查看: 1707|回复: 0
求助 RK3588开发板在Android12.0系统上调试OV7251移植问题
ID:858009 发表于 2023-3-20 15:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本人小白一个,求解一下教程
使用的是
迅为的RK3588开发版
问题:打不开摄像头
打不开摄像头dphy3配置在ov5695基础上修改的
* mipi camera dphy1
&csi2_dphy3 {
        status = "okay";
        ports {
                #address-cells = <1>;
                #size-cells = <0>;
                port@0 {
                        reg = <0>;
                        #size-cells = <0>;
                        mipidphy3_in_ucam0: endpoint@1 {
                                reg = <1>;
                                remote-endpoint = <&ov7251_out_4>;
                                data-lanes = <1 2>;
                port@1 {
                        reg = <1>;
                        #size-cells = <0>;
                        csidphy3_out: endpoint@0 {
                                reg = <0>;
                                remote-endpoint = <&mipi4_csi2_input>;
&csi2_dphy1_hw {
        status = "okay";
&i2c4 {
        status = "okay";
        pinctrl-0 = <&i2c4m1_xfer>;
        ov7251_4: ov7251@36 {
                status = "okay";
                compatible = "ovti,ov7251";
                reg = <0x36>;
                clocks = <&cru CLK_MIPI_CAMARAOUT_M4>;
                clock-names = "xvclk";
                power-domains = <&power RK3588_PD_VI>;
                pinctrl-names = "default";
                pinctrl-0 = <&mipim0_camera4_clk>;
                reset-gpios = <&gpio1 RK_PD3 GPIO_ACTIVE_LOW>;
                pwdn-gpios = <&gpio1 RK_PB0 GPIO_ACTIVE_LOW>;
                rockchip,camera-module-index = <3>;
                rockchip,camera-module-facing = "front";
                rockchip,camera-module-name = "default";
                rockchip,camera-module-lens-name = "default";
                port {
                        ov7251_out_4: endpoint {
                                remote-endpoint = <&mipidphy3_in_ucam0>;
                                data-lanes = <1 2>;
&mipi4_csi2 {
        status = "okay";
        ports {
                #size-cells = <0>;
                port@0 {
                        reg = <0>;
                        #size-cells = <0>;
                        mipi4_csi2_input: endpoint@1 {
                                reg = <1>;
                                remote-endpoint = <&csidphy3_out>;
                port@1 {
                        reg = <1>;
                        #size-cells = <0>;
                        mipi4_csi2_output: endpoint@0 {
                                reg = <0>;
                                remote-endpoint = <&cif_mipi4_in0>;
&rkcif {
        status = "okay";
&rkcif_mipi_lvds4 {
        status = "okay";
        port {
                cif_mipi4_in0: endpoint {
                        remote-endpoint = <&mipi4_csi2_output>;
&rkcif_mipi_lvds4_sditf {
        status = "okay";
        port {
                mipi_lvds4_sditf: endpoint {
                        remote-endpoint = <&isp0_vir0>;
&rkcif_mmu {
        status = "okay";
&rkisp0 {
        status = "okay";
&isp0_mmu {
        status = "okay";
&rkisp0_vir0 {
        status = "okay";
        port {
                #size-cells = <0>;
                isp0_vir0: endpoint@0 {
                        reg = <0>;
                        remote-endpoint = <&mipi_lvds4_sditf>;
