()     //ÖD¶Ï1·tÎñ3ìDò
     num++;
     if(num==9999)
     num=0;
void delay(uint ms)
  uint i,j;
  for (i=0; i<ms; i++);
    for (j=0;j<1500;j++);
    PORTA=0xFF;  //êy¾Y¿úÎaêä3ö
    DDRA=0xFF;
    PORTD=0xFF;  //Pull up;
    DDRD|=0xF0;   //set the PORT as input
  EICRA=0x0a; //falling edge trigger
// EICRA=0x0f; //rising edge trigger
  EIMSK|=0x03;  //Enable INT0 and INT1
  MCUCSR=0x00;  //¿ØÖÆoí×′쬼Ä′æÆ÷3õê¼»ˉ
  EIFR|=0x03;
  SREG|=BIT(7);
      PORTD|=BIT(4);
      PORTA=table[m];
      PORTD&=~BIT(4);
      PORTA=0xff;
      PORTA&=~BIT(n);
      PORTD|=BIT(5);
      PORTD&=~BIT(5);
      delay(2);
ID:66032 发表于 2014-9-16 09:29 | 只看该作者
更改code 如下
ID:66032 发表于 2014-9-16 09:44 | 只看该作者
#include <macros.h>
/*输入参数:无
/*返回值: 无
  PORTD|=BIT(2); pull up;
  EICRA=0x02;//INT2 下降沿触发
  SEI();
/*输入参数:
/*返回值: 无
   PORTE^=BIT(4);// use the toggle mode, you will see the change everytime
  CLI();
  DDRE|=BIT(4);
